Question about Estate TEDX640JQ Electric Dryer
Dryer when dryer is turned on the drum thumps sometimes loud and sometimes lower
  • 943 Answers
HI thanks for your question. the noise you hear , is worn drum rollers or back bearings and front bearings. if you need more assistance get back to me .
Posted on Oct 11, 2008
What is making mywhirlpool/admiral electric dryer sound loud and thumping noise
You dryer belt may be shot and a piece of rubber is missing making it jump while working. Needs replacing before it completely quits. It will eventually just break apart.
Apr 13, 2015 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
How do i take apart the my dryer
Sounds like a drum roller bearing. When they go bad they form a flat spot and that against the drum will give a loud thump. Turn the drum by hand and you should feel the flat spot. You may have to remove the back panel to get a good look see and a repair access. Good luck.
Jul 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Loud thumping as drum turns. NOT and
felt bearing gone ...followed by grinding,,possible marks on clothes..
Apr 07, 2010 | Frigidaire GLER642A Electric Dryer
Belt and drum turns but with a thumping sound.
check the idler pulley, it could be broken. Also check the inner side of the belt for a chunk missing.
Oct 03, 2009 | Maytag Dryers
New dryer makes a loud thumping full or
I hope he did nt charge you. Because of the seam in a dryer drum, they do make a slight thumping noise but it should not be real loud. I hope the tech took the dryer apart and checked the rollers. One of them may have a flat spot.
I would ask for a factory represent ive to come out and see if they think they would want a dryer in there home that make that much noise.
Please rate solution
Sep 03, 2009 | Dryers
Loud thumping noise in Frigidaire model # FDE336RES2
You have to remove the top lid. Then remove the front panel. Then remove the belt and drum.
Your problem is a bad rear drum support assembly.
Remember to unplug the dryer.
Mar 27, 2009 | Frigidaire FGR341AC Electric Dryer
Loud thumping noise
IT COULD BE THE DRUM BUT I WOULD INSPECT THE DRUM ROLLERS TO SEE IF ONE HAS A FLAT SPOT IN IT. IT MIGHT NOT HURT TO CHECK THE DRUM BAFFLES/PADDLES TO MAKE SURE THEY ARE TIGHT.
Jan 27, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Loud thumping sound
It's probably time for new drum support rollers. There are two rollers the drum rides on and their bearings can fail, which makes them noisy and also makes the drum wobbly while it turns. Replacing the rollers isn't difficult, and you can do it yourself if you feel comfortable working with hand tools and are patient.
Here's a good site with information on belt replacement and other repair tips, and a source for parts:
http://repair2000.com/wpoolbelt.htm
Nov 26, 2008 | Kenmore 63942 Dryer
Loud Thump each time the Drum Rotates
You have a problem with your dryer drum.  The seam weld has cracked and the drum needs to be replaced.  You will need to call a qualified LG technician to resolve this issue.
Apr 15, 2008 | LG DLE2532W Electric Dryer
Estate TEDX640JQ Electric Dryer Logo
60 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
