Question about Runco CL-510LT Multimedia Projector
Need to adjust from full screen to wide screen on Runco SC3050
After having satellite dish worked on, it appears that the Runco
sc3050 defaulted to wide screen. I do not have a manual to figure out how to readjust to wide screen using remote.
    Problem Solver:
  • 17 Answers
You need to use the remote, press the Menu button... on the menu that pops up on the screen, use the remote to scroll down to where it says "aspect ratio", and then select enter.
From that menu, you can select all the different aspect ratios that your Runco can perform.
Here is a link for the owners manual, straight from Runco.
http://runco.com/legacy_prods/legacy_manuals/CL-510_510LT.pdf
Posted on Dec 09, 2008
Approximately. 2" wide vertical black line top to
You may need to adjust the resolution of your laptop to fill the full screen of the TV.
Sep 27, 2013 | Televison & Video
This is a 26 inch toshiba lcd flat screen. the power went out for a while now I cannot get a full screen, just a black border around the edges. can you please advise me on what could be wrong, thanks will
Dear Friend: when TV is unplugged for a while, it goes into "factory default" settings. That's why you have 4:3 format of your picture settings, instead of "wide" or 16:9. check TV "screen" or "picture format" button, if it present on your TV(not a cable or satellite) remote control. If not, enter "menu" and find "display settings" and adjust it accordingly. Also: same issue might happen to your "boxes" Cable or Satellite. If those were without power for a while, same thing might happen to those. Check "menu" or call your provider, if needed.
Good luck,
Alex.
Apr 19, 2011 | Toshiba 26AV502R 26 in. LCD HDTV
We are not getting a full picture on the screen. There is a black section across the top and the bottom of the screen. How can I adjust this out. We have never had a problem with the TV before but we...
It may have something to do with the closed captioning... Hit the menu button, then select Screen. There you should see the options for CC. Try turning it off if they are on. Other than that the issue may not be with your TV but with the reciever for the satellite. Make sure it's not configured for a wide screen (that the aspect ratio is either 1:1, 4:3 and not 16:8)
Apr 14, 2011 | GE 27GT271 TV
Tv picture is always on full screen can not change it to wide screen or small screen. so side of picture is cut off so miss half off people at either side of screen and logos too tv channels missing like 5...
Do you use a satellite dish or cable? There are 2 different ways to control picture size. One is through the TV itself but there is sometimes also a control through the dish. For DISH network it is format on the remote. You may want to check if that setting is set to zoom or a setting like that. If it is, the TV control of the picture won't change anything. Email me back with more details if this doesn't solve your problem.
Feb 20, 2011 | Televison & Video
HOW CAN I RESET TO THE FACTORY DEFAULTS SO THAT I CAN MAIPULATE THE PICTURE MODE FROM THE REMOTE? PRESENTLY I CANNOT PERFORM ANY PICTURE MODE CHANGES AND THE TV APPEARS TO BE STUCK IN THE NORMAL SETTING,...
If you are connected to a cable box or satellite receiver and it is high definition (hdmi or component cables) you would manipulate the screen size with the hd zoom, aspect, or format button on the cable or satellite company's remote.
If the television remote control also has it you would further adjust the screen size with a view mode, aspect, or format button
Apr 07, 2010 | Televison & Video
After programming my NEW Harmony One Logitech remote I can't get it to change channels on the Dish HDTV DVR along with a bunch of other problems.
To control a Dish Network PVR/Satellite, it needs to be set to respond to the default Remote Address (1).
To reset your Dish Network PVR/Satellite to the default Remote Address:
1. Press SYSTEM INFO on the receiver's front panel. The System Information screen displays on the nearby TV and shows the Remote Address.
2. Using the original Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT.
3. Using the NUMBER PAD, press the 1 button
4. Press POUND (#). If you entered the address correctly, SAT will flash three times.
5. Press RECORD. Make sure the Remote Address you see on the System Information screen is 1.
6. Press the SELECT button on the front panel to close the System Information screen.
7. Your Harmony remote should now control your Dish Network PVR/Satellite box
NOTE: Dish Network PVR/Satellite receivers sometimes have two tuners, allowing them to be used in more than one room on different TVs. Harmony remotes can only control a Dish Network receiver's main tuner while still in the same room with direct line of sight to the device.
What other issues are you having with the remote?
Dec 25, 2009 | Logitech Harmony One Advanced Universal...
Everthing won't be completely shown on my television.
It sounds like you have the picture"ratio" set or adjusted wrong, find the button on your remote labeled "ratio","format","wide" any of those,then just press the button multiple times until you get the full picture that you are looking for. If you have digital cable or satellite those receivers also have picture format adjustments in their menu system that need to be set for your type of TV screen(wide 16:9 or standard 4:3). If you need help, your cable company or satellite provider can assist you with info. Good Luck ! P.S. don't forget to refer to your owners manuals.
Dec 02, 2009 | Zenith Z32X31D 32" TV
I have a runco pl 50dhd aspect ratio problem
Jeff, make sure to check the satellite receiver's set up menu it also has ratio adjustments the need to be set for 16:9 or whatever ratio your comfortable with. Good luck !
Nov 24, 2009 | Refrigerators
I cannot reset the picture to Normal (which should fill the entire screen). f
on what dvd player also has zoom mode set it at 16.9 on all units once no zoom in or do u use dish hd page up down will adjust size also
Jan 31, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Open Questions:
Runco CL-510LT Multimedia Projector Logo
195 people viewed this question
Top Runco Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Are you a Runco Office Equipment and Supply Expert? Answer questions, earn points and help others
