Question about HP Computers & Internet
I purchased a compaq M 300 laptop without a hard-drive,and CD-Rom. Now I would like to install Windows XP using a hp MB cradle I recently purchased but the unit is not reading the WinXp cd-rom. How can I install the operating system to this unit? thanks for your help. emitoday@bellsouth.net.
  • emitoday Oct 11, 2008
    Thanks for the solution but I have not tried it yet. I am not sure however if there is an option in the bios to set for CD-rom since the unit was not manufactured with a cd-rom. I will try it anyway. thanks
    I still cannot get the system to boot , I set the boot options to boot first from the multi bay device but following the post it came back with messages , disk read error occurred, Press .ctrl, alt del to restart. no more action available
  • HP Master
  • 6,487 Answers
First thing to do here is to make sure that on your BIOS you set boot priority to CDrom so when you put the installation for XP and restart the computer , it will boot from the CDrom not from the hard drive..
Hope that helps........
Posted on Oct 11, 2008
    Genius:
  • 1,913 Answers
U have to bootable disk of win xp.then set first boot devicce in bios your dvd rom or cd rom.
then u get message pres any key to boot from cd .wehn u start the ssytem.
then follow the procedure.
press enter.
then create parttion.
as u like.
thejn simple follow the procedure.
  • kishor khatri
    kishor khatri Oct 11, 2008
    when u start the ssytem press DEL or F2 or F8 or F12 to enter in bios .
    save boot device as your dvd or rom.
  • kishor khatri
    if u have any problem let me know.
SOURCE:
Need saystem requirements
System Requirements:
  • Windows 98/2000/Me/XP
  • Pentium 200 processor (Pentium II 300 or greater for Windows XP)
  • 64 MB RAM (128 MB RAM for Windows XP)
  • 800x600 display (16-bit high-color)
  • Minimum 720 MB hard drive space
  • 4X CD-ROM drive or faster
  • Windows compatible soundcard and speakers
Jan 26, 2011 | The Learning Company PrintMaster Platinum...
Pentium III 500 mhz will support windows XP
Here is Windows Xp requirements:
PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
1.5 gigabytes (GB) of available hard disk space*
Super VGA (800 x 600) or higher-resolution video adapter and monitor
CD-ROM or DVD drive
Keyboard and Microsoft Mouse or compatible pointing device
Jul 28, 2009 | Intel Pentium III Xeon , 500Mhz...
I have just brought dell latitude e5500 laptop. i wanted to connected the hp officejet 5610 scanner to my laptop but am not able to do. please help
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab19
Jul 11, 2009 | HP Officejet 5610 All-In-One InkJet...
Can not install windows Xp
What error messages are you seeing ?
Have you any codes given ?
Without knowing this it could be alot of things ie...
Could be bad memory, Bad CD or CD Rom Drive and so on...
Gaz
Jun 01, 2009 | HP Compaq Presario v3000z Notebook
Compaq 2500
The disk itself may be corrupt , go to microsoft and download xp home or pro , whatever your using and burn to a disk .If you don't have access to another computer , go to a repair shop and you can usually buy a burn't copy of xp for 5 to 10 dollars . RE-install as usual. please note !!! you must know what service pack is needed for the install . SP1 - SP2 ....OR to be on the safe side just get XP SP1. good luck!
May 30, 2009 | HP Compaq Presario 2500 HP Pavilion ZE...
Plz help me
plz check your hard drive, cd rom and ram
May 18, 2009 | HP Compaq Presario CQ50-110US Laptop
Can we install windows xp on compaq v3424 au laptop
If your laptop meets the following requirements then there shouldn't be a problem:
CD-ROM or DVD drive
I would take a system restore point BEFORE you upgrade and make sure you back up everything BEFORE you attempt an install/upgrade.
Hope this helps.
Feb 20, 2009 | Microsoft Windows XP Professional With...
WindowsXP SP2Installation hangs in Compaq Presario 2000 series
minimum requirements for XP
• 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
• 1.5 gigabytes (GB) of available hard disk space*
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• CD-ROM or DVD drive
• Keyboard and Microsoft Mouse or compatible pointing device
Nov 07, 2008 | Microsoft Windows XP Professional With...
How to install operating system on laptop with now cd-rom drive or floppy
Did you change the '1st boot' drive to the optical drive?
If you haven't, you need to enter the BIOS setup and change from C: to whatever your optical drive is named and then change it back once the operating system is installed on the C: drive.
Oct 11, 2008 | Compaq Armada E500 Notebook
WINDOWS XP
Windows xp can run on any PC that has a 233 mhz processor and 64mb of ram. Here is a list of hardware requirements for windows xp taken from microsofts website : These are the minimum requirements for basic functionality. Actual requirements vary, depending on the system configuration and the programs and features that you choose to install. If you are installing Windows XP over a network, you may need additional available hard-disk space. The minimum hardware requirements for Windows XP Home Edition are: ? Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended) ? At least 64 megabytes (MB) of RAM (128 MB is recommended) ? At least 1.5 gigabytes (GB) of available space on the hard disk ? CD-ROM or DVD-ROM drive ? Keyboard and a Microsoft Mouse or some other compatible pointing device ? Video adapter and monitor with Super VGA (800 x 600)or higher resolution ? Sound card ? Speakers or headphones The minimum hardware requirements for Windows XP Professional include: ? Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended) ? At least 64 megabytes (MB) of RAM (128 MB is recommended) ? At least 1.5 gigabytes (GB) of available space on the hard disk ? CD-ROM or DVD-ROM drive ? Keyboard and a Microsoft Mouse or some other compatible pointing device ? Video adapter and monitor with Super VGA (800 x 600) or higher resolution ? Sound card ? Speakers or headphones
Aug 29, 2007 | Computers & Internet
Computers & Internet Logo
59 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
