Question about Mitsubishi WT-42311 42" Rear Projection Television
Mitsubishi WT42311 Convergence IC replacements didn't work
The horizontal red lines on my 42" tv won't line up. It will let me adjust the vertical lines left and right, but not the horizontal line. My tv wasn't moved or dropped but I did smell a slight hint of something burning the first time this problem surfaced. We did replace both convergence IC's and the it didn't correct the problem.
Any suggestions what the next step might be? Thanks in advance for your help.
  • chrisbristow Nov 01, 2008
    It was helpful but I found the ERROR AMP 110V/20mA had gone out. I replaced it and the TV would turn on for a few minutes and then shut off, if I immediately turned it on it would shut off in a few seconds. The picture wasn't as good either.
    I did replace the 5 amp pico fuses even though they seemed fine on my multi meter and now the tv won't power up. Clicks on and off almost instantly.
    Any other tips? Thanks again.
  • d7192003 Feb 18, 2009
    Same problem except I can not adjust red convergence left or right, only up and down. I installed both IC's STK392-110 with new and no change. Sounds like one solution will solve both of our problems.
    Thanks, Dale
I had the exact same problem. I went to TVrepairkits.com and bought the kits for about $60. I bought both a desoldering and soldering iron at RadioShack.
KEY: The entire chasis slides out of this baby, held in by 6 screws! This made it hugely convenient to locate the convergence chips and have access without virtually any additional assembly.
I was getting ready to remove the convergence chips when I noticed a bad solder on one pin. I figured this might be the problem as vibration had temporarily fixed it in the past. The resoldered that one pin and re-assembled.
Fixed! Set works great again.
Posted on Dec 12, 2009
    Problem Solver:
  • 13 Answers
We need a instruction manual
Posted on Nov 02, 2008
  • Mitsubishi Master
  • 8,617 Answers
The pico fuses will usually need replacement when the Ics go out they take out the two 5amp pico fuses.You can get replacement picos at the following link.
http://servicemanuals.vstore.ca/
Posted on Oct 11, 2008
How do you set convergence
What is your Make and Model number?
Mar 18, 2010 | Televison & Video
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
My tv has many lines in the screen. what kind of problem is this and what does it need to be fixed?
You may be suggesting a convergence problem..when the blue and red boxes will not center. You have bad grounds on the convergence ICs. Resolder or replace theses ICs. Or you may be asking about a problem in the vertical section. Vertical problems will appear as horizontal lines on the TV. In this case you have bad capacitors near ithe vertical IC and must also resolder or replace the vertical IC.
Nov 15, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS50805 Serial # 102718 No red in picture
Replace the convergence ICs your model uses two STK392-040 Convergence ICs. You can get replacements at the following link with instructions.
Dec 28, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Convergence
you need to replace both convergence ICs they are STK392-110 you can get replacements at the following link with free installation instructions so you can do the repair yourself.
Aug 23, 2008 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi rear projection tv
replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Hitachi 43FDX01B Convergence Problems
Hitachi remote part # HL01643........I like the original remote
to do adjustments.................T.
Aug 06, 2008 | Hitachi 43FDX01B TV
Can't control red convergence on VS-45607
The STKs are three channel ICs they each control horizontal and vertical of one color the third channel controls part of green and the other half of green is controled by the other ICs third channel. Its customary for the Ics to fail and only have one channel bad in the IC. However its recomended to change both because of the bad Ic having green it can actually weaken the other IC and that one will fail shortly.
Aug 03, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Sony tv model no. KV - 19 APR 2
This is for a different model, but I had thin horizontal lines in red and had to adjust the tube for red. You may have a similar adjustment on your set.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Aug 01, 2008 | Sony KP-48V80 48" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
763 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
