Question about Refrigerators
RCA freezer problem
I have an RCA Refrigerator/Freezer mod # MTX18EAXJRWH. The food is always frost covered, it seems that it got warm / soft food and then refroze. The food is so frost bitting that I end up throwing it out. Also I find the fan is always running and that it is very cold, and I have the freezer setting at the lowest setting. No issues with the refrigerator.
the dr
  • 447 Answers
SOURCE: Refrigerator/freezer is warm, fan is running.
The problem is the compressor isnt starting. The relay is probably ok. It should have 5yr warranty on the compressor. However if you purchase a Supco RC0810 start assist relay available at all appliance parts stores, it will start the compressor, however this is only a temp fix. But it should last till sears can put a new compressor in.
Posted on Sep 29, 2007
bobotfel
  • 236 Answers
SOURCE: Thermostat (1) Assembly defrost, (2) damper, (3)Thermostat???
If it is digital control its either the thermistor or the control itself, if it is manual then the problem is the thermostat.
Posted on Feb 05, 2008
  • 958 Answers
SOURCE: Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
Posted on Jun 25, 2008
22yooper
  • 828 Answers
SOURCE: Frigidaire is freezing everything
Make sure the light is going off when the door is in the closed position. Find the switch that the door makes contact with when it closes. If the light is not going out the heat from the light being on could cause such a problem.
Posted on Aug 25, 2008
docjohn174
  • 943 Answers
SOURCE: freezing problem
HI thanks for your question. try turning the thermostat to a lower, number. and clean all the coils at the back by the compressor. it might be all you have to do/ thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 12, 2008
LG French door bottom freezer unit is only 5 years old. Bottom freezer suddenly not keeping food frozen. Ice cubes are melting, ice cream is soft, and there is water on bags of frozen food in top basket...
You have a defrost condensate drain blockage where all the water from defrost remains inside the freezer compartment and causes the symptons you are having. I cannot tell you how to remove every model numbers freezer rear panel but I think that if you study over my link here=> Leaking Refrigerators and this link HERE you will get an idea of what to do. I am here to answer any questions, Sea Breeze
Aug 09, 2013 | Refrigerators
My fridge part of fridge/freezer doesn't work
Post the model number of the refrigerator. Defrost freezer behind where the cold air circulates with a hair drier. (unplug power first!) Most times when a refrigerator side stops cooling it is because the freezer evaporator behind the panel in the back of freezer (most times) has become blocked by frost=> SEE PHOTO Most times the panel before you see the frosted covering the evaporator will begin to show a layer of frost building=> SEE PHOTO (Click each photo to enlarge.) Sometimes the fresh food section of the refrigerator side will warm because ice or frost will block the damper from moving that regulates temperatures in the fresh food section. Sometimes the damper is defective and sometimes the sensor that controls the damper movement is defective. For these reasons it is important that you provide your model numbers so someone knows just what type refrigerator you have to cover all of the possibilities of what may be wrong causing the warming of the fresh food section and soon the freezer section will also begin to warm. The most likely cause are the defrost control, ADC Adaptive Defrost Control, defrost heater, defrost thermostat, air damper and air damper sensors in that order. Let me know what you have and I will try to identify just what may be happening, Thanks Sea Breeze
Dec 01, 2012 | Refrigerators
FREEZER NOT FREEZING PROPERLY
There could be a large list of things that cause the freezer to warm up from the temperature it was before. The most likely reason is you probably have a defrost problem. Defrost heater, defrost thermostat and the defrost control are all things that may have failed. If your model is not a frost free let me know. Look inside freezer for a layer of frost building on the rear wall. If your refrigerator is not defrosting it will be a short time before the fresh food compartment begins to warm. To extend the time your refrigerator and freezer can keep food safe defrost by placing a bucket of hot water inside the freezer and close the door. Please place food from freezer and fresh food compartment into another refrigerator or cold storage area. By keeping doors shut as much as possible the refrigerator and freezer will last up to a week this way before defrosting again, Sea Breeze
Sep 12, 2012 | Hotpoint Refrigerators
GE GTS22KHP refrigerator - fridge is warm, freezer seems cold and is making ice. When the fridge was getting warm, we checked the freezer and some of the food in the door of the freezer was starting to...
With 'no-frost' fridgerators, they enter a 'defrost' cycle that is supposed to elimnate any frost. There are a few suspect parts, but it should be 1 of 2 parts. The timer that controls when it enters the 'defrost' cycle is occuring too often, or more likely, there is a thermostat that overrides the timer once the temp on the cooling coils (not freezer) reaches, say 55 degrees and commands the freezer to resume cooling.... I bought a themostat off amazon for $26 and put it in and no longer have my ice tray frozen solid after prolonged defrosting. Google 'no-frost' fridge how it works...
Oct 24, 2011 | GE GTS22KHP Top Freezer Refrigerator
Food in freezer covered in ice particles
The only way frost can form on the outside of your frozen foods is from moisture in the air entering the freezer. This happens when the door is opened exessively or your door seal is not seated firmly to the frame when the door is closed.
Fuji
Aug 06, 2009 | Maytag MZD2766GES Side by Side...
We have a G.E. mod.# GSS22KGMCWW refrigerator that frosts
you have defrost problem 1 timer 2 defrost thermostart 3 heater best way call service
Apr 05, 2009 | Amana ARS2464B Side by Side Refrigerator
Freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
May 22, 2008 | Frigidaire Refrigerators
My frost free fridge freezer is set to high and still only gets down to about 11c and is usually at about 15c
You may have ice blocking the opening in which your freezer air passes through to go into there refrigerator .Try this,unplug the refrigerator for for at least 14 hours ,that should allow all of the ice to melt.Then ,plug it back in and take the temperature of both freezer and fresh food sides.You should find a temperature that will hold at or very close to Zero degrees in your freezer side.Start with this for your first step in repairing this and get back to me.
May 12, 2008 | Refrigerators
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
