Question about Breville Coffee Makers & Espresso Machines
Power specs for breville bes200 espresso maker
Hi guys
am looking at buying an espresso maker for our motorhome and want to be able to run it off an invertor. What are the watts and amps that the above machine uses and also do you have an idea on how long it would approximately take to pre-heat the unit. Also would a modified sine wave invertor be okay to use with this machine.
thanks and look forward to your reply
  • 7 Answers
SOURCE: Breville Die Cast 800ESXL has a silicon seal (steam ring) to replace faulty or worn ones. There is no shipping charge, and they are $4 each. To replace the steam ring you'll need to remove the stainless spray disk on the brew head with a phillips screwdriver (one screw) and pull off the old ring (pay attention to the direction and placement of the stainless disk).  Takes about 2 minutes to do.
Part # .800ESXL/192
Also, on mine I noticed that the filter holder was ground down at the factory a bit too much on one side, which causes a slight leak down one side (coffee, not water).  You might check the holder (with the filter removed) for imperfections that could lead to your leak. Good luck.
Posted on Feb 22, 2008
SOURCE: manual for espresso/cappucino machine
The Miele manuals are available on the Miele site.
Posted on Mar 29, 2008
  • 4 Answers
SOURCE: breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Posted on Sep 26, 2008
SOURCE: Delonghi EC 155 general help
You don't have to wait 15 mins. just a few minutes, then run some hot water to warm up the portafilter and dry it up, fill it up with coffee and when you get the gree light again, make your espresso . You will have to have a good fine coffee and make sure to pack the coffee really good and don't leave any around the edges , so could make a good seal. If you have steam coming out of the machine , is maybe to hot and is ready to brew . Cool down the machine after use, run water through it and let the steam out of the nozzle.
Posted on Feb 06, 2009
  • 80 Answers
SOURCE: My breville espresso machine wont heat
try priming water
Posted on Aug 01, 2009
Breville espresso no pressure and water trickling out slowly..upon powering up its not as loud as usual too
Probably has lime/scale built up in it. You can try running vinegar thru it. It may require disassembly and physically cleaning the water lines out.
Jul 04, 2016 | Breville Coffee Makers & Espresso Machines
Services manual Brevill BES200
Feb 13, 2015 | Coffee Makers & Espresso Machines
I have a BES200 breville machine that when I turn it on the heating light only stays on for 1 second then turns off but the machine sits there a pumps but nothing else. ANy suggestions? I tried the online...
My machine has the same problem, no red light when first time switch on the button. the red light only ON, when I turn the selector to the left or right side.
I am curios, an opened the back panel door, and found one cable was not connected properly (loose) to the thermostat.
After re-connected the wire.. voila.. the machine works well.
Previously the machine has a problem with the steam (small steam came out), I dropped to the service center and they gave me the new ones with the above problem (no red light on)
Hope it solve your problem too
Jun 17, 2011 | Breville Venezia BES250 Espresso Machine
Heater doesn't work.
Hi. Sound like a problem with your Control Board or thermal block. You will need to speak to Breville
  • 1.866.BREVILLE (1.866.273.8455)
  • May 21, 2010 | Breville ESP8XL Espresso Machine
    Breville Die Cast 800ESXL Espresso Machine: Problem... Watery espresso. My machine worked great for a year, then all the sudden, the espresso is watery and the basket where the grinds are is full of water...
    Personnaly, when I use the big filter, the grinds are dry after the extraction, but for the small filter, it's all soggy. If you look at the documentation, ( they say wet coffee grind after extraction is normal.
    But did you change the coffee brand ? Or the grinding level ? How do you grind your coffee ? I had big troubbles once with a commercial grinder at my grocery store, it's when I decided to buy my own Breville grinder.
    Good luck,
    Oct 16, 2009 | Breville Die Cast 800ESXL Espresso Machine
    No user instructions
    Please use the link provided below to download the required manual.
    May 26, 2009 | Breville Coffee Makers & Espresso Machines
    I would like to buy a breville cappuccino maker but hear the dial at side gets stuck and breaks easily,even when cleaned well after use. Has this been rectified. Doreen
    Hi, apparently Brita, that owns Breville, did not fix the problem yet.
    I can see that complains keep coming.
    The problem is apparently on CM8 and CM9, the more expensive Cappuccino Maker BES200XL
    does not have the problem.
    One suggestion, Breville are nice budget coffe maker, if you want to spend some mor money on a better product buy a Gaggia or something similar. Italian coffee makers are usually the best for espresso/capuccino. If you want a Breville buy the ESP8XL Espresso Machine.
    Here is another good brand.
    Sep 13, 2008 | Microwave Ovens
    Breville 800E5Xl didoe
    DIODE ZENER 24V 1W 5% DO41 1N4749AOrder 'diode zener 24v 1w 5% do-41 - 1N4749A' online from Digi-Key. Manufactured by Fairchild Semiconductor. Digi-Key part number 1N4749A-ND. - 22k -
    Jul 14, 2008 | Breville Die Cast 800ESXL Espresso Machine
    Coffee Makers & Espresso Machines Logo
    42 people viewed this question
    Top Breville Coffee Makers & Espresso Machines Experts
    Steve Banks
    Colin Stickland
    Colin Stickland
    Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
