Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
Jenn Air Electric Slide In Range JES8850BCS
Electronic panel for the oven does not work. The timer and number keys work fine. I tried resetting range however that did not work.
  • 833 Answers
SOURCE: Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
Posted on Dec 13, 2007
SOURCE: jenn-air jes9800AAB keeps buzzzing, front function panel flashes on and off
Your control panel is getting ready to quit. Mine did the same thing, I ignored it and now nothing on the touch panel works. About $150.00 for the part.
Posted on May 30, 2008
SOURCE: Clock/oven/temp screen for a Jenn-Air electronic range #SVE87600
I believe Jenn Air will pay a portion or electronic parts replacement on their ranges less than 5 years old.
You might try unplugging the stove for 1 hour and this is supposed to reset the stove to factory settings
Posted on Sep 10, 2008
alandc
  • 25 Answers
SOURCE: Don't know if the oven part of range is gas or electric
The model number can usually be found just inside the door or drawer (on the range itself).
All the Jenn-Air convection ovens I'm familiar with are electric even if the cook top is gas.
Posted on Jan 31, 2009
erpaalai
  • 999 Answers
SOURCE: jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Posted on Jul 03, 2009
I have a jenn-air electric down draft slide in range. I had a power outage and now stove top works fine but no display or oven functions not even oven light.
You will need to replace the control board (clock assembly) on your unit. I see this all the time with power surges and it takes the control board out. Your model is a discontinued one and the part may need to be a special order. Here is a link to the part, call the number that is on the page and I am sure they may get it for you.
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-clock-item-number-ap4088717.aspx
Nov 08, 2011 | Jenn-Air SVE47100 Slide-In Electric...
I need to replace the glass top on a jenn air JES8850BCS slide in range. How do I do it? Can it be done leaving the range in place or does it need to slide out for the replacement? Thanks.
It looks as if you need to remove the whole cook top to replace the glass top, incidently that is a 400 dollar item, so you have to take care. See: http://www.partselect.com/PartDetail.aspx?Inventory=2341162&SourceCode=5&ModelNum=jed8430#RepairStory
Apr 11, 2011 | Jenn-Air JED8430 Electric Cooktop
My Jenn-Air SVE47100 slide in electric range does
Obviously it does not work fine. The thermostat sensor or the stat itself could be an issue. Can you see the sensor 'bulb'? Clean it with oven degreaser and steelwool. What is the temp in the oven with a 'oven thermometer'? Is this consistent with the oven readout?
Sep 24, 2009 | Jenn-Air SVE47100 Slide-In Electric...
I have a jenn air oven and stove top. the
Just a suggestion, turn the breaker off to the range and leave off for 30 secs. This may reset the board. That's the easy way. If that doesn't help I'll try to find more on it.
Jul 24, 2009 | Jenn-Air JES9800A Electric Kitchen Range
Oven element
bad relay on erc(electronic range control), or and open thermaostat wired in line with element you would need to pull unit and check wiring
Feb 07, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Jenn-air slide in range/convection
its not a loose wire. jenn-air is famous for having to replace the display board. once you replace it it will be fine
Nov 28, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Electric panel not working
you have a common problem for that oven the key pad fails from wear try to find a replacement it should be fine after that.
Sep 19, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
135 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
