Question about Sony KP-48S75 48" Rear Projection Television
G-board fir KP-48S75
Where can i get a g board for this rear projection tv.
Sears wants 674.00 to fix this problem. The red and Blue have seperated and dips on the screen. Sears told us it was the g board.
can you help????
  • 10,594 Answers
I been replied you in your post, check it out..
http://www.fixya.com/support/t1129194-g_board
Posted on Oct 13, 2008
Standby/timer light stays on red. no picture or sound on tv.
this is a simple capacitor fix at your local tv guy..should be 100 to $150 max
Apr 09, 2014 | Sony KP-48S75 48" Rear Projection...
The colors are seperating making it look like 3d
This is symptom of convergence output chips failure in rear projection tv, replace convergence ouput ICs in tv to get it fixed.
If you are handy with electronics stuff repair and can solder parts in circuit board then check 2 big black ICs mounted with aluminum heat sink on D board of tv, replace them with same numbers and if you feel uncomfortable working with tv circuit boards, local tech will help you.
Thanks.
Mar 31, 2010 | Sony KP-51HW40 51" Rear Projection...
We have a Sony KP-48S75 48 rear projection television The picture has colors of blue, green, and red around the figures on the screen. what is wrong. Can this part be replaced without going to a...
Its convergence ICs, the STKs gone bad. The repair can be done only by person who knows about PCBs with embedded components. and good with soldering. You can down load the service manual for your tv from this fixya site tech support and decide how you would like to do it. You can check for costs and more FAQs on www.fixurtvs.com. If you are not sure best bet is to go for professional repair. Thanks if you took time to vote for me.
Mar 21, 2010 | Sony KP-48S75 48" Rear Projection...
Sony KP-51WS510 51 in. Rear Projection Keeps blinking 5 times. The red and green projectors are working fine, but the blue is not working. Sears service replaced the power supply, and the first board, then...
You may want to recheck your connections coming off the blue tube to the board. Also check the IC links/Pico fuses on the power board. I have a repair manual for this Tv if you need it. shanesebay304@yahoo.com
Dec 10, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony kp-48s75, shadow or ghosting picture
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 07, 2009 | Sony KP-48S75 48" Rear Projection...
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Broken the plate( F and L )difussion
Here are part numbers of plate diffusion of Sony KP-48S75 TV
4-070-280-11 PLATE (L), DIFFUSION
4-058-455-11 PLATE (F), DIFFUSION
Oct 24, 2008 | Sony KP-48S75 48" Rear Projection...
Kp-48s75 sony rear projection
does a red LED ever blink on the front panel. if you ever get 5 blinks than you are most likely haveing CRT failure the IK lines arent right and it is blanking the video.
Feb 19, 2008 | Sony KP-48S75 48" Rear Projection...
My tv is broken
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Try the suggestions on this post from the Troubleshooting page: http://www.fixya.com/problems-solutions/t101379,p228476/Sony-KP-48S75-48-in-Rear-Projection-Television.aspx
Jun 18, 2006 | Sony KP-48S75 48" Rear Projection...
Sony KP-48S75 48" Rear Projection Television Logo
66 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
