Question about Amana Dryers
My dryer wasn't drying like normal. It took more cycles to dry my laundry. I checked the exhaust and found the exhaust connection "hose" wasn't adequately connected and had a few small holes in the tin foil-type surface. I used duct tape to cover the holes and taped the hose back on -- both to the dryer and then the outside exhaust pipe. I put a load of laundry into the dryer and pushed the timed-drying cycle start button. The dryer started, but made a klunking noise and quit. I went to push the start button again, and the machine made a noise when I pushed the button in, but didn't start. Any thoughts? Thank you. Christena O'Brien Eau Claire, WI (715) 836-7329 christena.obrien@ecpc.com
  • 706 Answers
Hello Chritena,
Based on your description.. I'll throw some ideas at you for you to try.. Not sure if you have an electric or gas dryer but that shouldn't make a difference .. Try unhooking the exhaust for a few minutes and start the dryer.. If it is a gas dryer.. do this with plenty of ventolation since the byproduct of gas combustion is unhealthy.. If it is electric.,.it isn't healthy but it isn't bad either.. let the dryer run until you feel good hot air flowing out.. If the flow is weak then chances are you have either a blower problem or restriction in the blower system inside the dryer,, If you get good hot air flow, then you probably have a restriction in your ductwork or the outside vent cap itself.. These are the main areas to check.. let me know the outcome of these checks and if they fail to resolve the problem.. will dig a little deeper.. Next time, please provide the model number too.. it helps focus in on the specific details...
Regards
Posted on Oct 11, 2008
It takes the dryer too long time to dry the laundry even on 80 degrees.
I took my dryer apart and found the vent shoot and exhaust needed cleaning. Also the exhaust vent pipe going out side should be cleande.
Dec 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer will not shut off in any 'auto' mode. Time display ticks down, then jumps up again and keeps running. Dryer does works properly when 'timed dry' is selected. Checked and cleaned exhaust vent. ...
How long is the vent from the dryer to the outside? Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dry-ability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
Jul 14, 2010 | Samsung DV337 Electric Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Jun 17, 2010 | LG DLG7188 Gas Dryer
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Apr 01, 2010 | LG DLG5932W Gas Dryer
Whirlpool dryer, it takes 2 or 3 cycles to dry a full load, the clothes are warm and when I disconnect the rear exhaust and turn it on it blows pretty good, it never took so long to dry the clothes
check the vent hose to the outside,especially if there's been siding installed on the house and the vent has one of those plastic guards by the outside exhaust,for keeping birds out,this can plug around the vent and build up with wet lint,run it without the hose on and see if drying time comes down to normal again,then you know the outside vent is the problem
Jan 26, 2010 | Dryers
My Miele T8322 Tumble dryer turns off before the clothes its fully dry even in Extra Dry mode. The vent pipe is clear. Is there any kind of adjustment or do I need to get a new sensor under warranty...
IS THE DRYER PUSHED UP AGAINST THE VENTING IN THE BACK OF THE DRYER? IT MAY BE CRIMPING THE EXHAUST MATERIAL CAUSING A RESTRICTION.
IF THAT IS O.K., DISCONNECT THE EXHAUST AND RUN A LOAD OF LAUNDRY THROUGH A NORMAL DRY CYCLE.
IF THE DRYER DRIES THAT LOAD O.K., THERE IS A RESTRICTION SOMEWHERE IN THE EXHAUST. ALSO, CHECK THE LINT TRAP. IF THERE IS A WHITE CLOUDY FILM ON THE LINT FILTER, TAKE A WIRE BRUSH AND CLEAN IT OFF. IT IS RESTRICTING THE AIR FLOW AT THE FILTER.
CHECK THE LINT FILTER HOUSING FOR A BUILD UP OF LINT. IF THERE IS, USE A CENTER CARDBOARD FROM WRAPPING PAPER ATTACHED TO THE END OF THE VACUUM HOSE. FLATTEN THE CARDBOARD TO FIT INTO THE FILTER SLOT AND CLEAN OUT THE LINT.
Apr 22, 2008 | Dryers
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Clothes are not getting dried.
Check your dryer ducting.  If you have not cleaned your dryer ducting recently, it may be time to do so.  In order for a dryer to work correctly, it needs proper air flow.  A lot of people don't realize that just seeing the heating element glowing and the air blower fan running isn't enough to get your clothes dry.  If the dryer does not have a proper exhaust the air has no where to go.  All that air that is normally exhausted out of the dryer vent carries all the moisture from your clothes with it.  If the exhaust is clogged, all that moisture stays in the dryer and the dryer works harder to try to heat.  Your clothes stay wet and, eventually, your thermal cut-out and/or heating element will blow.  You could also have a clog somewhere inside the air baffle in the dryer.  This is where the exhaust fan is.  Lint can get trapped in this area clog up your dryer.  Here's a simple test you can perform:
1. Remove the exhaust ducting from the back of the dryer and dry one load in this manner, letting the dryer exhaust freely into your laundry room or garage.  Feel the air leaving the exhaust port on the back of the dryer.  The air should eventually heat up and be rather forceful.  If your clothes dry faster, then you know you have a clog somewhere in the ducting.  You will need to trace it all the way to where it leaves your home at the exhaust vent outside.  If it is run in a crawl space, make sure it is suspened from the rafters and not on the ground.  Leaving it on the ground makes it susceptable to rodents wanting to chew through to get inside your dryer.  Dryers provide a great source of warmth and bedding material (lint) and mice love them.  Also ensure thre are no sags in the line that will create areas for lint to collect.  If you find that your clothes are drying better, take care of the problem immediately.  Running a dryer for extended periods of time exhausting in your home can add unwanted humidity, dust and potential mildew.
2.  If your dryer still is not drying sufficiently, or you have very weak air flow coming out of the rear exhaust port.  You will need to remove the air baffle housing and check for clogs.  I experienced a home where a dryer would not heat, but the ducting was clear all the way to the exterior vent.  The heating element was also heating properly.  When I removed the ducting, however, there was barely any air coming out of the dryer.  When I inspected the air baffle housing I found a mouse nest as big as a shoe box and compacted to the point that I had to disassemble the unit to get it out.  You will find that MOST insufficient drying problems are directly related to the cleanliness of your dryer interior and your dryer ducting.  Not to mention, the potential for house fires if you do not maintain a dryer properly.  I have also found situations where lint became so backed up in a dryer that there was evidence of multiple fires inside the dryer.  Take the time to double check your dryer venting and replace those old plastic worn out vent hoses with new semi-rigid metal hoses.  They resist crimping and crushing and will not clog as easily.
NOTE: It is normal for the heating element to cycle on and off.  This is actually a symptom of a "healthy drying cycle".
I hope this information is helpful to you.  If you find no obvious signs of clogs or obstructions, let me know.  You may have something else causing your problem.
Oct 31, 2007 | Dryers
Drying cycle - laundry comes out wet!
possibly that drain pump is not pumping out - washer dryers take in water during the dry cycle. check filter
Mar 17, 2007 | Bosch Classixx WVF 240S Front Load Washer...
Dryers Logo
70 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you an Amana Dryer Expert? Answer questions, earn points and help others
