Question about NAD C542 CD Player
Digital out put problem to external DAC
I have a two year old NAD C542 and recently added a Musical Fidelity X-DAC V3.
The DAC is connected via a 75ohm coaxial cable.
The problem is occasional brief cutting out of sound (like skipping but not the disk skipping - if you know what I mean) at the begining of tracks. The DAC works fine with my Sony DVD player and the NAD player is fine using its own DAC.
Other than the skipping the combination of the two sounds absolutely fantastic.
Is it unusual to have a problem in the digital output stage of the NAD cd player?
Or could it be that because it is a HDCD player as well, that there is a compatability issue?
Please help
SOURCE: Nad C542 Troubleshooting
This is an issue that has plagued the 541I and 542 models - some units worked fine and some units had similar issues as the ones you mentioned. It was suppsoedly fixed beginning with Serial Number G56C54224800 but I know someone who has a later serial number and had the same issue. It could be the laser or the transport or both. Simply put NAD has a quality control issue. There products still produce great sound but the great sound at a reasonable price is seemingly coming at great cost - the lack of consistent quality.
Posted on Nov 18, 2007
petraman7
  • 1175 Answers
SOURCE: NAD C541 CD Player
I wouldnt buy another one from NAD.
I've worked on their stuff cant say anything nice, Sorry.
Posted on Nov 14, 2008
petraman7
  • 1175 Answers
SOURCE: NAD 5340 spins disk but no audio output
Hi...
I've worked on a number of NAD players.
2 things to look for.
1. The belt that pulls the drawer in also lifts the laser assby to the disc. Those wear out.
2. The capacitors in the power supply section tend to age poorly.
Theyre usually 470 to 1000 uF(microfarads)
Also try pulling all the cables and re-seating them
If any of this works, rate my help please,
Thanks
Posted on May 08, 2009
  • 5 Answers
SOURCE: NAD C542 CD PLAYER
maybe it is just the belt for the tray motor.
Posted on Dec 01, 2009
robotek
  • 1512 Answers
SOURCE: Pressing the 'open' button on my NAD C542 CD
G'Day Michael,
Having fixed thousands of CD players in my career, and also being a NAD Authorised service guy from 1989 till recent times, I can comment with some authority to your situation, and correct some of the ill found assumptions given to you already.
This unit uses a KSS213c transport. Very common and used in many machines, also relatively reliable.
The drawer load motor is not shown above. Is will be mounted on the black plastic load assembly. The drive belt/motor for it will be under the tray runners.
If you do not hear the motor run, then it WILL NOT be a broken or failing belt. However, this is the most common problem with this style of transport. I would be checking anyway to see, the load motors do free run fairly quiet with no drive belt connected. Wind the tray assembly out by hand by kicking the gears over to open the draw to see the belt/motor
Because you cannot get it to work from the remote, AND you have "open" indicator on the front panel, it WILL NOT be a faulty front panel button(never seen one fail ever!)
I have never replaced a load motor to a Sony transport. Spindle motors can be a problem, but they never stop working altogether.
I would be checking the tray mechanics, a jam caused by something fouling the gears may cause a fail. Tap the front of the draw as you press eject to see if you can encourage it to work.
Sometimes, small nylon drive pinions can split, the excessive gap in the gears caused by the split causing a bind. Check also for blown pico fuses in the servo drive stage. This will cause no drive to the load motor.
If you cannot pin down the source of the problem, the player IS welll worth repair. These machines sound great and would have cost you a few bucks to begin with. If you need help locating an expert NAD authorised repair guy I can help.
Happy to discuss any of this further with you. As previously direct your comment to me by name. Cheers
regards
robotek
Posted on Aug 04, 2010
NAD WIRELESS USB DAC 1 KILLS WIFI CONNECTION
The NAD wireless using the 2.4Ghz frequency which is also used for WIFI.
Your option would be to change the channel of your WIFI to see if you can reduce the interference.
Your best option is to use 5Ghz for your WIFI (this requires that your Wireless router and Laptop support 5Ghz).
Jan 31, 2014 | NAD DAC 1 Wireless USB digital-to-analog...
I'm sending the signal from the TV's digital audio output to the digital audio input of a Musical Fidelity M1 DAC then out to my speakers. For 2 stations, ABC News 24 and Gem, the only sound I get...
The default audio output device on your television set needs to be set to digital audio out. Do this for all channel types, whether HDTV or whatever. Also, if there is an option to convert all audio to digital (as there are on some televisions), choose that option as well.
May 16, 2011 | Televison & Video
Audio CD playback problems
the problem may be in that you have two audio outs conected, one stereo via rca and other hdmi remember that hdmi is audio and video outs or two digital outs one hdmi and other coaxial or optica to tha dacs, put only one outs and thats the solution
i hope i could help you
Jun 02, 2009 | NAD T 515 DVD Player
may be you have another digital outs like and hdmi, be sure that you have only one audio out
May 25, 2009 | NAD T 515 DVD Player
NAD CD player C 542
SORRY but you need to get this to your dealer,don,t think anything is stuck in there just a faulty drawer mecanisim.
hope this helps.
CABLE GUY.
Aug 04, 2008 | NAD C542 CD Player
NAD C542 CD PLAYER
Jun 27, 2008 | NAD C542 CD Player
Nad plays for a minute or so...
First thing to do is to check all your new caps and their polarities.
Capital98
Dec 19, 2007 | NAD C542 CD Player
found same problem with mine, solution .. place clean paper over the optic, then a magnet, leave for a few seconds, the build up of static causes a magnetic field in the optic preventing it tracking, have cured a few other brands with this as well .. shows manufactures are putting inferior parts in to their players, hope this helps !!
Mar 20, 2007 | NAD C542 CD Player
No disc
Try using a cleaning disc, if that doesnt work take apart the unit and manually clean the lens. If that doesnt work your going to have to take the unit in for an estimate. If its more then two year old and you paid less then 150 bucks for it , it probably is not worth the estimate fee. good Luck
Aug 26, 2006 | NAD C542 CD Player
'No disc'
Most likely a general service is required.As it is under warranty, take it iommediately to their Service Centre. They will clean the lens. grease the Drive Mechanism and Tray mechanism. Should - in all probability clear up the problem.
NAD C542 CD Player Logo
100 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
