The stick shift feels loose sometimes, going into and out of gear. ie you can tap the stick out of third gear with very little effort.
I've experienced this on a Volvo and it was the linkage bushings. Stiffened it up nice!
SOURCE: 1999 Dodge Intrepid...shift lever wil shift gears
I believe that the cable has to be adjusted. Most cases, the cable adjustment is off. Worst case senario, is the bushing in tranny is worn out.
SOURCE: my standard stick shift seems
The spacer on the top of the transmission is bad, The sifter uses a cable and a spacer on the cable end which is located on top of the transmission, very easy to get to, just buy the part and put it on.
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
Mercedes-Benz transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Mercedes Benz not engaging in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Chrysler PT Cruiser only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
2007 Ford Expedition: How to shift car in neutral with Dead Battery
http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html
2002 Nissan sentra will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Nissan Sentra stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic transmission will not go into high
gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car won't downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
Buick Park Avenue: Transmission will Not
shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
No
First gear Starts In Second Gear
http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html
Ford Taurus won't shift from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
2006 Ford F150: Will Not Shift out Of Park?
http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html
Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
1998 Chrysler Voyager: Transmission Problem?
http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html
Shift indicator directly goes to 2nd when key
is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
Chevrolet silverado has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
2002 Chevrolet Avalanche Z71: Gear shift
Issue?
http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html
Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
Transmission-Hard To Down Shift
http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html
Automatic transmission shift lever hard to move on cold
mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
2000 Nissan maxima shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish delayed shifts while
driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
2007 Hyundai Santa Fe: Will not Shift out of
Park Mode?
http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These will help.
Thanks.
Transmission not engaging in first
gear?
Vehicle only goes
in First gear?
Engine will not go out of park mode?
Car stuck in park?
Car will not come
out of Park?
Automatic
transmission will not go into high gear?
Car wont downshift
sometimes?
Transmission
will shift into drive?
Auto wont shift
from park?
Car Transmission
Shift indicator
directly goes to 2nd when key is turned ON?
Third gear missing
Vehicle has whining sound in gear?
transmission?
hard to move on cold mornings?
Gear shifts hard?
delayed shifts while driving?
This will help.
Thanks.
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html----transmission sticks in first gear?http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html-----Transmission not engaging in first gear?http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html-----Vehicle only goes in First gear?
----Engine will not go out of park mode?http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html----Car stuck in park?http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html-----Car will not come out of Park?
Automatic transmission will not go into high gear?
---Car wont downshift sometimes?
----Transmission will shift into drive?
-----Auto wont shift from park?http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html----Car Transmission will not go into Park mode?
-----Shift indicator directly goes to 2nd when key is turned ON?
----Third gear missing and engine losing power?
-------Vehicle has whining sound in gear?
-----Hard to shift gears on Manual transmission?
------Car hard shift at slow speeds?
---Automatic transmission shift lever hard to move on cold mornings?
------Gear shifts hard?
-------Vehicle noticed sluggish delayed shifts while driving?
This will help.
Thanks.
thanks for the help. is it an easy fix?
