I closed the door, lock button is on, when i press any other button the lock button blinks 3-4 times and then go steady again, but nothing is going on with machine
hi jerome
I have the procedure for Toyota auto lock, is worth to try it
AUTOMATIC LOCK SETTING
1) Step in the vehicle and make sure that all doors are closed completely
2) Insert the key into the ignition key cylinder.
3) Wait for more than 5 seconds.
4) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
? Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 2).
5) While the LED is illuminated :
• Open and close the driver's door 2 times.
• Turn the key to the ACC position.
? LED will continue illuminating.
? Indicator lights will flash 2 times.
Ignition controlled door lock ON :
6) While the LED is illuminated:
• Open and close the driver's door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
? Indicator lights will flash 1 time.
? LED will extinguish.
Ignition controlled door lock OFF :
6) While the LED is illuminated :
Exiting Valet Mode with Key Fob:
1. Open the entry door.
2. Press the lock button.
3. Press the unlock button.
4. Press the lock button again.
5. Ensure the red LED is a steady glow.
Exiting Valet Mode with Valet Button:
1. Turn the ignition ON.
2. Turn the ignition OFF.
3. Press and hold the Valet/Program button for 10 seconds.
4. Ensure the red LED is a steady glow.
Entering Valet Mode with Key Fob: 1. Open the entry door. 2. Press the lock button. 3. Press the unlock button. 4. Press the lock button again. 5. Ensure the red LED is a steady glow.
Entering Valet Mode with Valet Button: 1. Turn the ignition ON. 2. Turn the ignition OFF. 3. Press and hold the Valet/Program button for 10 seconds. 4. Ensure the red LED is a steady glow.
Those are all the codes from the manual for Sharp T.V.s
So now turn the item on you want to control with the remote.
Press the corresponding button.
Hold "set" till the LED stays steady.
Enter the 4 digit code.
When entering the 4th number the LED should shut off.
This means that your remote is set for that device.
Press OK to store the code.
If the LED blinks 3 times and goes steady again the the code is not the one you want and you need to start an step 1 again.
You can also try the Code Search Function
Turn on the device you wish to match with your remote.
Aim the remote at the device and press and hold the Code Search button in the upper left of your remote for at least 3 seconds until the LED light on the remote turns a solid red.
Press the button on the remote for the item you want to program.
The LED light should blink once and then remain a solid red.
Press the On/Off button slowly until the device you want to program turns off.
The LED light will blink once each time you depress the On/Off button.
When the device you want to program turns off, press the ENTER button.
The LED button will turn off and the code for that device will be stored in your remote.
hi yes this can be done, here is how
make sure you have all keys ready to reprogram
close all windows and doors
insert key into drivers door lock
within 5 seconds of putting key in door lock turn key to unlock position 3 times
this puts the key into programming mode ( door led should be on )
press and hold lock button, within 5 seconds of holding lock button
press unlock button 3 times ( keeping lock button pressed at same time)
then release lock button
that should be it...to make sure correct programming is achieved key led flashes 5 times, and door led flashes 6 time, if you have more than one key do same as above within 15 seconds of doing the first key..
phew..lol, well i hope that will work for you..please vote thanks
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button. Press lock button briefly 3 times within 10 seconds keeping unlock button depressed. Release unlock button. Some models: LED flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously.
The Drum LED blinks if the drum unit is near the
end of its life. Use the drum unit until you have a print quality
problem, then replace the drum unit with a new one.
The Drum LED continues to blink if the drum
counter was not reset when you replaced the drum. To reset the drum
follow the instructions below:
Open the front cover of the printer.
Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Reset the drum counter only when you replaced the drum unit with a new one.
is it on steady??? or blinking??? if on steady try pressing nad holding the button with the "lock" symbol on/or above it, thinknits the heat button, for 3 secs it will "unlock" the controls, if blinkin then its a diff issue, may be a bad door switch not recognizing hte door being closed therefore wont start,
Firstly, empty the oven of stuff, including the little thermostat that dangles from the grate, if you value it's life.
Next, close oven door.
Press CLEAN; it beeps and green LED illuminates. LED readout says " -- -- --".
Press the UP arrow; it beeps and LED readout says: ''3:00'', for a three hour burn.
DOOR LOCKED LED blinks while door locking mechanism actuates, then stays on steady. Burner ignites, and it's off to the races.
The exterior of the Range becomes quite HOT, providing an excellent opportunity to educate young children of the concept. ;)
The Cleaning Cycle can be stopped at any time by pressing the OFF/CANCEL button for ~3 seconds. The door will remain locked until the internal temperature of the oven falls below 400F. Nice toy.
thank you, it worked.
