Question about Dishwashers
My Whirlpool GU2300 just stopped working. None of the panel lights come on. I've checked the outlet and it is working fine.
  • rtalbot Feb 01, 2009
    I have the same problem with a different Whirlpool Model (Model # DU948).
    Sergeant:
  • 409 Answers
here a few things to check:
plug the unit into another outlet, if you still don't have power then
unplug the unit and check the connections to the circuit control board on the frontand the keypad, if okay then
check the door latch assembly and make sure that the switch is making contact, if okay then
you have a blown TCO fuse on the control board
i would recommend replacing the control board, since the fuse is saudered on the control board.
let me know if any of this helps.
Posted on Oct 11, 2008
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
Hey my rear lights have all of a suden stopped working are there a few things i can check myself to get them working again. the front ones are working fine and none of the back ones are but the bulbs seem...
Check your fuses (open the kick panel above accelerator pedal to access) If it's not a fuse you can get a test light for a few bucks at supercheap/repco etc.It has a needle which you push through the plastic coating on your wires to see if power is there.Try working backwards from there to check for broken wiring.
Feb 09, 2011 | 1996 Ford Contour
Control panel will not light up, the dishwasher was running and now it has stopped mid cycle and will not do anything. I just replaced the control panel (black plastic with buttons, not control...
I have a kitchenaid dishwasher model # KUDC10FXBL1 I went to start it and none of the buttons were working. I have checked the breaker and the wiring and everything seems to be in order.
Jan 13, 2011 | KitchenAid 34 in. KUDP01FLSS Stainless...
My Kenmore Calypso washing machine has is
Where the power cord goes into the washer is a small box called a line filter. It is there to protect the electronics in the control. It might be that the line voltage filter has failed. Remove the rear panel on the control to access it. Calypso Service Manual
Jul 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool GU2300 Dishwasher. The machine stops for long periods during the cycle. All lights go out. If the machine is opened before the cycle finishes, it will not resume. If I try to restart, the normal...
Hi
Door latch.
Open and close the door to make sure the door latch is securely fastened.
Check the dishwasher wiring for a possible loose connection where it connects to the house wiring.
Fuses or circuit breakers.
Check your house fuses or circuit breakers to make sure you have power to the dishwasher.
Thanks for contacting fixya.com
Oct 24, 2009 | Dishwashers
No power
Hi lushman001
I'm Harvey the Master Plunber.
Your question is: your 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
First check all the breakers (or fuses).
Second check the electrical connections. If you're not a qualified electrician or service tech then call one. It"s under the unit behind the kickplate.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
WHIRLPOOL QUITE PARTNER ii
there is a thermal fuse attached to the main control, check for continuity if none replace fuse.
Jul 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Replace the heating element of a whirlpool GU2300
I have a manual but will need to full model number,,
Jul 09, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
399 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
