Question about Pioneer Audio Players & Recorders
I have a Stereo Double Cassette Deck; Pioneer CT-W404R. I've set the REV MODE switch; I've pressed the record button; I press playback and the tape for recording begins moving, but not the other tape. If I push any buttons on the left, everything on the right side shuts off. What am I doing wrong?
I was following instructions for "Recording." On the next page were instructions for "Tape Copying," though the first page began with, "Load a tape for recording in Deck II." That sounded like what I wanted. Anyway, that was my error.
Posted on Oct 12, 2008
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
Pioneer CT-W208r won't eject tape.
These dual cassette decks were throw away units in most cases. The belt inside and the grease in the cam mechanism is in bad shape and the deck can not cycle through the steps it need to so as to reach stop. Only stop mode will allow the door block to release. The tape can safely be extracted by a Technician. The deck need work. Dual cassette decks are not always worn the repair cost.
Dec 23, 2013 | Pioneer CT-W208R Single Cassette Deck
Pioneer CT-W350R Double Cassette Deck will not playback.
Might need belts and a good cleaning.Rotation sensor not detecting reel table rotation. It is doing what it is suppose to do when at the end of the tape but you tape may not be at the end.
Nov 20, 2012 | Audio Players & Recorders
Where can I buy Pioneer CT-W701R Stereo Double Cassette Tape Deck Riemen Belt
If the methods listed in the manual won't open the door, then the tape is not inserted properly. Insert a golf tee in one of the two small holes below the tape door and slightly adjust the position of the tape up, down, or sideways. Then press the eject button and it should open. This will only work if the belt is OK.
Apr 26, 2012 | Pioneer Audio Players & Recorders
Pioneer Stereo double cassette deck Ct-W302R - is it repairable?
They might be repairable but usually at a cost that exceeds it value. Who wants to pay $150 to fix what was known as a throw away tape deck? Not many. It might even exceed $150 as they are complicated to repair bot being designed to be repaired.
Mar 22, 2012 | Pioneer Audio Players & Recorders
Hello What is the difference between the recording NR switch b/off/ c
If you record a track with NR (standing for Noise Reduction) on it will sound brighter than with it off. The B and C sounds like it's Dolby B and Dolby C type noise reduction. C is better than B, but it's up to you to decide which you like best. Both systems were developed to deal with the problem of tape hiss. Most commercial tapes use Dolby B. If you record with either Dolby on it is best to play it back with it on, as it can make the tape sound more hissy, switched off. But if you don't record with it on, then putting Dolby on to playback would make it sound dull.
Sep 24, 2010 | Pioneer CT-W404R Single Cassette Deck
I need a complet set of belts for my Pioneer CT-W103 Double Cassette Deck.
Just measure the diameter of each belt (in mm) and then search with Google. Belts are generally not maker specfic.
Aug 15, 2010 | Pioneer CT-W103 Single Cassette Deck
Forgot how to record (dual) tape to tape (been a while)......can not remember sequence of buttons to press or if i need to press buttons at the same time (i.e. Trying to record 1 cassette tape to another...
The left side is usually the playback deck and the right side is the record deck.put in a tape on the left side and push play.Then push the record button first and while holding it down ,the play button on the right side deck.One deck will not have record buttons on it,and that is the playback deck.
Jul 09, 2010 | Audio Players & Recorders
CT-W602R Dual Cassette Deck- door won't open
Dear etu7diante,
The another way to release the cassette from the deck is by moving the flywheel manualy after opening the cover of the system. The system should be disconnected from the power supply. If you are able to to do this please let me know .later I can guide you to do the job.
ramesh22
Jun 09, 2008 | Audio Players & Recorders
Problem with deck B on Pioneer CT-W205R
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
Dec 20, 2007 | Pioneer CT-W205R Single Dual Cassette Deck
104 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
