Question about Thermador Kitchen Ranges
F24 error code on Thermador SEC 272 double wall oven
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: GE Wall Oven - error code F1
According to GE, the F1 fault code indicates a problem with the Electronic Range Control (ERC) Board. If the fault cannot be cleared, they recommend replacing the ERC and the touchpad. Has your repair guy tried any of these ideas? Post back with your comments, please.
Posted on Jan 17, 2008
Master_Tech
  • 770 Answers
SOURCE: f7 error
F7= function key is stuck or shorted >> you can turn the breaker off to the unit then back on if it come back up it will have to be replaced
Posted on Jan 27, 2008
SOURCE: f24 error code
Take off the lower panel of your washer and under this panel on the back of panel is a book which tells you what the error codes are and how to fix them or test for them. It looks like a tempature sensor code to me.
Posted on Apr 19, 2008
SOURCE: F24 Error code and incessant beeping
Being a software developer I guessed that the keyboard (the touch pad) was bad, because in my case one of the keys (the Top Oven OFF key) did not beep or work. So I went on the Thermador website and found the touchpad on the schematic. I ordered one yesterday from a firm called Mar-Cone in St. Louis, and it arrived today. It is a very easy replacement, and takes about 10 minutes. Happily it was a good guess, and it works fine. For the 27" SEC272BS/01 (stainless) the part # is 474083, and cost $189.20. They will express ship for $25.
Phew, we have 20 people coming for dinner on Thursday.
I'll be happy to let anyone know how to change the panel.
Posted on Nov 25, 2008
jumptrout51
  • 3361 Answers
SOURCE: we are buying a new double oven and cooktop, do
All 3 are top notch.
Posted on Aug 02, 2009
I'm getting a f24 code on my lower wall oven...what to do?
Hi. Error code F24 indicates that the controller has failed to communicate with the lower convection fan and oven lights control board. If the error code persists, I would recommend connecting with an expert repair tech to assist further and the display board may need replacing.
Sep 26, 2014 | Electrolux ICON 30 in. Double Wall Oven
Thermador over has f 24 code
fan/ air flow issue. search here for another post I did explaining the correction.
May 20, 2014 | Thermador SC272T Electric Double Oven
Code f24
shorted keypad. replace touch pad and relay board. Expensive!
Feb 06, 2013 | Thermador SEC302 Electric Double Oven
My thermador double oven display is note openly connected. How do I fix it?
This board set can also be rebuilt at www.fixyourboard.com. Dim display is a common failure that can be repaired reliably at a fraction of the new board cost. Here are the relevant partnumbers :
35-00-760, 12001691, 492071, 14-38-901, 492069, 492067
1065923121 , 1065923160 , 1065923161 , 1065923200 , 1066025120 , 1066025150 , 1066025151 , 1066025160 , 1066025201 , SCD272T , SCD302T , SCE30500W , SCE30600B , SCE70600B , SCE70600W , SC272T , SC301T , SC302T , SMWS72YP AFTER S/N 8204 , SMW272B , SMW272P , SMW272S , SMW272W , SMW272YB AFTER S/N 8204 , SMW272YS AFTER S/N 8204 , SMW272YW AFTER S/N 8204 , SMW272ZS AFTER S/N 8204 , SM272B , SM272S , SM272W , SM272YB AFTER S/N 8204 , SM272YS AFTER S/N 8204 , SM272YW AFTER S/N 8204 , SM272ZS AFTER S/N 8204 , SVD48600B , SVD48600PF , SVD48600PG , SVD48600PK , SVD48600PR , SVD48600PT , S272T , S301T , S302T
Feb 02, 2012 | Thermador SC302T Electric Double Oven
F24 shows on readout and oven shuts off
The F24 fault code is caused by a closed/stuck/shorted contact on the control panel for more than 60 seconds, such has someone leaning against the controls or objects hanging in front of the controls.
Solution: Touch OVEN OFF, or turn power OFF at the circuit breakers, wait 3 minutes and then turn it back on. If the condition persists the touchpad/control panel will likely need to be replaced. Turn the power off in order to stop the beeping.
Jan 23, 2011 | Thermador SEC272BPSS Electric Double Oven
I have a Thermador Model C302ZS
I did too!! My appliance guy told be to but it on the curb - it wasnt worth fixing and we only had it 3 years!!!
Aug 17, 2009 | Thermador C302U Electric Double Oven
F-24 error, beeping after use - Thermador C302US
error code f24 oven shuts down while baking if i open the door and beeps continuously
Jan 24, 2009 | Thermador C302U Electric Double Oven
Nov 09, 2008 | Thermador SC272T Electric Double Oven
Thermador Built-in oven model cm301
Same issue w/our Thermador CM301. F23 and F24 codes - BSH acts like they have never heard of the problem! Awful service. This should be reported to the Consumer Board.
Feb 19, 2008 | Thermador SC302T Electric Double Oven
Kitchen Ranges Logo
284 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
