Question about Canon DC210 DVD Camcorder
Cant finalise a canon dv 210 disk in a VR mode.
Why. but it can finalise the disc in a video mode.
It should finalise in both the modes.
Posted on Oct 18, 2008
How do I finalize the mini-disc in my Canon DC201 camcorder?
to finalize dvd you have to do it or on camcorder or DVD RECORDER. find someone that have and you will be able to do it. good luck
Sep 28, 2009 | Canon DC210 DVD Camcorder
Finalising discs with canon camcorder
I do know that to finalize discs, you need to have your camera plugged in to a wall outlet, according to the owner's manual.
Jun 07, 2009 | Canon DC210 DVD Camcorder
Recorded DVD will not play in another player
Hey,
Maybe the format of your recorded movie didnt support your player..check out your manual for the supported formats and check the format of your recorded movie.If any of the format in the manual matches your movie format then it will definitely play..
please rate my suggestion..
Apr 15, 2009 | Televison & Video
Format a cd
First some explanations:
The Canon DC210 will only take 'minus' format DVDs (DVD-R, DVD-R DL and DVD-RW). Only the DVD-RW must be formatted (initialised) before use. During initialisation you'' be asked whether you want to initialise the disc in VIDO mode or in VR mode.
VIDEO mode: Once finalised discs recorded in VIDEO mode can be played back in most common DVD players, offering the best compatibility. However, recordings cannot be edited (deleted, rearranged etc) on the camcorder.
VR mode: You can easily edit the recordings on the camcorder. However, discs recorded in VR mode can only be played back with DVD players that are compatible with DVD-RW discs in VR mode.
My preference is Video mode - I can then play the disc on a DVD player and edit it on a PC.
Now, to initialise a DVD-RW
1. Press the 'FUNC.' key
2. Use the joystick to select 'MENU' - it's in the bottom left corner of the screen
3. Use the joystick to select 'DISC OPERATIONS'
4. Use the joystick to select 'DISC INITIALIZE'
5. Use the joystick to select either 'VIDEO' or 'VR' mode
6. Use the joystick to select 'YES' to confirm your choice
7. Use the joystick to select 'YES' to start initialising the disc
Close the menu only after the screen display returns to the 'DISC OPERATIONS' menu.
Don't forget to rate this solution once you've tried it !
May 11, 2008 | Canon DC210 DVD Camcorder
Samsung dvd recorder
Make sure you have finalised the disk, otherwise it won't play back on other players. Also there are two standards that you can use to record onto disks, video mode or VR mode. Video mode was the original standard but it wouldn't let you edit or add anything to the recording afterwards but it is more compatible with other players. VR mode allows you to edit the recording but is less compatible for playback on other players.
Mar 28, 2008 | Televison & Video
Will not play on computer
Before you can transfer pictures or video from your Canon DC210 to your PC you need to finalise the disc in the camcorder.
You also need to make sure that the DVD drive on your PC is capable of reading a DVD-R, DVD-R DL or DVD-RW format as these are the only disk formats that the DC210 will handle. Not all PC DVD drives can read these formats.
To finalise the disk you must have the power adapter connected to the camera, plugged into a wall socket and turned on. Then, switch on the camera, put it into playback mode, Press 'Func.', select main menu, select 'disk operations', select 'finalise'. Don't move or shake the camera or switch it off whilst the finalising step is underway - this could cause problems.
Once finalising is complete, put the disk into the PC.
Good Luck.
Mar 25, 2008 | Canon DC210 DVD Camcorder
Transfering from canon dc210 to my pc
Good Luck.
Mar 19, 2008 | Canon DC210 DVD Camcorder
Cant transfer footage from Canon DC201 onto computer (and eventually internet) Do I need specialist software to take video from DVD to computer?
You don't need specialist software to take video from DVD to computer.
One of two things has gone wrong
1. Your PC cannot read the -R DVD format, or, more likely
2. You have not finalised the disk.
You must finalise the disk in the camcorder before putting it in the PC. To finalise the disk you must have the power adapter connected to the camera, plugged into a wall socket and turned on. Then go to the main menu, select 'disk operations' and you'll see an option to finalise disk. Don't move or shake the camera whilst the finalising step is underway.
Mar 09, 2008 | Canon DC210 DVD Camcorder
Mini dvd playback
Two problems here.
To JOA629 - You may possibly have initialised the disc in VR mode by mistake. VR mode discs will not play on a PC. Are you re-initialising the disc between when it works and when it doesn't ? If you're using VIDEO mode, are you finalising the disc on the camcorder before using it on the PC ?
To dewynn729 - you have intialised the disc in VR mode, which is a newer format than VIDEO mode. VR mode discs will produce .VRO file extension. Record your video on a disc initialised in VIDEO mode, finalise the disc on the camcorder (don't forget to plug the camcorder into the power adapter, and switch both on), then read the disc on a PC.
Dec 28, 2007 | Canon DC210 DVD Camcorder
Unable to finalise
For some reason one of the discs that i have recorded on will not let me finalise. When i put the disc in it says recording disabled and then i go to the finalise menu and the finalise selection is unhighlighted. How can i fix this so i can finalise the disc and use it on my computer?
thanks
Oct 28, 2007 | Sony DCR-DVD602E DVD Camcorder
Canon DC210 DVD Camcorder Logo
204 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
