Question about Acer AL1716 F Monitor
ACER AL 1716
THe screen doesn't turn on. The indicator light flashes green. The monitor will come on sometimes when the computer is turn off and on several times.
I had one with the same problem. All the capacitors in the power supply were fried. If you're good with electronics, you can pull it apart and replace them (about 8 bucks in parts) or take it to someone who is.
Posted on Nov 12, 2008
  • meatybeats Nov 12, 2008
    The backlight inverter is actually integrated with the power supply on this model.
    Champion:
  • 293 Answers
Hi...there,
It's seems your backlight inverter are busted, need to replaced a new one or repaired it.
Posted on Oct 11, 2008
Flashing green light and monitor wont start
There are one or two capacitors that open in the power supply, sometimes it will have a bulge at the top, making it easy to spot.
Apr 05, 2012 | Acer Computers & Internet
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
I have a AL 1716 monitor and the on/off button is
More likely to be bad caps with bulginh tops in the power supply, common problems, see some example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 06, 2010 | Acer AL1716B 17" LCD Monitor
Acer monitor only display for about 3 to 4 second
Sounds like a busted syncing circuit, probably due to a condenser. It takes about that time to heat or overcharge, at which point a safety feature will turn off the display.
You just MIGHT get some more life hours out of the monitor by tuning it to a lower resolution, but it will buy you a month even in the best hypothesis.
I'm afraid the monitor is in for a repair/replacement.
Oct 30, 2009 | Acer AL1716 F Monitor
Acer AL1914 black screen, green light
it sounds like a deleted driver? try getting the driver for the monitor, did you loose the Operating system at some point, if so try a system restore to a date when the computer was working properlly prior to the malfunction. It sounds like it restored you to a time before the driver for that monitor was installed.
Feb 16, 2009 | Acer AL1914B Black 19 in LCD Monitor
Acer AL 1715 monitor flashes 2x and dies
LCD panels use cold-cathode fluorescent bulbs to make the light necessary for them to show images. What you're describing is something I've seen in panels where the bulbs were dying or dead. it's also possible that the controller for the bulbs is also on the fritz.
Jan 08, 2009 | Acer AL1715 17" LCD Monitor
ACER AL 1716
There are two types of lines.
Lines caused by a bad LCD screen and lines caused by poor sync.
A bad LCD will cause perfectly straight vertical and horizontal lines that don't move at all. This is because the row and column addressing ICs have gone bad, so you will end up with rows or columns of bad pixels.
Poor sync looks more like what you are describing. The picture will flip vertically and horizontally.
Poor or missing sync can be caused by a bad video cable, or a bad IC on the main board.
If the monitor has a removable video cable, borrow another one from a friend to test if the monitor is working. If it works, head to your local computer store and buy a new cable.
If the monitor still doesn't work with a different cable, you may have a bad main board. The only way to repair the monitor will be to replace the board.
If you open the monitor, be sure to check for bad capacitors. They can cause all sorts of strange faults. Look elsewhere on this site for how-tos on inspecting capacitors.
If your video cable is not removable, there's not much you can do. You will need a way to test that each pin on the cable connector on the main board conducts to a corresponding pin on the other end of the cable. You can do this if you have a multimeter, or a continuity tester.
Mar 28, 2008 | Acer AL1716 17" LCD Monitor
Snowy Raster on display
Hi mcuyg,
Hope this will give you hint in solving this problem. Try configuring monitor settings in OSD mode; contrast; brightness; etc.. other special settings can be accessed using combination of buttons to minimize the raster intensity. On hardware side try resoldering cold soldered points and check the SMPS side.
Best regards,
Rosener Guyano
Jan 27, 2008 | Acer AL1716 17" LCD Monitor
Acer AL1716 F Monitor Logo
469 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
