Question about iLO 3200 32 in. LCD Television
Ilo 42 inch plasma
Picture cuts out after a few mins if i let it cool for 5 mins then turn it back on it's fine again for a few mins, i have found that it is when a ceramic piece in the back of t.v. on a circuit board gets hot it kicks out! can i get a new board or is that the problem & where pls help!
  • jay_linski Jan 10, 2009
    42" plasma works great for 10 min...then picture goes bad...shut it off and after a while it is ok again for about 10 minutes!!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Call for a fix ya technecian around you
Posted on Oct 11, 2008
  • olayoju victor Oct 11, 2008
    call for a fix ya technecian around you
42 inch samsung plasma comes on then picture go's out turn off and back on the picture comes back on and go back out after 30 min
It sounds that the Va / Vs voltages to panel has gone out of its range. Check these voltages. If you wish to get more details about these voltage settings, check this link.
Feb 05, 2013 | LG RU-42PX10 42 in. HD-Ready Plasma...
42 inch ilo tv black picture sound only
If the fuse burned out the the tv would not turn on at all. When the tv is on is the back light still on? If its not its probably the back light that needs changing. If its on then its one of the circuit boards.
Jun 02, 2009 | iLO LCT32HA36 Television
Plasma tv picture goes on and off but always has sound
I install a fan in the back, there is a only o9ne 5 v, 3,3 a that you can connect workin fine..
Mar 24, 2009 | Gateway GTW-P42M303 42 in. Plasma...
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
42 inch LG Plasma TV - Lost picture
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Sep 16, 2008 | LG 50PX1D 50 in. Plasma Television
ILO 42 IN PLASMA
most likely several capacitors are blown on a power vga board you could have a tech come out to see if he can replace them.
May 06, 2008 | iLO 3200 32 in. LCD Television
Gateway Plasma 42" TV
my 5 yr. old 50 inch plasma hd that i paid almost $7000 for started flashing for afew sec. when first turned on.progresivly got worse,flashed for about 30 min. then ok until turned off.after about a month power light comes on fans start then trips off. gateway phone 888 737 6949 wants $250 for power supply $330 for video?board $600 plus for other boards no guarantees.i fixed mine by spending $1000 for a new vizio 50 inch plasma hd.if anyone wants a free dead gateway email me,
archie
Mar 02, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Ilo 42" plasma tv model#pdp4210ea1
my 42" ilo plasma started going black on the outside to middle, now its totally black and no sound the power indicated lites for a min then the tv shuts off
Jan 10, 2008 | iLO 3200 32 in. LCD Television
No Signal after 30 Mins
Posted for a similar problem:
This is an issue with IC 803 on the Z board. This is a 3.3 V regulator that supplies this voltage to the slot card cage. Most input boards use this voltage EXCEPT the component board which is why it keeps playing along whike the DVI, HDMI, or composite signals will cut out after warm-up.
This is a surface mount multi-pin IC and is a bit tricky to replace.
The entire board is PN# TNPA3198xx with suffix determined by what model 7 series plasma you have.
This was a problem from around Nov. 2004 to Mar. 2005
T Wiz
Sep 22, 2007 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
I have suddenly lost the picture on T.V. but still hear audio of program...
sounds like your input board went out. I had the same problem on the ILO version of this panel. Got a replacement part off of Ebay. Search for Ilo plasma on ebay and it will come up
Sep 08, 2007 | Tatung P42BSKT 42 in. HD-Ready Plasma...
iLO 3200 32 in. LCD Television Logo
78 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
