I have a DCP 150C I need to change the black ink cartridge I have bought a LC37BK but do not know where to start thanks julia
  • Anonymous Dec 03, 2008
    my dcp-150c scanner doesn't work
    it cannot be recognized by my computer
    i'm using a widows xp os
    Genius:
  • 1,913 Answers
I've changed the yellow ink cartridge and it won't complete the clean process. It's telling me to look in the user manual under troubleshooting and main tangency, but I cannot
Hi Tracy,
Unplug and reboot the DCP-150 C. Ensure each of your cartridges are seated properly by doing all if necessary in an order. Let it set for a couple of minutes .Power it back up and run diagnostics. Las but not least, should there have been a paper jam. Go through the order. Make sure all the droor and interlocks are satisfied by checking each one of the entry points. Simply open and close. You got this!
Here is a link for cartridge resets for a similar machine. There is a variety of help videos around this you tube link on the side bar that may suit you if this one does not. This step is tried, after, the first method of suggestion failed.
Fare. Well. How to Reset Purge Counter on Brother DCP 195C or DCP 197C Printer
Fare. Well.
Dec 09, 2014 | Brother 32 Lc970 Bk/c/m/y Ink Cartridges...
My Brother Dcp-150c's cartridge sensor seems to be malfunctioning, it says black cartridge empty and color cartridges almost empty, even when replaced with new cartridges. Ist there a way to fix this error...
My Brother Dcp-150c's cartridge sensor seems to be malfunctioning, it says install black and ink empty and offline even when replaced with new cartridges. Ist there a way to fix this error or do I have to replace the cartridge sensor inside? Thanks.
Oct 23, 2010 | Office Equipment & Supplies
I got dcp-150c model and the problem is the black olour is not working evn its cartrige is new
It seems that ink cartridge not detected, try to search available software reseter for that model or buy from printer supplier what we called printer head reseter.
Mar 21, 2010 | Office Equipment & Supplies
Brother DCP-150C - just installed a new black cartridge (changed colour cartridges last week!) - printer will print but page comes out blank??
This may be because ink is clogged in the printhead. ? Place the clogged cartridge in about 1/4 - 1/2 inch of warm water for a few minutes. When ink starts to slowly leak out take the cartridge out of the water and dry it using a soft cloth to "Q-tip." Then place it back in your printer and run the print head cleaning utility that comes with your printer software. You may have to run this 2-4 times before printing quality is reestablished. If your print head is destroyed, as can happen, you will have to buy a cartridge and refill that cartridge before it is fully empty.
Feb 19, 2010 | Office Equipment & Supplies
Brother dcp-150c, black ink wont work
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nozzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nozzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
Feb 14, 2010 | Office Equipment & Supplies
ALL CARTRIDGES SHOWING FULL BUT BLACK NOT PRINTING
Dear it is problem black nozel is dry ink jum please wash it then solve your problem
Aug 12, 2009 | Office Equipment & Supplies
Brother dcp-150c Clean Unable 46
If you actually changed the flushing box, you should know how to go to the maintenance mode and reset the waste ink counter. Info. that is only available to Brother techs.
Jul 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
My Brother DCP-150C cant print, displays, UNABLE TO CLEAN"
Unable to clean either means there's a paper scrap in the clean station, or the ink overflow box is full and needs to be changed by a dealer. Sorry, no quick fix...
Jul 22, 2009 | Brother MFC-5840CN All-In-One InkJet...
Black ink cartridge doesn't work.
Have you tried
  1. Taking out all the cartridges
  2. Power down the power
  3. Power up the printer
  4. Open the scanner Cover
  5. Close the scanner cover
  6. Message will ask you to put the ink.
  7. Put in Black
  8. Close scanner cover
  9. It may ask you whether the Black is being changed.
  10. Open the cover.
  11. Install Cyan.
  12. Repeat step 8-10 for the rest of the 2 colours.
  13. It should resolve the Black ink empty message.
Let us know if this works.
Thank you.
Dec 11, 2008 | Brother DCP-110C All-In-One InkJet Printer
104 people viewed this question
jasbo
jasbo
