Question about Microsoft Office Outlook 2003 for PC
MS WORD paragraph spacing
Hi, I'm using double spacing but when I press enter for the next paragraph it is more like 2.5 space, but only between paragraphs. Usually it keeps to the double spacing format. What have I done and how do I fix it??? Please help, my assignment's due in two days!! Thanks!
    President:
  • 1,901 Answers
Click on Edit>Select All.
Then click Format>Paragraph.
Make sure "Spacing">"Before" and "After" are set to 0 (zero), then click on "OK".
Posted on Oct 11, 2008
When I hit "Enter" it always double spaces. What do I need to do to get single space?
Your word default is set to double space. You need to find your paragraph setting, depending on the version of Microsoft Office you are using. Once you find the paragraph settings, you need to set it to single spacing and set the "spacing before" and "spacing after" to zero as in the attached picture.
One way to set the option is to hit control-A to highlight the whole document and then right click, and then click on Paragraph.
25547294-44porhhyjuxju0hkakw43rbb-4-0.jpg Good luck.
Paul
Mar 10, 2015 | Microsoft Windows 7 Home Premium for PC
Double spacing
Before doing anything else, highlight all the text (including any 'white space' that might follow), that you want to change into 'single' spacing. Then go to top menu 'Format' then select 'Paragraph' and on the new menu find 'Spacing', Then on the pull down menu select 'single' and 'OK'
Jan 14, 2014 | Computers & Internet
How do I set the space tabs on Dell Inspiron M5030
The only place I am aware of is in MS Word.
MS Office 2010 Word - Right click anywhere on document and using Paragraph. Custom Indents and Spacing are set there.
Oct 12, 2012 | Dell Inspiron M5030 2800B3D 156Inch Laptop
How to fix line spacing to single space on word pad to type a letter. i have it on single space but still does double space
when in wordpad there are couple of things in blocks
clip board, font, paragraph,insert,and editing
2x spacing will be in the paragraph block its the top row right corner
if u hover your mouse over it reads line spacing click it and change it to 2
that should fixya up
good luck on the letter
Mar 29, 2012 | HP Computers & Internet
How can I come back to normal distance between the lines in a document
Depending on the actual program you are using it will be under similar titles to these: With MS Office 2003 you should go to format --> Paragraph--> Indents and Spacing (tab) then select your line spacing. Most doccuments are considered "normal" when they are double spaced. In MS Office 2007 the titles are similar yet not quite the same. I am not positive what the precise titles are under 2007, or any other word processing programs, but they are typically intuitive once you know the context of one.
Sep 09, 2011 | ASUS 90-A4C1K1000 Keyboard
Good day! sir/madam..where can i find the line spacing? i need it because i want to create a concept map and my teacher wants that it's line spacing is double spacing. how and where can i find it? thank...
Go to the Home ribbon, then to paragraph.
There should be a small arrow shaped figure in the bottom right corner of the paragraph area.
Click that and change the line spacing to double spaced.
Mar 05, 2011 | Microsoft Office Professional 2007 Full...
How do i change line spacing to single spacing
Okay, follow the procedures below:
from your ms word, click format and scroll to paragraph, then press enter.
Check the third option and you will see spacing, from there, you can change to single line spacing and press ok to save settings.
Good luck.
Apr 18, 2010 | Microsoft Office Professional 2007 Full...
I NEED TO RE-PROGRAM PRESET NUMBERS, BUT DON'T HAVE MANUAL FOR CANON L350 FAX MACHINE?
Open panel cover Press DATA REGISTRATION Press V to display 2. TEL REGISTRATION Press SET twice Press V (if necessary) until an empty space appears Press SET twice Enter Fax number Press SET twice Enter name using number keys (e.g. 2 = A,B,C like a mobile phone) Press > to enter next letter Press SPACE to enter a space Press * to enter a numeric Press SET To continue press DATA REGISTRATION Repeat steps 5 to 10 To end press STOP
Feb 09, 2010 | Canon FAX-L350 Plain Paper Laser
Trying to type and single space
You can change this by adjusting the line spacing option.
You are talking while typing wright.
You can select the whole document by Ctrl+A.
Right click & select the paragraph option.
You can find spacing & line spacing.
In the line spacing select the numbers as you like.
Its better to use it as 1.5.
And click on ok.
Good Luck.
Live, Love, Laugh.
May 12, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Office Outlook 2003 for PC Logo
95 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
