Question about Toshiba TP50F60/61 TV
Toshiba Theaterview TP50F60 Color tube problem
I just traded an old amp for this tv. It turns on and it will show a faint picture but the light from the red,green and blue projectors show through the screen and onto the wall. What could be causing this problem?Thanks I really want to get this fixed
  • Anonymous Oct 11, 2008
    I HAVE TRIED TO ADUST THE PICTURES AND STILL NOT SHOWING GOOD.
  • swomina Oct 13, 2008
    I found out what the problem was. My lenticular screen is damaged so it's not catching the light properly. As a temporary replacment I removed the fresnel screen and made a screen out of two layers of wax paper fused together. The image quality isn't the greatest but it's definitely watchable.
djnick989
  • 1067 Answers
SOURCE: my toshiba wont turn on but red light come on an green light flashing no picture or sounds
yes ill got remote link for u here give me one sec
Posted on Jan 29, 2008
  • 3 Answers
SOURCE: Toshiba TheaterView
Called Tv tech. He said it was the power supply connectivity. common problem in rear projection Tv's. Cost to replace was anywhere between $300.00 and $400.00 dollars. Time for a new tv :-(
Posted on Apr 09, 2008
  • 3 Answers
SOURCE: Toshiba Theaterview Black Screen
yes its on your remote. its the c.capt button. or go under menu/enter and pan to the left untill it comes up. and turn it off by scrolling through the caption buttons
  • 67 Answers
SOURCE: color
I would not recommend changing tube usually 10,000 volts on a crt so very dangerous better to buy a new tv typically around the same in price
Posted on Apr 14, 2009
  • 7 Answers
SOURCE: Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Posted on Jan 09, 2010
WHY COLOR IS HAZY?
Model indicated is a projection set with three picture tubes.
Cleaning may help your problem--two ways to do this-
with set unplugged remove rear cover and clean the three large black lens you cannot miss--if dusty the picture will be dull and darker--should be done once a year.
Peek up inside to the rear and look at the mirror--unless grimy leave it alone.
Other way is to remove entire screen unit which if you have not done that entails some danger of damage to the screeen.
Try cleaning the lens to see if improvement.
Jun 12, 2012 | Toshiba TP50F60/61 TV
Have an older Toshiba theaterview TV, when turn on, we have no picture, no sound, just black screen and blinking red light that just continuously blinks.
Theaterview suggests a rear projection--in that case it most likely is in the convergence circuit--unsolder chips (convergence) and see if set turns on.
Some of their regular TV sets (picture tube) if the light is just blinking means the same thing=shutdown because of a short/problem but a model number would tell me which you have.
May 23, 2012 | Toshiba Televison & Video
My Toshiba TheaterView has no sound or picture
You may have overloaded your audio output with the external speakers(impedance or short wire problem?)as a result the audio out i.c maybe damaged which in turn may have blown one of several fuses in the power supply.maybe regular GMA type fuse or picofuses,you can try replacing blown fuse but if they blow right back you`ll need the help of a repairman
Nov 02, 2009 | Televison & Video
TP50F60/TP50F61 not working; no picture or sound;
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 11, 2009 | Toshiba TP50F60/61 TV
My 50 "Magnavox rear projection has a vary faint picture
If its over 6 years old , sound like the tube are shot , bright/focus together = bad tubes
sorry
Jun 30, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Mar 13, 2008 | Toshiba 50A60 50" Rear Projection...
Toshiba TheaterView
Feb 21, 2008 | Toshiba 50A60 50" Rear Projection...
Toshiba theaterview
What is the model number?
Jan 03, 2008 | Televison & Video
TV turn off and problem with red colour
the problem is in your color circuit and power supply make checks in those areas check the power supply regulator, diodes, cap ,and resistors.in the color circuit replace your color ic.then you can do resoldering of the components in the those same circuit,this will contain your problem good luck.
Jul 26, 2007 | Toshiba TP50F60/61 TV
Televison & Video Logo
203 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
