I droped my compaq nx9010,the dc power jack came out, how do i put it back ?
    Genius:
  • 1,605 Answers
You mean the plug or the Receptacle.
Posted on Oct 11, 2008
    Sergeant:
    Champion:
  • 334 Answers
Solder it back in buy new ac ******** ebay tuff job take it all aprt to mobo
Compaq CQ1-1225 AIO Wont Start at all. Removed all components
Suggestions;
Anti-Static wrist strap connected to ground source, and your wrist;
1) The jack your AC adapter plugs into on the motherboard, is the DC Power Jack.
Motherboard out of case, power to motherboard, take your multimeter and see if you are getting 19 VDC at the DC Power Jack's positive solder joint, on motherboard.
The center pin of the jack is Positive. (The inner cylindrical shell is Negative)
Follow the DC Power Jack's positive pin from the Center of the jack, to the motherboard.
You probably won't be able to touch your meter's Positive (Red) probe, to the DC Power Jack's positive pin under the jack; so touch it's solder joint on the opposite side of the motherboard.
(DC Power Jack should be soldered close to the motherboard, is why)
Of course also touch the Negative lead, (Black probe), of your meter, to the Negative, (Ground) solder joint for the DC Power Jack.
Getting 19 volts DC?
See if there is a cracked solder joint, for any of the DC Power Jack's pin connections to the motherboard.
ANY perceptible movement of the DC Power Jack on the motherboard, indicates a bad power jack, and may indicate a broken/cracked solder joint.
Center pin of DC Power Jack is loose? Bad DC Power Jack. Replace.
2) DC Power Jack is determined to be in good repair? No cracked/broken solder joints?
The next components in the power circuit on the motherboard, leading From the power jack, are P. MOSFET's.
Power MOSFET.
Power MOSFET Wikipedia the free encyclopedia
More information using a prior solution,
Dv6000 power light does not come on any more
Check the links given.
3) The last thing that concerns me, although I probably should have listed it first; is the AC adapter you are using.
Concern is that it doesn't have the 'intelligent chipset' that matches the Compaq CQ1-1225 All-In-One desktop PC's circuitry.
AC Adapter For Compaq Presario All in One CQ1 1225 Desktop PC Charger...
Just my thoughts..........
Regards,
joecoolvette
Jan 15, 2015 | HP Computers & Internet
Which ac do when a laptop compaq nc6400 is verr slow and doesnt charge the battery
What does the AC do? (Alternating Current)
Apparently not get rectified into DC electricity by the AC adapter, (Charger), or the rectified AC (Which is now DC), is not getting to the laptop.
Be sure the Battery is still good. They have a lifespan, and only last so long.
Verify, by performing a DC Voltage test with a multimeter, if the AC adapter is putting out the correct Voltage.
If it is an AC adapter for an HP Compaq NC6400 Notebook PC, the DC Voltage coming out of the AC adapter is supposed to be
18.5 Volts. (DC),
http://www.amazon.com/Notebook-Adapter-Presario-cq50-142us-cq50-110/dp/B001MQ4MNW
On the AC adapter plug going to the laptop, the center pin is the Positive connection.
The outer cylindrical metal shell is the Negative connection.
AC adapter puts out 18.5 Volts?
Have an assistant;
1) Gently wiggle the power cord coming TO the AC adapter.
2) Gently wiggle the cable coming FROM the AC adapter TO the laptop.
See if you get an intermittent reading on the multimeter. Indicates a broken wire.
[ An economical, but fine for this test, multimeter, can be purchased for as little as $8 to $12, here in the US.
Analog or digital is fine.
Available in a multitude of stores. An auto parts store is but one example ]
AC adapter checks out it's on to the DC Power Jack.
This jack is the round port on the laptop, that the plug from the AC adapter plugs into.
Battery removed use a wooden small object, and gently see if you can move the center pin around, for the DC Power Jack.
See if the rest of the DC Power Jack will move around.
ANY perceptible movement means a problem with the DC Power Jack.
The DC Power Jack looks like this not mounted to the motherboard,
http://www.batterystyle.com/compaq-nc6400-jack-p-436629.html
Click on the two views shown of the DC Power Jack.
The view on the left shows the jack from the back.
The view on the right shows the jack from the front. The view you see now.
Note that in both views the jack is shown upside down, in relation to how it actually sits on the motherboard.
The view on the left, (Back view), shows Prongs coming from the jack, that go down through the motherboard, and are then soldered.
The gold colored prong is the Positive prong. It goes to the Center Pin of the jack.
All of the silvery colored Prongs are for Ground, or Negative.
Where the Prongs are soldered to the motherboard, are called solder joints. Each prong has a solder joint.
It may just be that one, or more solder joints are cracked.
This would require disassembling the laptop down to the bare motherboard in your hand, then re -soldering any cracked solder joints.
[ Be SURE to use an ESD wrist strap, and have it's alligator clip connected to a good ground source, BEFORE working inside a laptop ]
It may be however that the DC Power Jack is damaged, and replacement is necessary.
HP Support > HP Compaq NC6400 Notebook PC > Manuals page,
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=1847703
On this page click on - Service and maintenance information
(Under the - Quick jump to manuals by category - heading)
Under the bold - Service and maintenance information - heading, click on -
HP Compaq NC6400 Notebook PC Maintenance and Service Guide
(24 Apr 2007 / 4.61MB )
[ This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name, it may take up to 30 seconds, before the first page comes up ]
Need guidance in de-soldering, and removing the old DC Power Jack, and soldering in a new one?
Post in a Comment.
If the DC Power Jack checks out, you have a bad power correcting chipset. This is a type of Power MOSFET.
Motherboard replacement is the solution.
Regards,
joecoolvette
Apr 25, 2012 | HP Compaq nc6400 Notebook
My M2000 will not power up, have new battery and charger but still no power.
The DC jack in the laptop is often source of trouble, but the computer must be dismantled down to the motherboard level, at this point I recommend a professional to assess the repair cost.
Apr 08, 2012 | Compaq Presario M2000 Notebook
My HP Compaq 5325 suddenly went off and now won't power up. No lights showing at all. Removed battery, plugged in mains but still the same - no lights. Can anyone suggest what it might be? thanks
The problem may be the DC jack in the laptop or a bad power supply. If you can confirm the power adapter is okay by testing or subbing another power unit then I will assume it is okay and go to the next step. Plug your supply into the laptop, now put your hand on the DC plug and apply pressure sideways with the thumb "not to hard" at the same time press the power switch repeatedly to see if it will start, if yes! the DC jack needs to be resold-ed back on the motherboard or replaced. If still no change this is where a computer technician will be needed to go further.
Jan 12, 2011 | HP Compaq nx6325 Notebook
DC Power jack heats up to very hot to touch on HP NX9010 laptop.
The DC jack, where you plug the power adapter cable, might be loose or defective, & needs to be either re-soldered or replaced.
In order to do this, the laptop needs to be disassembled & the motherboard taken out. Also, the motherboard needs to be checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 09, 2010 | HP NX9010 Notebook
Power connection loose
There might be the issue with DC in cable jack so need to get it checked through a software vendor.
Thanks
Apr 08, 2010 | HP NX9010 Notebook
My hp compaq nx9010 wont power up. dc supply is good and the batteries are ok. No led light...
This is a typical symptom of motherboard failure. Your laptop's motherboard will need to either be serviced or replaced.
Feb 16, 2010 | HP Compaq Business Notebook NX9010
Has no power
check your DC Jack on the back where electricity is plugged in to the laptop-
Maybe a bad connection.
With Thumb- push the jack to the left and press power button. If this doesn't work, Also try pushing to right, and trying the power button. If you get lights, or it powers on that verifies that you have a DC jack issue.
Do not attempt to use by holding it or using duct tape, get it repaired. If you attempt to use by holding or taping you will further damage the contacts around the jack internally and render the motherboard unrepairable-requiring replacement. This is only a test verification method.
The cost of DC Jack repair/reflow is $50- 100 depending on your area/region.
Try local first before mailing off your laptop!
Mar 22, 2008 | HP Compaq Business Notebook NX9010
Presario 2500 hp
just google Compaq Presario NX9010 replacement DC Jack
Jan 22, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Compaq presario speaker hook ups
a brand new HP 360 comes with no manual $1000 in a box.
fact.
that is because its at HP for free , you are not at HP but at fixya.
why be here? we are NOT HP.
the manuals are all there, one model might have like 30 manuals.
depends on what you are doing, they even covery up to 8 windows versions used, not in 1 manual but 8. (or 4)
speakers 101:
so KBL: are those external speakers? you never said that.
what is your service tag full model number it is not 2500
i get no hits at REAL HP for that number.
ZE 5000 NX9010 Series???? how can it be both #?????
hp has like 10,000 models of PC for 35 years
we can NOT GUESS them ever here, the service tag must be presented by you or all answers will be wrong.
for sure.
the speaker jacks on PC can be 2 channel, 3.1. 5.1, 7.1 and up.
we have no idea what you have there, at all. period
I get 1 hit, NX9010 at HP.
so if that is the model prefix (missing P/n on tag shown)
do know this that one model like this can have 5 different motherboards used, even for sound.
some have low end sound chips other higher end. more jacks.
seen. no photos for your jacks by you pressented.
so connect the speakers to the green jack.
speakers out. 2 channels.
this Laptop NX9010 came with zero external speakers
so you previous owner added them.
no JBL part numbers stated of the 1000s made.
the nx9010 front most 3.5mm phone jack is green
and is for head phones,
to use speakers they must be amlified speaker
you buy those and it has 2 speakers, a cross jumper from one to the other, and from the main speaker (has volume knob)
there is one cable from it to the PC green jack 3.5mm
then the main speaker needs its power pack connected with power on, this turns on the magic Amplifier inside.
this makes the speaker work on any pace made from 1990s to now.today.
off the green jack only.
then set the speaker to 1/2 volume
and then at the PC raise volume till happy.
that is it for 2 channel technology audio.
some PC have more fancy setup.
but here is your book free to read for 14 years
most of this PC are dead now, the CFFL lamps long ago burned out and screen dead forever.
read page 50.
http://h10032.www1.hp.com/ctg/Manual/c01122401
all the other books this pC are here. every one.
https://support.hp.com/us-en/product/hp-compaq-nx9010-notebook-pc/321850/manuals
Nov 22, 2017 | HP Compaq Presario 2500 HP Pavilion ZE...
Computers & Internet Logo
David Payne
David Payne
