Question about Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon EF-S 17-85MM F/4-5.6 IS USM prevents features from working on 40D
Tried to take photos today with Canon EF-S 17-85MM F/4-5.6 IS USM lens on Canon 40D, aperture reads 00, can't use aperture priority mode as won't change from 00, displays 00 in all modes including the Fully Auto mode, cannot change AF modes nor drive modes while this lens is on. I used another lens and it works as it should. I will try cleaning the contacts but what else could it be? Only 6 months old.
  • 67 Answers
Something sounds strange about this. aperture 00 is an invalid aperture value. stands to reason if that is the case the camera would complain about it. via error code. being that its only six mos. old i would give canon a ring.
Posted on Dec 11, 2008
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CHoQFjAA&url=http%3A%2F%2Fmedia.the-digital-picture.com%2FOwners-Manuals%2FCanon-EF-S-17-85mm-f-4-5.6-IS-USM-Lens.pdf&ei=mncUUJ3EOYnm9ATK2YCQBA&usg=AFQjCNHJaSazpAGakXjAkYnWzbV5ygWbrQ&sig2=SYGmYEaxlwZ3Rhv2yzgFZA
Jul 28, 2012 | Cameras
Lens not communicating with camera
contact problem or lens diaphram blades problem. First try to clean the contact with the pencil eraser. If the problem isn't solved. send it to canon it should cost you about 100.00 to repar.
Mar 14, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Auto focus does not work on the 135mm
hi i am sagha a camera repairer from mumbai, i have gone through such problems much oftenly,in your case i think it is the internal problem with the flex board inside the lens which is multitwisted on metal plate after prolonged use becomes stiff & brittle and creates hairline cracks on the pcb which in turn breaks the tiny tracks & leads to malfunction at 135 mm.
May 26, 2009 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Cant adjust below f/5.6 on a eos 40d
You are correct in thinking that it should be possible to set the aperture wider than f/5.6 at the wide end of the zoom range.  My best guess is that the lens is defective.  I'd suggest returning it for a replacement.
Dec 21, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Is there a manual for Canon EF-S 17-85MM F/4-5.6 IS USM Lens ?
there is a manual for the 40d kit with that lens. probably does not have exactly what your looking for but there is some useful info about that lens here is the link .
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=215&modelid=17779#DownloadDetailAct
Dec 09, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Lens won't allow me to change aperture & several other functions on camera
The USM engine may be out of order, or there is a bad contact in the lens.
Oct 11, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
My Canon 40D can't handle bright yellow and reds. It blurs the detail and overly saturates the subject (flower close-ups) - so that the bright red poppy is overly saturated and lacks detail even though...
By the way are these RAW images? What type of lense are you actually using, check this
EOS-1Ds Mark III EOS-1D Mark III EOS-1D Mark II N
EOS-1Ds Mark II EOS-1D Mark II EOS-1Ds
EOS-1D EOS 5D EOS 40D
EOS 30D EOS DIGITAL REBEL XSi/EOS 450D EOS DIGITAL REBEL XTi/EOS 400D DIGITAL
Compatible Lenses
EF 14mm f/2.8L USM EF 28-70mm f/2.8L USM
EF 14mm f/2.8L II USM EF 28-135mm f/3.5-5.6 IS USM
EF 20mm f/2.8 USM EF 28-200mm f/3.5-5.6
EF 24mm f/1.4L USM EF 28-200mm f/3.5-5.6 USM
EF 28mm f/1.8 USM EF 28-300mm f/3.5-5.6L IS USM
EF 35mm f/1.4L USM EF 70-200mm f/2.8L USM
EF 50mm f/1.2L USM EF 70-200mm f/4L USM
EF 50mm f/1.4 USM EF 70-200mm f/2.8L IS USM
EF 85mm f/1.2L USM EF 70-200mm f/4L IS USM
EF 85mm f/1.2L II USM EF 100-400mm f/4.5-5.6L IS USM
EF 100mm f/2.8 Macro USM EF-S 60mm f/2.8 Macro USM
EF 135mm f/2L USM EF-S 10-22mm f/3.5-4.5 USM
EF 180mm f/3.5L Macro USM EF-S 17-55mm f/2.8 IS USM
EF 200mm f/2.8L USM EF-S 17-85mm f/4-5.6 USM
EF 200mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6
EF 16-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II
EF 16-35mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6 USM
EF 17-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II USM
EF 17-40mm f/4L USM EF-S 18-55mm f/3.5-5.6 IS
EF 24-70mm f/2.8L USM EF-S 55-250mm f/4-5.6 IS
EF 24-105mm f/4L IS USM -
Jun 30, 2008 | Canon Cameras
Sharpness problem
That should be a very sharp lens, only thing I can think of is that you have a bad copy. It can be sent into Canon where they will fix it.
First, I would try giving it a full cleaning, and taking shots in good light on a tripod at 17-80mm, just to make sure its really the lens
Dec 15, 2007 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon EF-S 17-85MM F/4-5.6 IS USM Lens Logo
261 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
