Question about Samsung Digimax S500 Digital Camera
Samsung Digimax 401 camera
The camera was working fine. I didn't use it for a couple months. The next time I tried to turn it on it wouldn't turn on or do anything. I put new batteries and it still wouldn't come on or work at all. Can you tell me what else I can try to do to get it to work?
    Novelist:
  • 70 Answers
Hi scraftcrazy,
Since you didn't use it for a long time, you are sure you didn't leave any batteries inside the camera for that long. If you did the batteries will most likely have leaked out inside the camera, and caused internal damage. One tell tale sign is that when you took out the old batteries it would be oily or the battery is bloateds. In light of this, I suggest that you clean the battery compartment out, most especially the metal connectors, since that can also be cause of not getting a power and the camera not working at all.
Did you also use HIGH CAPACITY ALKALINE BATTERIES (Energizer e2 or something similar to that) right? Try a different batteries. Since digital camera's require these types of batteries to even run. If you put regular batteries in there, it won't turn on the camera at all even if the batteries are new. If the camera also has a reset switch/button you can also try to do that. Most camera's have this kind of switch. So you may have to check the manual of your camera on this one. If you don't have one you can download it here: http://www.samsungcamera.com/customer/download/cus_down_main.asp?key=401
The only other thing I can think off is did the camera came with an AC adapter? If it does, try using that instead and see of the camera can turn on using it's AC adapter. If it does, it's possible there is damage in the battery compartment connectors.
Hope this helps!
Peace! :)
Posted on Oct 22, 2008
When I put a 4gig mmc into my samsung 401 digimax the green led light flashes repeatidly and i am un able to use any function. when on its own 16gig internal memory it works fine
If you look at the user manual you will see that it only has 16meg internal, not 16gig as you stated.
It says this: Internal memory:16MB flash memory
External memory: SD card /MMC (Up to 256MB guaranteed)
So it probably can't take a 4 gig card.
Jan 23, 2012 | Samsung Digimax 401 Digital Camera
I need to get an operator's manuel.
At the website www.samsungcamera.com site you can download the manual and the driver for the Samsung Digimax 401 and the Digimax 4010 which are the same camera.
To get there go to the site and click on SUPPORT then at the bottom of page select page number 9 or in SEARCH type in 401 which will take you to the Digimax 401. DON'T FORGET THE DIGIMAX MODELS 401 AND 4010 ARE THE SAME. I proved it since I compared my 4010 manual to the PDF for 401 and page per page identical. You will have to select a language for the manual and assume also for the camera driver. I found that the Samsung site was not user friendly when I first used it looking for the 4010 model which is not listed but the 401 is there.
Hope this helps.
Dec 14, 2010 | Samsung Digimax 4010 Digital Camera
Digimax 401 keeps saying batteries low
the camera tends to take up a lot of battery so what the best solution is to buy some rechargeable batteries those work great. i have some of those. and they tend to last a very long time!
Mar 02, 2009 | Samsung Digimax 4010 Digital Camera
Auto focus quit working
Did it get dropped when the camera was open? If so it could have made the lens pop out more on one side. I'm not sure how to really explain it. When you open the camera, the thing that comes out might be off track I guess you could say. What setting are you using it on?
Dec 21, 2008 | Samsung Digimax S730 Digital Camera
USB CABLE
You can get one from any computer or electronics shop.
Mar 16, 2008 | Samsung Digimax 401 Digital Camera
Samsung digimax 401
the maximum amount of memory for Samsung Digimax 401 (or 4010) is 512 Mb
Mar 08, 2008 | Samsung Digimax 4010 Digital Camera
Samsung Digimax A7 Digital Camera Problem
My camera will not turn on , it froze last month whilst the lens was out so i pushed it back in and it started to work fine this time it has forze or broke with the lens inside and it will not turn on the batteries are fine but i cant turn the camera on?
Nov 05, 2007 | Samsung Digimax A7 Digital Camera
Will not turn on
Comment by The Fixx, posted on Oct 31, 2007
And here is the solution... Eureka - we have found a cure. Internal memory of 16MB is shot. Buy a memory stick, insert and voila.... The camera is back too life. And apologies to Samsung....This is really an extrodinary little camera.
Aug 30, 2007 | Samsung Digimax 401 Digital Camera
Camera connection turns pc screen blue
A typical issue if the host PC's motherboard drivers were never installed. This and more at http://www.usbman.com Sadly, you didn't tell the make/model/chipset of the host PC so I can't comment further.
Sep 08, 2005 | Samsung Digimax 401 Digital Camera
Samsung Digimax S500 Digital Camera Logo
63 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
