Question about Toshiba Satellite A205-S4617 Notebook
Toshiba laptop Did you ever figure out what happened to your laptop?? My powers on but I get no display. I can hear it run but nothing displays. Did you ever find out what the problem was or how much it costs to fix it. Did you lose your files? Guero111@yahoo.com Thanks!
  • Anonymous Oct 17, 2008
    turn on sometimes it boot up then sometimes it go to start in different modes and sometimes screen goes black but power light is on. Then sometimes it go to chksd, but never make it past start page. mx35-s149
  • Toshiba Master
  • 5,568 Answers
Since you didn't post this as a comment to the original message to which you are referring, the person you have asked will never see your question. You will need to go through all messages regarding your Toshiba model to find it again.
Posted on Oct 13, 2008
My toshiba satellite c655d-s5080 wont come on even though the power light comes on and the fan comes on after a while
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 11, 2012 | Toshiba Satellite C655D-S5080 Laptop
Power stable however no display, the lock keys flick and the bluetooth symbol always on.
no display after switching on the laptop?
1. try to connect to an external monitor using an analog video cable. monitor is on. turn on laptop after a minute press and hold on Fn key then press F8 at the same time to toggle the display between LCD to Monitor, if nothing happened do step 2.
2. turn of laptop. remove video cable. press and hold D key then press power button at the same time. this will test the LCD. check if there are colors display. if yes do step 3, if no replace lcd and lcd cable.
3. make sure laptop is off. press and hold on the Fn key then press power button at the same time to run a quick test. Even no display or anything wait for about 5 minutes check if you will hear series of beeps. If yes.replace video card if it is expansion, replace motherboard if it is integrated.
Sep 24, 2009 | Dell Vostro 1510 Laptop
No display/monitor problem? When I turn on my Toshiba Satellite pro L300, I can see the Toshiba logo, bios menu, windows loading logo etc, then when it loads my desktop, nothing! No display, no graphics...
When you press power button press F8 key then enter in enable vga mode.
Then go to display proeprty and set screen rsolution to 1024*768 then apply.
Then check.
Aug 20, 2009 | Toshiba Satellite Pro L300 Notebook
When i open my laptop only Q DISPLAY IN SCREEN HANG UP
Does the hard drive sound like it is spinning.
Did you try to go into the Bios setup?
Jul 27, 2009 | Toshiba Qosmio G25-AV513 Notebook
Toshiba Sattelite a135-s2276 turn on fan working but no display
I think some cooling devices on your laptop stopped working which might have lead to Motherboard problem due to heating.
Jun 22, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba m50-mx2 powers up okay but no display
when you have the memory in and you boot up does it look like the hard drive LED is flashing? If so then its booting up into windows and that would mean a bad Display. If nothing happens then try a different stick of good RAM and see if it boots up then, if still nothing then it sounds like a bad motherboard.
Feb 02, 2009 | Toshiba Satellite M45-S265 Notebook
Toshiba A105 will not boot up even with cd and f12
its not a booting issue if you hear the music, it loaded windows. you might have a display issue, shine a light on it to see if you can see any faint images, if you can the backlights out if not it might be the display adapter on the MOBO, in either situation calling toshiba would be required for a repair, or otherwise take it into a shop, but first try a power reset,
unplug it and remove the battery, then hold the power button down for one minute, replace the battery and power cord and try to boot again. if this fails call toshiba, its definately a hardware issue.
Jan 23, 2009 | Toshiba Satellite A105 Notebook
Toshiba A200
The common mistake made when repairing toshiba laptops is forgeting to remove the battery. If you forget this it can cause the problem you are describing. And this has happened to me before (it was not my laptop and I was lucky to figure a possible solution to the problem. Remove the battery and disconnect the power supply (if you are up to finding and removing the cmos battery it might take less time) then leave it a few day with out power this sould reset the bios and restore setting and hopefull solve your problem.
Nov 06, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba laptop power light is on but nothing is working
When you turn the computer ON, can you hear something running on the laptop? If yes, have you tried taking out the battery & just turn the computer ON with the ac charger plugged-in? If you tried to turn ON the computer with the fully charged battery with the above troubleshooting but still there's no display on the screen, then I think there's something wrong with your hardware (maybe the LCD or the motherboard). You could also try using an external monitor to test if it's your LCD that's defective, if not it's your systemboard. Try calling their tech support hotline.
Hope this helps.
Sep 21, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
