Question about Linksys Wireless-G Broadband Router
Suddenly router stopped working!
When I connect Modem to Desptop directly Internet works...
When I connect Modem to this router and connect router to the desptop thru wire, Internet doesn't work (for both desptop & laptop)....
When I connect Modem directly to Laptop, internet doesn;t work.
Upto yesterday everythign used to work.... as expected.
what is the problem and would be resolution.
  • 3 more comments
  • jsamanta Oct 11, 2008
    Mr Brown
    I tried all of these several times today, none of the combinations working for some reason. I can't believe suddenly how it can stop working !
    How to update firmware of this router ?
    Model / Version: WRT54G / ver. 2
    Power light: Solid green
    Desktpo's IP Adddress when connected to the router:
    Connection-specific DNS Suffix . :
    IP Address. . . . . . . . . . . . : 192.168.1.101
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . : 192.168.1.1
    I have downloaded the firmware, but not sure how to apply to router....
    can you provide me some steps pls...
    I tried - operation failed....
    I also tried to reset to factory settings - still same issue....
    No clue
    its comcast.. they have verified... from their perspective it is operational. because when I connect modem directly to desktop - it works.
    they can't do anything - thats what they told me
Mr Brown..
After few tries, I was able to upgrade firmware and it started working.
Thank you so much!......
Posted on Oct 13, 2008
  • 45 Answers
Hi jsamanta!
First of all check if the power light is blinking or solid. if it's blinking reset your router.
When your computer is directly connected to the router try checking the IP address by clicking start>run> type cmd then ok. then type ipconfig then hit enter. IP address should be something like 192.168.1.100. not 169.254.xx.xx. if it's the latter reset your router. use a ball point pen or a paper clip. the reset button is a small hole at the back. If the IP address is like the first one i've mentioned. log-in to your router.
launch browser (internet explorer or firefox)
type http://192.168.1.1 or whatever your default gateway is. go to the status tab and check if you are getting a WAN or internet IP address. if not you will see a "release" and "renew" button. hit release then renew. if you're still not getting anything. do a power cycle. turn everything off. connect everything the way they are supposed to be connected. turn on modem first then router then computer.
If everything fails the last options is a firmware update on the router.
Hope this helps. =)
Posted on Oct 11, 2008
  • 3 more comments
  • mrbrown0603
    mrbrown0603 Oct 11, 2008
    Sorry if none of that worked. can you give me the exact model and version of the router?
    Can you also give me the status of the power light? is it solid or blinking?
    What is the IP address that you are getting when your computer is connected to the router?
  • mrbrown0603
    You can find the firmware and other information for your router HERE.
    Don't forget to select the version.
    Who's your ISP maybe it's just settings that we need to configure.
  • mrbrown0603
    • Before you start, be sure you are using a PC that is connected to the WRT54G via a wired (Ethernet) connection.
    • Open your web browser (e.g., Internet Explorer, Netscape, etc.)
      In the Address bar, type in the IP address of your router. The default IP address is 192.168.1.1.
    • Leave the username blank and enter your password. The default password is "admin" all lower case.
    • Click on the Administration tab.
    • Click on Firmware Upgrade.
    • Browse for the firmware file that you have just extracted. The file name should end in .bin
    • Click the Upgrade button.The router will begin its upgrade routine. Do not power off or unplug the router until the process is completed. This process may take up to 5 minutes to complete.
  • mrbrown0603
  • mrbrown0603
    mrbrown0603 Oct 12, 2008
    Can you try cloning the mac address of your computer to the router. You can do it on the router's configuration page.
E900 no internet access
You can try turning off the router for 2 mins and try to access the user interface again . If turning off the device will not work then what you can do is connect the modem to the PC , download Firmware for your router , connect the router back to the computer ,access the user interface again and perform the upgrade .
Dec 07, 2017 | Linksys Computers & Internet
Hello. I have a Dlink dir 600 router and it worked without problems for about a year (usually there were 2-3 laptops wirellesly connected to it). Then suddenly I couldn?t connect to the internet anymore....
Make sure all the wires are connected properly. 1.-Unplug your modem and router from the power supply. Wait 1 minute. 2.-Plug your modem back to the power and wait for all the lights to stop flashing. 3.-Plug your router back to the power and wait for the lights to stop flashing
Follow these steps and your internet should be working again!
Jan 13, 2011 | D-Link DIR-600 Router
D-link has stopped working with comcast internet.
Are you trying to install the router.You can do it manually
without the CD.
MAke sure that your computer is able to go
online through the modem.
If your computer is able to go online
through the modem
Then you need to connect the computer to the
router ad the modem to the router.
open the set up page of the
router and change the settings of the router according to the
ISP.
Click Here for step by step by instructions
Jan 16, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
My modem is working but my internet is not
reboot the router if it dont fix the problem direct connect to the modem if it come on replace the modem
Aug 25, 2009 | Zonet ZSR1114WE 802.11g 54Mbps Wireless...
My router just stopped working. The internet
There can be several causes for this:
1. Check for power to the router which can be lost because of a loose DC plug or bad power brick.
2. Check the DSL or cable modem if it is working properly and can get you on line if directly plugged into your PC.
3. If any of the above are ok, then your router has just died. Routers have a high rate of failure so I won't be surprised if this was the case with yours.
Jul 13, 2009 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Router not working
Check the adapter definitions on your PC
Jul 13, 2008 | NetGear WGT624 Wireless Router
Wrt54g V8 Suddenly stopped working
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 07, 2008 | Linksys Wireless-G WRT54G Router
Lost internet connection
Change the calbe from the router to the dsl modem. Make sure you check labels on the rear of these devices to make sure the connections go where indicated. Is there and ethernet light on your modem. If that is on then the connection is made. Also check if the DSL modem works directly connected to the pc.
Jan 06, 2008 | Trendware TEW-452BRP Wireless Router...
Linksys Wireless-G Broadband Router Logo
160 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
