Question about HP DeskJet 9800 InkJet Printer
Printer will not print on 12x12 paper. Just ejects blank page. Selected borderless 12x12 photo paper. Attempting to print text on scrapbook paper from MS Word. It
  • reginaldStjo Feb 19, 2009
    Printer was working fine doing test sheets of 12X12 then it just started spitting out blanks. It actually starts feeding the paper then the paper feed light starts blinking. HP document says this could also mean that it thinks the paper is a different size then what the driver was set at. You push the paper feed button and it spits the paper out and continues to blink. Can't get it to print now
  • ccarezis Mar 01, 2009
    I'm printing form Illustrator on paper 6.25X6.25 and cannot print borderless... it cuts the image in the bottom can anyone help me???
My printer can not print when i give a print command.
Thanks and hope to hear from you.
Regrads
John.
Posted on Nov 27, 2008
I need driver off the printer hp deskjet 9803
my Email ma-bite-toi@hotmail.com
Posted on Nov 07, 2008
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Blank page feeding during print job
Please adjust paper size in printer properties.
Oct 09, 2008 | HP Deskjet 6940 InkJet Printer
Efforts to print 4x6 borderless print result in only top part of photo paper being used and top third of photo being cut off
First thing to try (and I'm assuming you're attempting to print a photo within HP Image Zone & have already selected the 4x6 photo tray? Hint: can be done via printer, properties, printing shortcuts) is to change the 'more options' directly below where you'd selected the 4x6 image size and then change to 'shrink to fit' vs. the default 'crop to fit'... Additional thoughts includes rotating the image (can be done directly on the preview screen...)
Dec 18, 2010 | HP Photosmart 3310 Printer
I am getting paper jam error message after I try to print on photo paper
Some printers detect the type of paper you are using, and print accordingly. Do you have photo cartridges installed? If not, that will trigger an error message. Try putting a smaller amount of sheets in the paper feed- that can sometimes trigger an error message, I've read in reviews. Double check the printer to make sure there, indeed, isn't a paper jam. The type of paper one uses with certain printers can be an issue, so google your printer make and model number and then type something like suggested paper type, or things similar, and you will get some sites that discuss problems with different printers and paper types, and also suggestions of which paper will work well with which printer.
I couldn't find any specific information since I didn't have a make and model number, but hope this general information helps.
Good luck, and thanks for using FixYa.
Sep 07, 2010 | Office Equipment & Supplies
Only printing 1/4 of page
Follow steps below
Load photo paper or plain paper with the print side facing you.
Open the All-In-One Center.
Click the Saved images tab.
From the Creative Tasks section, select Print an album page with various photo sizes.
Click Change the category of layouts listed above.
From the Selected Layouts box, select for example Only Borderless.
Click OK.
Select a paper size for the photos <- use DIN/4 to print on whole page
From the Page Layout area, select a page layout.
Drag the photos onto the page.
Click Printer Settings.
Select the paper size and paper type. <- use DIN/4 to print on whole page
From the Quality menu, select Photo, and click OK.
Click Print Now.
Hope this is helpfull and answers your question.
Aug 31, 2009 | Lexmark X2350 All-In-One InkJet Printer
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Borderless printing kodak 5500, clear coating business cards
Go to printing preferences of the particular program and then select Borderless . THESE ARE THE SIZE OF PAPERS SUPPORTED IN Kodak printers.
  • 3½ × 5 in.
  • 4 × 6 in.
  • 4 × 8 in.
  • 4 × 12 in.
  • 5 × 7 in.
  • 6 × 9 in.
  • 8 × 10 in.
  • A
  • A4
May 07, 2009 | Kodak ESP 5 Printer
The paper size must be set to borderless in both the application (MS Word) and the printer driver. To set borderless printing in the application, follow the steps below.
  1. Click File , then Page Setup .
  2. In the Page Setup dialog box, click the Paper tab.
  3. Under Paper Size, select the appropriate borderless paper size.
To select borderless printing in the printer driver, follow the steps below.
  1. In the application, click File , and then click Print .
  2. In the Print dialog box, click Properties , and then click the Paper/Quality tab.
  3. Select the appropriate borderless paper size.
HINWEIS: Under Paper Type, you cannot choose plain paper and print borderless. Choose photo or brochure paper instead. s.gif
Nov 14, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Epson R1800 prints do not lay out on paper correctly; off center
Hi-
But goal is to have a borderless printout right? when you go to page setup and choose paper sizes when you go to letter size, does it have a slider for letter- borderless? and when you go to file print and and check the print setting/ print layout is fit to page selected?
keep me posted. Thanks!
Jul 12, 2008 | Epson Stylus Photo R1800 InkJet Printer
Printing photos onto 6x4 inkjet paper
which is the model of the printer, not all the printers permite to you do this
Oct 30, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP DeskJet 9800 InkJet Printer Logo
301 people viewed this question
Seeker5211
Seeker5211
