I have a HP 852c printer and when I used it to print using my Photo Shop Elements program I need to change the print setup to 5 1/2 x 8 1/2 (half sheet) but that is not an option. How can I add this to the paper size options? Thank You
IB4G2008
  • 3587 Answers
SOURCE: Problem Priniting on a Non Standard Paper Format with IP5200
the issue here is whether your canon can handle that size of paper. is it running on the manual insert tray?
when you choose paper source, you'll need to identify where the paper is coming from..
try that..
of course, up to date drivers are here
Posted on Feb 28, 2008
  • 26 Answers
SOURCE: printing from iphoto - photos are not 4x6 and not borderless
wat pc do u have? are u using mac? if ur using microsoft try these:
go to ur printer and faxes - right click on ur hp printer icon - select preferences - select printer shortcut tab - select the appropriate size - the click ok. that should solve ur problem
Posted on Jun 11, 2008
venusPCgurl
  • 26 Answers
SOURCE: My HP Deskjet F2100 All-in-one
just leave your paper type as Plain Paper,
and if your printing out a 5R size photo or photo sizes not exceed on Letter size paper, just leave the paper sizes using Letter,
print on both sides set as OFF.
then just customize the printing quality for a good printing result.
then load or place your photo paper properly on the paper tray to avoid jam.
Posted on Aug 24, 2008
SOURCE: printer is not recognizing the new custom paper size
You also have to create a form the same size in "server properties".
Click on "printers and faxes"
Click on "file" top left of screen, choose "server properties"
Click on "create new form"
type in width and height of paper
(my HP printer will not recognize any paper less than 5' in height and less than 3" in width)
If your create a form less than 5" in height ' and/or less than 3" in width - chances are that's why your printer won't recognize new form. Height HAS to be at least 5" and width HAS to be at least 3"
type in name of new form
save form and close
It should now be in your printer paper options.
Posted on Mar 25, 2009
  • 6 Answers
SOURCE: printing a custom size card with a C7280,
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Posted on Jun 27, 2009
How do I print photos from my cd using hp Photosmart plus?
Don't Connect the printer. First use the cd to install the software for your printer. in the software is a program called print photos or print pictures. After installing the software, connect the printer and switch it on. Start the software and a menus should guide you trough he straps to choose and print the pictures you want to print. Be aware you need to setup things once the program is running, like how big the pictures should be. Don't make them bigger than the paper you insert. Also what kind of paper you use, like plane paper, or photo paper, matte or glossy.
Mar 20, 2015 | HP Photosmart Plus All In One Printer b210
Printing 11x14 photos
First use a photo processing programme (like say Photoshop or PS Elements - or if you have not got that (can be expensive) get the free Faststone Image Viewer and size the image to twice the paper size you want, then use the crop tool to select half the image and save that as a file with a name where you can find it again. Do the same with the other half. You will now have two files, each half of the paper size. As they will have small borders, print and trim the borders, so you can then mount side by side to achieve what you want. I would advise to NOT try and print without borders - that can introduce other problems - just accept having to trim the small borders from normal printing.
Apr 09, 2014 | Epson Stylus NX230 Small-in-One USB...
Prints only top half of photos on top half of
I suggest that you go into the printer properties section on control panel. There Will be a section which allows you to tell the printer the type of paper, size desired, orientation of photo to horizon and etc. There is also likely a selectable setup procedure on the printer's own display to do the same... It sounds like a basic setup format issue....
Apr 02, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My HP Photosmart D7360 only prints part of the photos from my Adobe Photoshop Elements 5 software? It will not print all of the photos. It prints about 1/4 to 1/2 of the photo and then the printer stops...
is it printing fine from other application if yes,
then just to inform you that there is a problem in printing from HP printer with OLD ADOBE VERSIONS which has been fixed in the new versions of ADOBE
Oct 15, 2009 | HP Photosmart D7360 All-In-One InkJet...
Bottom of line missing
First try and go to page setup under file and set your bottom and top margins to .25. is every bottom half line faded? If so then yes you might need a new ink cartridge.
Aug 12, 2009 | HP Deskjet 6980 InkJet Photo Printer
On HP K5400 printer the Left margin for #10
See an online manual with instructions to change the print settings here., then open the document program that has the addresses in it and use the print preview and page setup to adjust the margins for the printing to 1/4', if they'll go down that low.
Jul 10, 2009 | HP Officejet Pro K5400dtn Printer
My epson rx420 only prints the left hand side of any document ??? Can any one help please . many thanks
have you set the page setup in document is same with page setup at print setup. Some new epson printer use paper sensor to measure the paper width. If page setup wider than actually paper inserted, the printer will print only half page. example : Your document 10 cm wide, page setup 20 cm, and you insert 10 cm paper wide. It will print only half of 10 cm, 5 cm.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
Hp deskjet 940c printer
1.Setting DPI values
2. Follow one of these paths to select your print options, depending on the
software program you are using:
• Click File > Print, then select Properties
–or–
• Click File > Print Setup, then select Properties
–or–
• Click File > Print > Setup, then select Properties.
The printer properties box appears with Setup, Features, and Advanced
tab options.
3. Select the Setup tab, then choose the following:
• Print Quality: Best
• Paper Type: The appropriate photo paper type
• Photo Paper Printing:
- PhotoREt for best print speed and quality
–or–
- 2400 x 1200 dpi for source images greater than 600 dpi (requires
400 MB or more hard disk space and takes longer to print)
• Paper Size: Appropriate paper size
4. Select the Features tab, then choose the following:
• Orientation: Appropriate orientation
• Two-Sided Printing: Unchecked
• Copies: Up to 20
5. Select the Advanced tab if you wish to make optional adjustments to
color, ink volume, or ink drying time.
6. Click OK to return to the Print or Print Setup screen.
7. Click OK to print.
Apr 08, 2008 | HP DeskJet 940c InkJet Printer
PHOTO paper
The HP printer was prepared to use HP's photo paper to print borderless pictures among other things.
If you use a third party photo paper, try using A4 size, position the picture in the paper using MS Word or another WYSIWYG program and, after printing, cut the picture in the right size.
Dec 31, 2007 | HP PSC 950 All-In-One InkJet Printer
I'm getting really confused with the resolution stuff
The C4000 is a 4 megapixel camera and can produce photos that should produce very nice 8 x 10 photos. 11 x 14 prints may be pushing it a bit. Your cameras should be set for 2048 x 1536 and the .jpg compression should be set to "Super High". Better yet, that camera can produce TIFF format. For photos you plan to print, use the TIFF format. The other half of this process is the printer. Most inkjet printers have a number of settings. Make sure that it is set for photo paper and be sure to use glossy photo paper. If you can print a 8 x 10 print in less than a minute, your printer is not set right. If it seems like it is taking forever, it is set right. .................... Using Photoshop Elements 2: Open your photo into Elements. Click Image, Resize, Image Size Remove the checkmark from "Resample Image" Change resolution to 300. Notice that the width height is about 5 x 7 inches. So if you print that photo at 300 dpi (dots per inch), you will get an outstanding 5 x 7 print. Most inkjet printers produce their very best outputs at 300 dpi. At 200 dpi, the image is still quite good. When you get below 150, you will start to see changes in quality. Now set the Resolution to 200 dpi and notice that the output size has changed to about 8 x 10 inches. Now check to see how it will look on paper. click OK. Click File, Print Preview You can verify that the photo fits on the paper and that the paper is correct (horizontal/vertical). Now print the photo. The next window that opens should let you get to your printer properties and you can verify that you have the printer set for it best settings and that paper is set to photo paper.
Sep 06, 2005 | Olympus Camedia C-4000 Zoom Digital Camera
83 people viewed this question
jasbo
jasbo
