Question about Karcher 2500 PSI Pressure Washer
Briggs 6.75hp Will Not Start and it's Brand New!
Your question was
I bought a brand new troy-built pressure washer with a 6.75 Briggs on it from Lowe's today and they sold it as is (They couldn't get it started as well). I checked the spark plug and I have good spark. I have new gas in it, a new filter, and when I try to crank it, the plug is wet with gas. The only thing that I can see wrong with it is it doesn't seem to have very high compression. I didn't put a compression gauge on it, but I can put my finger over the spark plug hole and pull the recoil rope and it just doesn't feel like other motors. I pulled the flywheel off and checked the shaft key and it looks new too. I did pull the valve access cover off to double check the valves and they look like they are opening and closing and seating like they should.
If I pour gas into the carb, nothing happens. If I pour gas in the spark plug hole, I can get it to pop but that's it, it will not fire off.
Is there leaking on hthe head? (wet?) Can you see or smell gas there? = gasket. Is there gas in the oil? Pull the dipstick and smell it...might even be really thin. = piston or rings. Pull the plug and see if you can get a view of the piston when it's Top Dead Center. If it's scarred or eaten (deep pits) then the piston is probably bad and needs to be opened up any way. Some people try to put "Special" plugs and if they are too hot it could burn a hole right thru the aluminum. Also Plug could have had too long a shaft and hit the piston,
Good Luck.
Han G Thesobs
Posted on May 07, 2009
  • 239 Answers
You need a new had gasket or a new piston
Posted on Dec 28, 2008
  • Alvaro Domingues
    Alvaro Domingues Jan 07, 2009
    did i help you ? please rate!!
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
My Troy built 2700 power washer won't start. it's been 8-10 months since I used it last. I bought it 2 years ago.
99% of the time is the fuel that has unstabled in your carburetor you can try to clean it but replacing would be recommended.
Aug 05, 2013 | Briggs Stratton 198347gs Pump Assembly Kit...
What is average going price for a new or used wobble pump for a Campbell Hausfeld PW2200V1LE. My 6.0 Briggs & Straton engine is in very good condition Reason I ask is a brand new pressure washer in my...
keep the briggs if your just gonna use it for yourself get the sjv axial pump 239.00 put it on your briggs.many retail stores use s disposable pump no sightglass or drainplug sjv has forged brass head no pot metal.
Jul 30, 2013 | Campbell Hausfeld Garden
Briggs and Stratton pressure washer will not start. I have a 6.75 hp pressure washer that is only a year old. when I pull cord it turns over but does not start. I changed plug and checked it, I have spark...
hello dave, the problem is compression to low,you need 60 to 130 lbs to run engine,check for blown head gasket,or bad rings,or a stuck open valve,hope this helps,,
Feb 22, 2012 | Briggs & Stratton Garden
Troy Bilt Pressure Washer Model 01902 Leaking Gas from Air Filter
try banging lightly on carberator with block of wood or something to free up float and valve!!!!
Jul 01, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Power washer will not draft
craftsman 2000 psi, model 020211, starts up and runs good just lost pressure?
Jun 09, 2009 | Briggs & Stratton Gas Pressure Washer...
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Just bought a new Briggs Stratton 6 75 pressure washer. i put in a half a tank of gas in the tank and it started up. i ran the pressure washer until it was out of gas. put more gas in now it will not...
assuming you tried choking it when you tried to start it, verifiy its getting gas,if not tap lightly on the bowl of carburator. if it is getting gas, check for spark
May 02, 2009 | Briggs Stratton 020273 Elite Series...
Karcher 2500 PSI Pressure Washer Logo
248 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
