Question about Vacuums
Putting on a belt on a vacuum
Putting on a belt on a upright vacuum
  • 438 Answers
Greetings from GoVacuum.com,
Replacing a Belt on an Upright vacuum can vary from model to model, but it is basically going to be the same for most upright models.
First you will need to access the belt. Most upright vacuums this is done by turning the machine upside down, and most you'll need to remove the bottom plate by unscrewing (usually 4) screws that hold the plate on. You should see screws that are closest to the actual roller brush, simply remove these screws, and take the bottom plate off. If the machine is a Eureka, or Kenmore, the top agitator housing will be removed from the top of the vacuum, not the bottom.
Once you have removed the bottom plate, or top agitator housing, you should be able to see the belt (or broken belt) along with the roller brush. Remove the broken belt. Make sure that you purchase the correct belt by taking the make, and the model number (located on the back or bottom of the machine). Please note that a broken belt may be 4-5 inches longer then a new belt, as they stretch a lot before they finally break.
Once you have the new belt, you will need to remove the roller brush. Pay attention to how the roller brush fits into the agitator housing, usually there will be fittings on the end of the roller that have to be put in a specific place, or in a certain way to work right. After the roller brush is taken out of the machine, you will need to wrap one end of the belt around a metal pulley on the opposite side of the roller brush. Most pulleys are located where the main housing (handle part) of the vacuum meet the the agitator (floor part) part of the machine. Anyways, wrap one end of the belt around the pulley, and then put the roller brush through the other end of the belt. This is where you'll need to put some elbow grease into it. You'll need to stretch the roller brush and belt so that the brush and belt are stretched back to the place where you took the roller brush out of the vacuum.
Once you have replaced the roller brush with a new belt around it, pull the belt a few times to make sure that the brush spins while you are pulling it, to ensure that the belt is not pinched, and is spinning freely.
I hope this helps. Here's a video showing how to replace the belt on a Hoover Windtunnel Self Propelled model; Feel free to email me if you'd like to send me the model number of your vacuum, this way I can be a little more specific, and give you part numbers. I have all belts for all vacuums in stock. Email; chris.jones@govacuum.com. 1-866-468-2288. You may also chat with me by going to our website, www.govacuum.com, and clicking in the top right part of the page. Thanks!
Posted on Oct 13, 2008
  • 99 Answers
Make and model req.
Posted on Oct 11, 2008
reddevil6
  • 1673 Answers
SOURCE: looking for Eureka belt 70646A for a Eureka The Boss upright
It should be a standard Eureka U belt. That number you have is not a good number. Most repair shops should have this one. The R belt is a real thin and different material.
Posted on Mar 11, 2008
Agent Don
  • 310 Answers
SOURCE: installing belt on hoover self propelled upright vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40544&thid=641399
Installing belt on Hoover self propelled upright...
Posted by Fryeburger on Jun 02, 2008
Need help installing belt on Hoover self propelled upright vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Ultra U6430-900 Wind Tunnel Bagged Upright. The best way to install the belt on a Hoover to replace one or both of the belts @ the same time for the best cleaning. The average belt change is every 4 to 6 months for best results. There is a tool that looks like a screwdriver that has a right or left angle on the end that serves as a belt puller and to hook the belt(s) onto the brushroll 1st and then take your puller and then pull or stretch the belt onto the motor pulley. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 02, 2008
SOURCE: Beater Bar Belt Removal from Upright Electrolux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783793
Generic problem for all Vacuums
Beater bar Belt Removal from Upright Electrolux...
Posted by wrenn on Jul 14, 2008
I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Go Ahead. Use Us.
Posted on Jul 15, 2008
pinballer2
  • 9 Answers
SOURCE: putting on a belt on
Can you be a little more specific with your vacuum? I'll try to assist you if you have the model.
ukvacfan
  • 328 Answers
SOURCE: where is the belt on a dyson upright vacuum?
There is no drive belt on this model - its a cylinder pull along model.
If there's a problem with the turbo brush you can flip open the base of it by removing the screws, check that the toothed belt is in place and there is no clogs of dirt between the turbine and the brush bar.
Posted on Apr 12, 2009
How to change vacuum belt on a electrolux upright
ok,there are a number of screws under the power head unit.Remove them and gently pull off the top.gently remove brush,put new belt on the motor shaft first then put brush nack in position with belt on...Do not tighten up,there should be a little play in the belt.Simply put cover back on ..
Sep 05, 2014 | Electrolux Vacuums
Panasonic optiflow upright vaccum
Hello, Put the vac on its side and remove the screws holding the cover plate on. This exposes the beater bar and belt on the side. Pull the beater bar out and take the belt off. Reverse this to put the belt back in place.
May 30, 2014 | Panasonic MC-UG323 OptiFlow Upright Vacuum...
Eureka 1931 bagged upright, I changed the belt but now the cover is rubbing against belt. How do I prevent this?
If your cover is rubbing, you probably put the belt on wrong. It should line up with the belt close to the groove in the underside of unit.
May 31, 2010 | Eureka 1934 Bagged Upright Vacuum
The brush belt has come off my Bissell 8910. Part
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
tey36
Apr 18, 2010 | Bissell 8910 ProHeat Clear View Upright...
Belt pulley is broken
sad to say but as far as i know you cannot get any parts for dirt devil vacs only filters and belts and bags sorry
Nov 03, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Cannot figure out how to install brush belt on a bissell proheat
heatman101
twywt
Jan 16, 2009 | Bissell 8910 ProHeat Clear View Upright...
Problem getting belt around motor shaft... Eureka The BOSS
make sure the vacuum is in the upright (locked position) - when you lower the handle, this puts tention on the belt. If it is in the upright and locked position, there is plenty of clearance (unless you have the wrong belt.
Apr 07, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
298 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
