Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
Neptune Maytag MDE9700AYW
My dryer won't spin and timer keeps going through the cycle but nothing happens. There is no error code that lights up. I can hear a hum that engages for about 3 second and then goes off when I press the start button, but then it goes away. Can you help?
  • 3 Answers
There is really only one way to put the belt on. Pinch it and loop it around the tension pulley and then slip it over the motor pulley. If the belt is not off, it may be a loose wire to the sensor that switches the dryer off when the belt is off or broken. Mine had that problem. If that doesn't work you will have to replace the tension pulley sensor.
Posted on Jan 03, 2012
  • 21 Answers
Remove the screws from the bracket from the vent tube at the back of the dryer.
You can access the belt from there.
If the belt is off then the tensioner will push a switch to shut the dryer down.
Just hook the belt back on or replace the belt whatever needs to be done.
See other posts for this model number on how to connect the belt back if it came off.
They do that when turned the wrong direction.
Posted on Jan 18, 2009
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Maytag neptune error code
anytime a fuse trips it is due to too much load on a circuit-or over heating-tear down the machine and clean out lint look for it in the ducts that exhausts out of the house and even the outside flap-cheers Denny
Oct 22, 2013 | Maytag MDE9700AYW Neptune 174 Electric...
I have a Maytag Neptune electric dryer model # MDE9700AYW and I have a fault code " FE " & the dyer doesn't dry the clothes. What is my problem
Maytag Dryer and FE code means power source "Frequency Error".
Invalid power... you will need a electrican to come out the power is not wired up right.
I would replace the wall receptacle before buying any dryer parts
Hope this helps (remember to rate and comment this answer).
Jul 01, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Model MDE9700AYW: I set the timer for a certain amount of time (say 30 minutes). I come back 45 minutes later and the dryer is still running. There is also a "racetrack" in the display. No error...
Instructions
1. Break your load down into smaller groups. Large, saturated blankets, duvets, blankets and other upholstery can be too heavy for the MDE9700AYW to safely dry. Dry large large items one at a time with some smaller items such socks and underwear to better balance the load. One washer load should equal one dryer load.
2. Confirm that the cycle selector has been pushed down and the dryer door is latched shut. When the dryer door is opened, the cycle is temporarily paused to protect you from injury. Press the cycle selector down to resume the drying cycle once the door has clicked closed.
3. Examine the circuit breakers or fuses in the dryer's electrical circuit. The Maytag MDE9700AYW needs two active fuses or breakers, depending on your home, to operate its electronics and spin the drum. The dryer may not spin if either one of the fuses or breakers is inactive.
Feb 24, 2011 | Maytag Dryers
T5 error code
e5 code have replaced thermister
Jul 24, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag MDE9700AYW electric dryer doesn't stop in sensor dry mode.
The link below contains the service manual. Detailed Troubleshooting begins on page 10.
Good luck
MDE9700 Service Manual
Sep 22, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag neptune MDE9700AYW ts t5 error
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Hope this helps
Jul 25, 2009 | Maytag Dryers
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
524 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
