Motherboard shorted ? help please
I have a MARS Foxconn motherboard ,i have a problem with this mobo , in a few words this mobo looks dead ( this happened after a possible short circuit from the back of the northbridge to the metallic mobo tray ) I already check the PSU two times with a PSU tester and the PSU is OK , i swap this Foxconn MARS mobo and installed a older Foxconn 945P7AA Motherboard and the PC with this older mobo is working properly OK ,I have connected the 24 pin connector and also the extra 8 pin power connector to the CPU , the Power Supply is a Seasoinic 650W energy plus, the blue Standby LED on the Foxconn MARS motherboard dont light on when I switch the PSU on,must be for sure a problem with the MARS mobo , but where ? what can I do? I have a expensive multimeter , thank you for the help
  • 74 Answers
Unless you have about a $3000 soldering machine and lots of skills soldering, i would say just get a new mobo. the cost to fix it would be lots more than its worth
Posted on Oct 11, 2008
I have a foxconn mobo model g31mv and has a problem with the video, well it shows nothing at all. Ive changed the memory, power supply, jumped the bios and check all the wiring and nothing. So.. what...
Try this motherboard troubleshooting beeping code first.
No beeping means short circuit,loose parts.
One beep means everything is working good.
Two beeps means CMOS error.
One long beeps,two short beeps means video problem
Three long beeps means keyboard error.
Continuous long beeps means memory not detected.
Continuous Hi-Lo beeps means processor overheat,loose blower fan heat sink.
If no beeps need to change capacitor parts of motherboard for burn, short and open leakage.
Jul 16, 2011 | Foxconn G31MV-K Motherboard
Foxconn 945G7MA-8EKRS2 Motherboard will not post with pentium d cpu ,i have even updated with the lates bios flash,
Good day,
According to Intel 945G chipset supports Celeron D up to Core2Duo. Intel Gigabyte's 945 DS3 even supports up to Core2Quad. GByte Foxconn has 3 mobo bios from there site. Foxconn
According to their date: Latest to oldest
4BFF1P56 No Version 4BFF1P40
Have you tried installing the no version bios? In my experience some latest bios have some problems with other devices so try to use the no version bios. or try a different mobo bios with the same chipset from Foxconn. below are two foxconn mobo models i can't see the difference.
945G7MA-8EKRS2 945G7MA-8EKRS2H
Update at your own risk..
hope this helps, thanks for posting.
Jul 01, 2011 | Foxconn 945G7MA-8EKRS2 945G P4/Pentium...
I have a foxconn motherboard (G33M02) and the LED is flashing orange and it will not power on. I have used the PSU on another computer and it work and when i used a different PSU the LED is steady orange...
 In that cse you must try 2 more things:
1 - remove all disks and try to boot in the BIOS - if it works then one of your disk is dead and blocks the motherboard. Find it by elimination and replace it. If it doesn't work then
2 - replace the memory, video card  and processor (in this order) and again try to boot in the BIOS. If everything fails then your mobo is dead, replace it.
Aug 11, 2010 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Is a HP Pavilion MCP73M01H1 (Napa) the same as a Foxconn M7PMX-S?
oh wow. Why would the lady say such an ignorant thing with such conviction. This is just nonsense as we all know companies outsource all the time, precisely Retail driven, close to the end user companies like HP and Dell. PRODUCING is not the same as contracting out a set of mobos like the gentlemen correctly suspected of being the same as a foxconn model. I happen to have an HP with a foxconn mobo (and to the guru lady, it seems to also have Nvidia's signature, so really, what you see here, is Nvidia provides tech, Foxconn manpower and efficiency, and HP sales and marketing and the product sells, but suggesting HP which cant get to the phone to keep up support go out and actually manufacture their own mobos is the stuff of laziness).
To the gentleman asking, I have looked at the specs and your analysis seems to be right on. Here's another exact HP product (the one I own, given another HP special foxconn mobo name given the sheer volume of business these folks generate to foxconn. It does seem to get often confusing though and if I were you, and you seem to be quite familiar with hardware and the such, if you were to attempt a flash, make sure to backup first, that is the only harm you will cause to your computer, if you are not cautious even when you're certain. Here's the link to which I mentioned so many times:
Jul 23, 2009 | Intel Motherboard, 945GC, Core 2 Duo,...
I don´t have the foxconn motherboard manual "661m08"
Most mobo's have the connection points printed on them. Use a strong flashlight and look for some pins that have the following words printed near them (PW or PWR, RS or RST, HDD LED, etc) They should all be grouped together in the same corner of the mobo. Have you tried googling the motherboad name to find a manual? I have done that on a few occasions and got lucky.
Apr 30, 2009 | Intel Motherboard
Foxconn n15235 mobo will not post nd gives long beep
i think your motherboard is your problem... check your motherboard to other systems.
Apr 15, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Audio drivers are gone
After some searching for that MoBO i found out that the name of your MoBo is P4M800P7MB-RS2H
And here is all avaliblr drivers for it
It the window "Search by download Type" you print P4M800P7MB-RS2H, in the window bwlow you select >DRIVERS, then you will see all drivers there is for that MoBO, select them you want and download them
Good luck to you
If you find my answer helpfull, plz dont forget to vote!
Dec 26, 2008 | Foxconn 6627MA-RS2H Motherboard
Motherboard shorted
Oct 11, 2008 | Computers & Internet
Foxconn x38 motherboard support
Please give me the full model number of you're Foxconn mother board. If you no longer have the box the number will be on the motherboard.
Example of other Foxconn model numbers. (Foxconn 865A01-PE-6EKRS), (Foxconn 760GXK8MC), (Foxconn 661MX) & (Foxconn P9657AA-8KS2H).
Type the correct model number into the window to the left of Search.
If you still need help just let me know!
Good Luck!
Jul 06, 2008 | Computers & Internet
Foxconn manual for a n15235
There is no Foxconn mainboard (and will never be...) called N15235 although this is printed on the board. The right name is P4M800P7MB-RS2H and you can find all stuff here: LINK
P.S.: you can find the right model number printed on the board beside the RAM slot near the CPU and on small label above.
Tom (
Feb 18, 2008 | Computers & Internet
Computers & Internet Logo
433 people viewed this question
David Payne
David Payne
