Question about Liquid Video MVBG619 Portable DVD Player
Liquidvideo LV-1530 TFT display with DVD player - DVD doesn;t work
I purchased approx 5 years ago system work perfectly approx. 1 year ago the unit would automatically take in DVD's. I would have to wiggle the dvd until the unit would recognize it and then pull it in at which time it would work. If I pushed the DVD into the slot it would not start spinning and play. The DVD on the unit has now stopped all together. It will not automatically take in a DVD no matter what I do and never starts spinning - ideas? Parts?
5 Suggested Answers
SOURCE: DVD player keeps shutting off
I HAD THE SAME PROBLEM BUT ON MINE I HAD TO REWIRE THE FAN WHERE IT HAD WENT OUT IT WAS REAL SIMPLE.JUST TAKE THE BACK OFF OF OT AND UNCLIP THE FAN WIRES AND SPLICE THEM INTO THE HOT AND GROUND WIRES THAT RUN RIGHT BESIDE IT (THE MAIN HOT AND GROUND) .IT WAS GOING TO COST ME 85 DOLLARS TO HAVE IT FIXED IT ONLY TOOK ME ABOUT 30 MIN.AND I DID IT MYSELF.GOOD LUCK
Posted on Mar 04, 2008
SOURCE: Car DVD player powers off after 5 mins
I FORGOT THE PASSWORD
Posted on Apr 08, 2008
Witchunter
  • 98 Answers
SOURCE: black screen on L17lcd2
If you even manage to find some, I am almost completely sure it would be better to buy a new one when it comes to finances. Putting these parts together is a skilled technique. Also, if you have a guarantee with that monitor, why not return it.
Posted on Jan 15, 2009
jimboz4
  • 305 Answers
SOURCE: remote for my Liquidvideo MVOHD70 Car DVD
hi, have a look on this website...hope you can find what your looking for
http://www.avukltd.com/
Posted on Jul 29, 2009
Westinghouse oven model WFE946SA, purchased only 4 mnths ago. No lights display
main control board,take it back,its expensive,1 year warranty
Jul 26, 2015 | Ovens
Panasonic DMR-EZ28 won't talk with remote
hi you need to reprogram the remote to fit with the unit there have 3 codes for remote 1 or 2 or 3 to reprogram your remote with the code indicated on your display press and hold the [3] and [ENTER/OK] buttons together for approx 5 to 10 seconds, then release
Jun 24, 2009 | Panasonic DMR-EZ28K DVD Recorder
Vhs SP tapes
It sounds like the tapes may be physically damaged, wrinkled or creased. This may have been done when they were played in whatever machine you used 5 years ago. Tapes can also be damaged in storage by heat or humidity. Tapes should also be stored on end in their boxes, not flat. If these tapes were stored flat, the bottom edge might have gotten wrinkled. This can damage the control track and cause playback issues.
May 09, 2009 | Sony SLV-D380P DVD Player/VCR
My dvd players won't work
no. they should last longer. however electronics from walmart have been known to not hold up. i bought a 20 dollar dvd player from best buy like 4 or 5 years ago and it still works perfectly today.
Dec 04, 2008 | Durabrand DVD-1002 DVD Player
Region codes for Samsung R155 (UK)
hi give this ago works fine on us or uk
1. Press the Menu button on your remote control
2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the onscreen display
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested and Worked on my UK player (Region 2).
also works on r136 and r150
Oct 25, 2007 | Samsung DVD-R155
How to connect other dvd or HDMI player into dav-sc5 for amblification
If your alternate DVD player has digital audio out you can make this connection via the 'optical digital in' port on the rear of the unit which corresponds to the Video 2 function. I have done this myself because the inbuilt DVD function in the Sony unit is dead (fixed once under warranty, problem recurred about a year later, same issue as other unsolved posts on this board, DVD function hangs, system won't switch off, etc. common problem with this unit, crap product).
Oct 18, 2007 | Sony DAV-SC5 System
How to use av on a lg television
Did the dvd start, if so can this be a bad dvd player. It could need cleaning. Have you tried another device, like vcr or another dvd
Sep 13, 2007 | Televison & Video
Tray is not opening
To open the tray this is not a perfect fix, but it will allow to use it. After the unit is powered on: 1)Hit the "Open/Close" button 2)Wait a while (you will get the timing down with practice) 3)Tap gently, yet briskly with fingertips at area in the attached pic, that the red arrow points to I think the problem is that the tray becomes unbalanced somehow. Because when a DVD is in, the drive opens fine, only when there is no disc do you have to tap on the unit.
Aug 13, 2007 | Philips DVP642 DVD Player
My TFT display screen only shows white. (white, not blue)
Sounds to be defective. All white is not normal under any conditions.
Jan 01, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Screen is completely black
There is a switch on the right side of the unit labelled Video Out (switch facing front of unit) or TFT On (switch facing rear of unit). First make sure that the switch is on TFT on. If it is then switch to Video out and then back to TFT On. This made our screen starting displaying again when it was black.
Nov 19, 2006 | Durabrand DUR-1700 Portable DVD Player
Liquid Video MVBG619 Portable DVD Player Logo
190 people viewed this question
Top Liquid Video Televison & Video Experts
Electro Med Services...
Are you a Liquid Video Televison and Video Expert? Answer questions, earn points and help others
