Question about OKI C3100 Led Printer
HP c1380 The printer doesn't uplift or feed paper. Have reinstalled, turned off and on, restarted PC. No progress. Message keeps appearing that the printer is out of paper.
Past service life message on Epson C88+ message appears and will not accept new cartridges or try to feed paper at all. Since this printer is just for home printing and it doesn't need to print...
Check if there are any objects blocking the way of the printhead or if there are objects down the paper feed area.
Is your printer placed on a stable, flat surface?
Does it happen to all the papers that you are using? Are the papers in good condition?
Try loading only 10 to 20 sheets of regular paper.
do a printer check to isolate the issue. Turn the printer off. Unplug the usb cable from the printer. Hold down the paper button while you turn the printer on. Keep on holding down the paper button only. Let go of the paper button when the power light starts blinking. If it does the same, there is an issue already on the gear of your printer.
If your unit is out of warranty, log on to support.epson.com. Click on help me find a service center to the left of the page to contact the epson local servicers near your area. If your unit is under warranty, call epson.
Oct 03, 2011 | Office Equipment & Supplies
My HP 3050 Laser printer is not recognizing the print cartridge. I had a paper jamb and the error message started. I have tried to power down the machine, reinstalled a new cartridge, removed and...
Hello, If your cartridges are not empty, but you continue to receive the 'Ink Cartridge(s) are Empty ' error message, follow these steps to override the message. Disconnect any cables (Ethernet cable or USB cable) that connect both the printer and the computer. Restart your computer. (Consider bookmarking this page in your Web browser so that you can easily return to it after the computer restarts.) With the printer turned on , remove the power cord from the back of the printer. Wait 30 seconds. Insert the power cord back into the printer, and turn the printer on. Clear any error messages. Reconnect any cables that connect the printer to the computer. If the above doesn't solve the problem, you will have to download Hp diagnostic utility on your your computer, install is on your computer and it will help to detect and solve the problem. Visit the hp link below, read all the information on the page and download the diagnostic tool from the page. Click here: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02114788&tmp_task=solveCategory&lc=en&dlc=&cc=us&product=441125 Keep me informed if none of the above seems to solve your problem. Good luck.
Jul 11, 2011 | HP LaserJet 3050 All-In-One Printer
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
Printer is loaded with paper, but out of paper message appears. The message instructions are to add more paper and press continue to print. I've checked the paper rollers and blew air in to clean. ...
the roller rubber that is pulling the paper has a problem either it is worn out or not rotating you can have a visual inspection on the paper tray observe whether the rubber is rolling after you command a print..if not then you need to open the case of your printer and check for any brocken belts and gears that holds the rubber roller.
check also the switch that senses the paper feed at the tray it is a small switch that is triggered by the paper when you insert.
the message out of paper is cause by a time out of the paper to reach the printer head because of difficulty of feeding the paper the roller wont engage thats a out of paper message appear..good luck just post back if you have question
much appreciated if you cn click the 4 thumbs uo button for my effort this keeps me going!
Aug 23, 2010 | HP Deskjet 3845 InkJet Printer
Paper jam appears at the screen. eventhough it's already been cleared.
try to restart you pc, and turn off your printer try to feed paper manually by turning the roller to guide paper and check for possible obstruction and check also hook type key for feed sensor if free to move. turn of printer and make test print.
Mar 23, 2010 | HP D1560 Deskjet Printer InkJet
Paper jam error message
This problem is a detection problem, due to a bad sensor selection or incorrect label size.
If the labels are white labels with a separation between each, select TRANSMISSIVE. If the labels are preprinted, select the TRANSMISSIVE PREPRINTED LABELS and set the threshold doing this.
With the printer in ONLINE, press PAUSE once, the message PAUSE appears in the display, press and hold on the PAUSE key, TRANSMISSIVE is displayed, release the key and press PAUSE until labels starts to feed, let feed some labels (5 or 6) and release the key. Press Restart and start to print.
Dec 08, 2009 | Toshiba TEC B-SX4 Thermal Label Printer
HP 5510 OfficeJet - error message "Remove & check color cart"
check all areas for any paper jam, also check the feed roller in the paper trays if the roller are slick with paper dust, clean them and then reinstall the paper. Sounds like a paper sensor is not been cleared. then the error message, should go away on reboot.
Mar 16, 2009 | HP Compaq Evo Notebook N600c
HP psc 1300 printer
I had to turn off my computer, unplug the printer power cord and computer cord. I restarted the computer and pluged in both cords to the printer and it worked.
Oct 07, 2008 | Office Equipment & Supplies
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
OKI C3100 Led Printer Logo
208 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
