Question about Dishwashers
My kitchenaid dishwasher heating element looks as if a coating is coming off of it in a small area. I would like to replace the element...how is easy is it to replace.
  • Anonymous May 17, 2009
    The heating element in our dishwasher is cracked. How easy is it to replace?
    Problem Solver:
  • 9 Answers
I just replaced mine. I ordered the part from Kitchenaid and just got it today. I turned the power off at the breaker, turned the water valve off under the sink. Two screws hold the machine in place under the counter top. I slid the machine out about 8-10 inches and disconnected the water supply tubing on the bottom left side of the machine and then was able to pull the whole dishwasher out from under the counter top. on the bottom in the back are two white plastic hex nuts with a wire connection going to each. I pulled the wire connections off each and loosened the white plastic wire nuts. Then I went into the washing tub where the heating elements is. I shook the two contact ends loose and pulled the element out. I put everything back in the reverse of this. You will then need to reset your panel by pressing the sani wash and the heat dry buttons back and forth a couple of times. All the lights will then go on and the machine will reset itself. Give it a go. Best to ya!
Posted on Oct 11, 2008
Thanks a million. I was able to reset my panel by pressing the sani wash and heat dry buttons until panel was all lit. Then I disconnected power. When I repowered, I pressed cancel. Then it started! What a wonderful sound. Thanks again. Grateful soccer mom.
Posted on Apr 15, 2009
I think the heating element is not working do i have to replace the control panel also?
Posted on Jun 10, 2010
Dishwasher is not drying. Dishes come out dripping wet.
Posted on Apr 20, 2009
Kitchenaid superba stove baking element does not heat
There has to be a baking element. Find it and replace it.
Aug 19, 2017 | KitchenAid Kitchen Aid Superba Series...
The water is not heating up
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Apr 14, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishes are wet after wash. Appears drying cycle is not working.
heatman101
Asker
Jan 06, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid dishwasher model: KUDI01FLSS caught on fire during a cycle! Wife claims she heard "electrical" sounding popping and crackling and smoke was pouring out sides. She was able to...
Sorry to read about your problem, I hope this helps you out.
yes you should replace, i would guess the plastic is melted, in the coil area
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Dishwashers
The clean dishes are suddenly coated with a gray white residue.
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried in vainto clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if the heating element goesbad then that also can mess things up bad... So I would buy new spray arms, and also check out theheating element to make sure it is working... Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 23, 2010 | KitchenAid Dishwashers
Kitchenaid KUDM25SH dishwasher - water not heating
Depends on how much that you use the dishwasher. It's possible that the element is burnt out. If you know how to check the element, you can with a meter, however if you don't know electrical, then by all means get a qualified individual. There isn't a thermostat. Everything is on a timer circuit.If there is a preheat on the machine, you could set it to that and the element should come on also.
May 03, 2017 | KitchenAid 24 in. KUDS25SH Built-in...
Our house had a power surge last year and since then our kitchenaid KUD102IRBL has had some issues. One is that the 4 hour delay stopped working all the time, and now a very loud noice comes out of it...
Step 1, Open up the sump assembly/filter which is below the lower spray arm. It appears the the sump filter top is held down with just one screw.
Remove everything you can, rinsing/cleaning any thing that needs it. With a flashlight, inspect/clean the sump area, looking for any debris. While you are there, look closely at the heating element for any damage (breaks or "bubbles" on the dark circle/rod.) If you see obvious damage, replace the heating element.
Reassemble and test out dishwasher. Test out with dirty dishes and use only a brand name powder detergent (like Electrosol or Cascade)
If problems continue, confirm that the heating element is working. Replace as needed. If it has failed and is replaced, you will see immediate improvement in cleaning.
If heating element is working and cleaning is still poor, replacing the main washer pump (which includes the impeller) will fix you right up.
Good Luck and please update me with what you find, Ok?
Apr 01, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Wet dishes
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Jul 19, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Heating element broken, water leaking
You have to pull out dishwasher to replace the element.The element is easy to replace once you have pulled dishwasher out.This enables you to reach the area that you need to reach.It is common for a element to brake.On a newer dishwasher ,I would say it must have been defective if it just broke in half.Nothing electrical in a dishwasher can cause it to brake.
May 20, 2008 | Kenmore 24 in. 15953 Built-in Dishwasher
Kitchenaid dishwasher
may have a heating problem.need to check for power to element,if no could be board fault,broken wire in door,if power is getting to element the the element could be faulty.hope this helps.
Jan 20, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
2,125 people viewed this question
Top Dishwashers Experts
