Question about JVC RX-6500V Receiver
Jvc 6500v no sub signal on soround sound
When my amp is on pro logic or soround sound the sub is on but dose not get a signal but it dose come on when soround sound is off to just 2 channel and sub
Hi, I had the same issue but if you change the front spk and center spk settings to "small" rather than large, the lower frequency is sent to the sub instead
Posted on Oct 03, 2009
I have a Yamaha HTR 5960 receiver hooked up to a Klipsch 10" synergy sub. The system has been set up for about 6 years and the sub suddenly quit working. I have checked connections and the sub is getting...
If you remove the signal cable from the amplifier while the Sub is switched on (turned down about half way) you should hear a thump sound. If you do that proves that your sub is working and you need to look at your Yamaha. Perhaps the sub channel has been disabled in the logic settings. Check the speaker configuration pages. If all looks well reset your amp to factory settings and try again. I have had a logic glitch which was fixed in this way.
Nov 23, 2013 | Audio Players & Recorders
Jvc kw avx820 no sound
Check the speaker connections it looks like there may be a feedback signal going back to the internal amp. If those are fine then the amp itself is clipping and you need to have the player checked.
Apr 03, 2012 | JVC KW AVX820 Car Video Player
How do I get the C5 Subwoofer to activate?
Hello
If subwoofer is inactive now, the sound preference settings you set now is wrong.
Before using the remote control for the following
operation
* Set the remote control mode selector to AUDIO
** There are exceptions in the operation mentioned
above. In such a case, follow each instruction
Dolby Pro Logic II*1
# Dolby Pro Logic II has a newly developed multichannel playback
format to decode all 2 channel sources - stereo source and Dolby
Surround encoded source - into a 5.1 channel.
Dolby Pro Logic II has two modes - Movie mode and Music
mode
# Pro Logic II Movie (MOVIE)
Suitable for reproduction of Dolby Surround encoded sources
# Pro Logic II Music (MUSIC)
Suitable for reproduction of any 2 channel stereo music sources
# Dolby Digital*1
Used to reproduce multichannel soundtracks of the software
encoded with Dolby Digital
# DTS Digital Surround*2
encoded with DTS Digital Surround. DTS Digital Surround (DTS) is another discrete multichannel
digital audio format available on CD and DVD software
Jun 19, 2011 | JVC TH-C5 System
We hooked it up and have no sound
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console for a widescreen, high-definition TV, determine your audio options, and check your console's serial number and Xbox Dashboard version.
Go to correct section for ... Audio
Change your audio output settings for games from this screen. These audio settings do not affect DVD movie playback. For DVD audio settings, refer to an individual DVD movie's setup screen.
Settings consist of:
  • Analog Output Settings: choose Mono to merge the left and right audio signals so that you can hear all sound through a connection to a monaural TV or monitor; choose Dolby Pro Logic II to listen in normal stereo (no audio surround receiver required) or to listen to Dolby Pro Logic or Dolby Pro Logic II soundtracks from compatible games or other media.
    Dolby Pro Logic consists of four channels of audio: front left/center/right and a monaural surround channel that is mirrored in each of your rear left/right speakers. Dolby Pro Logic II uses digital signal processing to generate 5.0 audio (front left/center/right, rear left/right) from any stereo (left/right) programming, whether from movies, music, or games. Unlike movies and music, however, games are specially encoded with Dolby Pro Logic II decoding in mind.
    To listen in either Dolby Pro Logic or Dolby Pro Logic II surround sound, you must connect your cable's left/right (white/red) RCA connectors to a compatible surround receiver. For more information, see our connection page for the cable you're using:
  • Digital Output Settings: configure this setting only if you'll be using the Toslink optical digital-audio output from a compatible Xbox 360 AV cable (optical digital-audio cable sold separately):
    The default digital-audio setting is Dolby Digital 5.1. If this is your preference, you do not have to make a selection from this screen.
May 13, 2011 | Microsoft Xbox 360 Console
Can i plug a 5.1 pro logic amp into the back of my tv?
Your TV should have Audio Out connections on the back. Normally these connections are the RCA type of connection. You can connect the Audio Out from the TV to the TV In jack on the Pro Logic amp. If you are watching either a cable or satellite receiver, or a DVD player, that equipment can also be connected to the Pro Logic amp. Depending on the type of amp you have there may be enough connections to have all of your equipment connected at the same time. If possible, it is better to take the signal straight from the source rather than letting it go through the TV first. Some of the Dolby Pro Logic encoding information can be lost traveling through the TV circuitry.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 19, 2011 | Televison & Video
Kenwood 107VR rec and No vol from Sub Output w/ menu Opt On
In the setup menu are the speakers set to large or small? On some receivers if you have it set to large all the bass is directed to the right-left fronts.
On my pioneer receiver if the speakers are set to large the sub-pre-out only works if the receiver is in a surround mode, if its in stereo mode and the speakers are set to large the sub-pre-out is dead. If the speakers are set to small the sub-pre-out works all the time.
Also, some receivers won't send a signal to the sub-pre-out if there is no LFE discreet signal info from the dolby digital or dts bitstreem.
For example I have several older dvd's that light up the L C R SL SR icons on my receiver, but don't light up the LFE icon. I have other older dvd's that just light up the L and R icons meaning they are only recorded in stereo like a vhs tape recorded in dolby surround.
In my basement I also have a kenwood dolby digital receiver.
I've noticed that when a dvd only lights up the left and right icons the pioneer will automatically switch to dolby pro logic surround. The kenwood will only send the signal to the left and right fronts (stereo). If I manually switch it (kenwood) to dolby pro logic I'll get sound from all the speakers just like the pioneer, but it does'nt do it by itself.
Most receivers that have a tape monitor won't work in surround mode with the tape monitor on. The pioneer will let me use the tape monitor with dolby pro-logic but won't pass through a dolby digital signal with the monitor on.
Hope this helps.
Apr 18, 2010 | Kenwood 107VR
My jvc ax6300 amp is wired in and the protection light is on. no sound from the subs?
Try to rest amp (turn off power) be sure subs are disconnected. Se if protection light comes on. If it does the amp needs to be serviced porbably a burnt component. If the protection light does not come on, connect one sub at a time to see if either one surges. Could also be that the gain is turned up too much.
Nov 06, 2009 | JVC KS-AX6300 Car Audio Amplifier
When i go to surround mode right front channel drops out
check for connection, might be the front right speaker was connected to right rear soround out, check recording if dolby pro logic or DTS system
Aug 31, 2009 | Denon AVR-3600
No signal from sub connected to NAD T760 in test mode.
Try using front pre out to the sub from the receiver. the crossover is in the sub anyway. If this works change your settings on the receiver and test again. If sub is still inop, could be an internal issue with the sub amp. Does your sub amp have an on/auto/off switch or light? check that as well. Hope this helps, if you need further assistance, send a reply and I'll help some more
May 24, 2009 | NAD T760
No Subwoofer sound with pro logic on TXSR503
When you are playing cd,s set your amp to stereo and the sub should work,prologic should never be used for playing music as this destorys the sound stage,if you are useing small speakers make sure you have set the size in the setup menu and the cross over to about 80hertz.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | Onkyo TX-SR503 Receiver
JVC RX-6500V Receiver Logo
124 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
