Question about GE Dryers
Ge dryer my ge dryer squeals on every revolution. the sound is coming from the back middle.
  • rambrose91 Oct 11, 2008
    I have a model# DDE 7907, serial# vh240883 GE dryer. Your response was the belt tensioner roller. With all due respect I don't think it is that because the sound is coming from above the tensioner. I can turn the drum a little bit at a time and every revolution you can hear a little sound right in the middle of the drum near the back wall.
    President:
  • 1,901 Answers
It is probably the belt tensioner roller. They are not that hard to replace and not that expensive either. If you have it replaced consider replacing the belt while you're at it.
Posted on Oct 11, 2008
I have a loud squeal in my GE dblreeee2w dryer. Can you tell me how to take the back pannel off to gain acess?
front panel .. the back panel dosent come off open door two phillips screw in top of door shroud opening the top lifts up screws in corners remove front door assy....
Jan 31, 2011 | Dryers
My dryer makes a loud noise when turned on seems to be comming from the back of the drum
Hello there: Here is the only things that noise could even beginning to come from so please read the entire list i have provided below Rear drum bearingSome dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Jan 12, 2011 | GE Dryers
Loud squealing sound when the basket first spins up this is a Kenmore stacked set, washer on the bottom, and dryer on top
Your problem could be a bad bearing...The drum rides in a bearing at the rear middle of unit..Its basically a plastic insert...When the dryer is first started the bearing will squeal until the plastic warms up..Normally you will hear the squeal at the back middle of dryer...Your problem may also be the belt tensioner...Again a plastic wheel with a metal bearing inside...Normally this squeal will be from start to finish..
Apr 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dryer squeals
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jan 17, 2010 | GE DWSR463GGWW Dryer
Squealing dryer.
Squealing usually refers to dry bearings. And the only bearings on a dryer that I know of, are where the shaft of the drum attaches to the back. But these seldomly give trouble. Can you tell where in the dryer it's coming from?
Dec 17, 2009 | GE Spacemaker Washer and Dryer Electric...
The dryer squeals (metallic sound) while drying clothes.
check wear pads around front of drum or rear depending on brand. Ge's are particularly prone to scraping sounds, but still one of my preferred brands. IF a ge, did it get any dents around the sides or back? The drum is close to the sides and a dent in right place will do it. Also the rear panel can push the drum forward rubbing in front.
Ge - wear strips in front, plastic bearing in rear center, replace both, inexpensive.
Whirlpool- felt pad and wear strip in front, felt seal in rear with roller support. check rear seal lube rollers
Maytag -roller in front and rear with front and rear felt seals. some designs have front drum support posts with wear pads. ck these.
Frigidaire (include some sold under GE name) rear bearing cup (plastic)-lube, front feltpad with wear plates if plates gone get new pad/wearplate asm.
Maytag and ge nomenclature tags are in rear .
Jul 19, 2009 | Dryers
Kenmore 417.81042000 Electric dryer has loud squealing sound
My dryer of the same model number had the same issue. The teflon/plastic wear points are worn out or have fallen off. They are about $22.00 plus shipping at the site below. Disconnect the power, lift (with force) the top off at the front of the dryer and you will have access to remove and replace.
Felt glide assembly - Upper felt seal with three glides attached. Comes with adhesive.
Part Number: AP2150497 made by FRIGIDAIRE
www.appliancepartspros.com/modelsearch_model.aspx?part_id=2150497&&model_id=301211
Oct 30, 2008 | GE DBL333EA Electric Dryer
Dryers Logo
123 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
