Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
DF light on continuously
Hi, I have a GE profile series (model TFX 27PF) side by side refrigerator with a self diagnosis module. The DF (defrost) light is continously blinking. So far, the freezer and the refrigerator seems to be working properly. What should I be worried about? Thank you. NJ
  • njasani Oct 11, 2008
    It worked! The DF light is out. Will keep fingers crossed to make sure that it is not a temporary fix. Thanks again.
  • njasani Oct 13, 2008
    The problem is back! What else can I do? NJ
    Genius:
  • 3,422 Answers
HI,
Please make sure that the cold knob is turned up.Next unplug all the cords of your refrigerator for 30min and allow it to reset.
Let me know the result.
Posted on Oct 11, 2008
  • Priya darshan Oct 11, 2008
    Thank you for using fixya:)
    Genius:
  • 1,550 Answers
You have a defrost problem which can be a heater, timer or defrost thermostat.
Take everything including the shelves out of the freezer and remove rear panel.
You can see a uniform frost on the coils.
My GE Profile refrigerator (TFX 27PPBA WW) will not continue to cool. I have to turn off for 5 seconds and then back on. It will cool and run for awhile and then stop running.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
Why does my ge fridge beep and displays DF for defrost?
I hope someone has an answer. Mine startes doing the exact same thing. I turned it off for about 20 minutes. When I turned it back on the DF is nstill blinking. I think we have a problem
Nov 17, 2010 | GE Profile PSI23NCR Side by Side...
MY GE PROFILE MODEL PSS26LSRE SIDE BY SIDE FRIGE CRISPER IS FREEZING UP
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE Profile PSS26NGS Side by Side...
I have an older GE Profile side by side not defrosting, have continuity in element when warmed thermostat kicks off and I have replaced the timer, still not defrosting. Model #THP21PBSMWW S/N SL238841
Need to check and see if the element is heating up when it goes into defrost. If the thermostat is bad it will not go into defrost. I purchased a new heating element for my GE and it came with the element and thermostat together. Also make sure the fan is running in the freezer this moves the heat through the coil as well as the cold temp when in freeze mode.
Nov 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge fridg and freezer not cold; just cool; TFX 20JR; what could the problem be?
The problem is probably the defrost heater . This model is at least 12 yrs. in age . Pt # WR51X442 is the part number for the heater and harness kit . These parts are located behind the inside rear lower freezer panel . First , make sure the freezer fan is working . If not Pt # WR60X10008 is the freezer fan motor .
Sep 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost build-up freezer back wall
Hi, You will need to remove the rear panel and test the defrost heater and the bi-metal switch. The defrost heater is a very common problem with this model. You can check continuity on both the heater and bi-metal to detern which one need replaced. The bi-metal switch needs to be tested while it is could. If both of these parts prove to be ok, you will need to change the mother board.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 24, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer is freezes it self up and a giant block of ice froms but refrigerator is warm
Hi: your model number dosn't get a match on a search. Did you check the defrost heater? I hope this helps Jeff,
Jun 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice will not come out
check switch or auger call service
Mar 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
231 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
