Question about HP Office Equipment & Supplies
HP Photosmart C6180 printer doesn't print yellow. I have replaced all cartridges with new ones and gone throught the cleaning and alignment menus without success. I performed the extended self test diagnosis and I see that item 73 states: "Print Head Calibration Confidence Level: 0." In the past I have used refilled cartridges with no problems.
  • 4 more comments
  • Kurzy Oct 11, 2008
    Thanks Nick, but as stated in my initial posting I have replaced all cartridges with new ones. By that I mean new HP original cartridges.
    Although I appreciate your comments they do not solve the problem.
    I can't undo having put refilled cartridges in the printer. So we're back to square one.
    I have gone through the entire HP diagnostic, alignment and cleaning menus and still no yellow
    Thanks but none of that worked. The # and 6 buttons had no effect and no reset appeared. The printer came on as usual.
    Thanks to Y'all
    Thanks Pride but that didn't do it either.
    Still no yellow
    Thanks Proton, but no, there were no yellow stripes.
    I do not have a second computer but can locate one and check further.
  • Anonymous Mar 22, 2014
    The alignment fails causing very poor performance. I have replaced all the ink cartridges, and cleaned the print heads. What else could be causing the problem.
    Sergeant:
  • 399 Answers
This sort of issue can also be caused if the electrical contacts between an ink cartridge and the print carriage are dirty. Assuming all the cartridges have ink in them, you should check the electrical contacts on *both* the cartridges and the print carriage. HP.com has a web page that shows you how:
Cleaning Electrical Contacts
also try this in the same manner as the instryctions are given.a slight change in doing will not reset.
The issue might be with the printer's cartridge or might be with the print head. So, please check for the ink levels of the cartridges and try cleaning them and also the print heads.
Try to perform the following steps:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Let us reset the printer to the factory settings
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold # and 6 while plugging in the power cord.
Posted on Oct 11, 2008
  • HP Master
  • 1,879 Answers
Just my piece,
browsed thru all suggestions and all that you've done.
new carts, cleaned contacts where cart snaps in, alignment, head cleaning, HP's troubleshooting.
original or refill is not recognized by the printer anymore. this type of problem with inkjets regardless of brand is bound for service/replacement.
    Novelist:
  • 188 Answers
Hi Kurzy, Please perform the following steps exactly as listed. A. Press and hold the ?*? key. B. While holding the ?*? key, Press the ?#? key, then release both keys. Display should say ?Enter Special Key Combo? C. Press and release, in sequence, the ?1?, ?2? and ?3? buttons. The screen should now say : "support" R0631M D. Press and release the right arrow button until the display says ?System Configuration Menu?. E. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?. F. Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. G. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. H. press and release the ?CANCEL? button as many times as necessary,so that, either the ?Welcome to Photosmart Express? screen appears, OR, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. I. Using the Power Button, turn the unit OFF, then unplug the power cable from back of the printer and wall outlet. J. Wait at least 30 seconds for the power to get discharged, then plug the power cable into the wall outlet first and then into the back of the printer. K. Turn the unit on. L. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. M. Press OK. N. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. O. Finally, print a self test page to check the functionality of the printer. P. Press Setup menu, then scroll using the arrow key and select Print Report then select Self Test Report.
    Genius:
  • 1,226 Answers
From the start of your question, i realize that there is no problems in the ink. the only problem put in my mind was the printer head of the printer. If the printer got older the some of the nozzle which passes the ink got sticky in which the yellow portion is affected. Our repair services here got to resolve this problem by pull outing the printer head and then clean it or blow it with air. If this not resolve the issue, there is a loss connection of the circuit connecting from the printer circuit board to the printer head of the printer.
may this help;
melnavz
  • HP Master
  • 1,183 Answers
The problem is with the print head and the , thin plastic signal cable that is attaches the print ahead to the printer. This part is not user replaceable and requires a technician to service the same.
As you have mentioned having run the HP diags. The test page , did it display yellow stripes or not.
Secondaly, if you have another computer at your place, or can check the printer on another system , it would help isolate the problem with the printer.
Thanks
proton
  • 87 Answers
OK.
The pocket where your cartridge snaps into. There is some gold connectors that will transfer signal to the cartridge telling it what to do . Now Take a bottle of rubbing alcohol and get a cotton swab or something of that nature. And rub on those contact points ( Not the new cartridge you have bought). The cartridges you buy are very clean and most cases never need clean. But on the other hand the printers continue to age and do to the moisture levels in a home being a level higher than that of outdoor moisture levels (factoring in cooking and what not) its not to say you have developed some invisible level of corrosion.
P.S If you don't have alcohol do not substitute it with any thing like acetone. I have did my best to apply to you laymen terminology for your benefit. good luck and thanks .
Yours truly;
PRIDE2000AD
    Scholar:
  • 54 Answers
Hi Kurzy,
This problem is pretty wide spread with this model and nobody knows why. We don't need to know the why, just the how - to fix it. I have found in my experience that once a printer gets something stuck in its very limited memory, it wants to hold onto it for dear life. Try this if after all the head cleanings and cartridge alignments have failed. Click Start>control panel>system> click the hardware tab, choose the device manager, scroll to imaging devices, find your unit and right click>uninstall. In the add/remove programs in control panel find printer and uninstall everything that has to do with your model. Power off your computer, while it is powered down, un-cable the printer from the computer. Now, don't use the manufacturers install cd, instead, go to:
http://www.hp.com/country/us/en/welcome_thumb_supp.html#Support
Before you download your software create a new folder on your desktop and name it something relevant to the software you are downloading i.e. newhpdrivers. Download software. Power off your computer, reconnect the printer to the computer, turn the printer on and power on the computer. Windows will detect new hardware and the wizard will ask for manufacturers install cd or a location to check for install files. Direct the wizard to the newhpdrives folder. Follow the instructions, restart when prompted, done. I hope this helped a little.
Thank you for using FixYa.com
Sincerely, cyyyd7
  • cyyyd7 Oct 11, 2008
    listen you cheap bastard, cough up the bucks and get real tech support.
    Brigadier General:
  • 6,966 Answers
Initially, pls try a reset:
  • power on the C6180 using the ON button;
  • unplug the AC cord from the mains;
  • simultaneously press and hold the # and 6 button while plugging the unit back to the mains;
  • maintain press & hold on the above buttons until display goes blank;
  • release both buttons;
  • "RESET" should be displayed.
Additionally, you may want to reference this page for additional insights.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Oct 11, 2008
    Hi again,
    I understand, have you tried the long method as described here?
    Master:
  • 763 Answers
Sir, did you try to uninstall and reinstall again your printer to your computer. do what you did before when you did your first installation of your device to your computer and see what happens. hope that helps!
CHARCOIS
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
It is the problem defective print head bud. Try to clean the print head. Also click this link for more information and troubleshooting tips.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00721660&lc=en&dlc=en&cc=in&product=1153494
http://h10025.www1.hp.com/ewfrf/wc/product?product=1153494&lc=en&cc=in&dlc=en&lang=en&cc=in
Thanks
Good luck
    Sergeant:
    Champion:
  • 334 Answers
Thats why cant use refill on these mess head s up on it i never recomded useing that stuff jams heads to point u cant clean them ok try reg hp ink once see if it fixes it refill stuff is dangeruis to this not mixed the same way hp is to go thorw nozzel after time time of using that refill stuff jams heads up clogs to points no good ok
  • nick helpap
    nick helpap Oct 11, 2008
    proably from over jam on nozzel form using bad refill ink to much wont last ok bad nozzel bestto buy new one i was right
HP A636 will not print yellow; tricolor cartridge is new
  • Align the print cartridge.
The printer automatically aligns the print cartridge after a new one is installed. You can also align the print cartridge at other times to ensure optimal print quality. Indications that you need to align the print cartridge manually include borderless prints with white space
along an edge, colors not printing satisfactorily, or poor print quality.
To align the print cartridge from the printer
  1. Load a sheet of HP Advanced Photo Paper in the input tray.
  2. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  3. Touch Cartridge.
  4. Touch Align Cartridge and follow the prompts.
Clean the print cartridge automatically.
If the printed pages are missing lines or dots or contain ink streaks, the print cartridge might be low on ink or need to be cleaned.
CAUTION: Clean the print cartridge only when necessary.
Unnecessary cleaning wastes ink and shortens the life of the cartridge.
  • Clean the cartridge.
Follow these steps to clean the cartridge automatically:
To clean the print cartridge from the printer,
  1. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  2. Touch Cartridge.
  3. Touch Clean Cartridge and follow the prompts.
If the documents are still missing lines or dots after cleaning, replace the print cartridge.
Attaching User Manual (see page 59).
http://h10032.www1.hp.com/ctg/Manual/c01518966.pdf
Feb 18, 2014 | HP Photosmart A636 Compact Photo Printer
The yellow cartridge doesn't print
Either the print head is blocked or the cartridge is empty, you can try the clean accessory in the printer toolbox/maintenance, if that fails, replace the cartridge.
Sep 06, 2010 | HP Photosmart C6180 All-In-One InkJet...
Brand new yellow ink cartridges are always read as empty
We have a step by step solution posted on our we site at: www.ccl-la.com/HP.htm The problem is air in the ink lines and the guide helps you purge the air from the system and restore printing.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
C6180 failed alignment test, will not print color properly
All colors need to be present to pass alignment. Usually what I see is the yellow is empty. You can blot the print cartridge on a damp paper towel to verify the inks are working and this also cleans the head.
Jun 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 indicates I need to replace the cyan cartridge but even when I replace it with a new HP cartridge I get the error. If I allow it to 'print in Black only' all colors print correctly and the ink...
All you need to do is an alignment on the printer.You will find that option in the control panel menus.If it still does not work try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Apr 04, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 all in one, does not copy or print anymore.
put the old cartridge back, if there have same error message then tell me what error message is, if not that's mean new cartridge is defect.
Dec 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart D7360
try to align the print cartridge. go to settings -> tools then choose align printer. you may also try to clean the print head.
Nov 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C5280 printer - 1 month old not printing correctly
Usually this problem is indicative of a clogged nozzle. I'm not sure about the track record of the Photosmart C5280 (a lot of Epson printers have this problem, and you just have to keep replacing the ink cartridges). I'm going to assume you tried this, but go ahead and run a few cleaning cycles on the printer, and see what happens.
Jul 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart C6180 black cartridge not printing
me too . 2 cartridges became empty at the same time and printer
stop printing COMPUTER FILES . yet , printer IS functioning
as FAX printing device ...
Jul 02, 2008 | HP Photosmart C6180 All-In-One InkJet...
904 people viewed this question
Ben Johnson
