Question about E-Machines eMachines Desktop PC
Emachines M2350 memory
I have replaced the mother board of my M2350, and I have a new 1GB RAM module to put in it. There are 2 modules in it currently, one to the inside, hard to get at, and an additional outside which is hidden behind a removable cover. Can the 1GB module be inside and a 256MB module be outside, or should it be reversed?
  • E-Machines Master
  • 4,338 Answers
It should work ok either way . But I would remove the 256 mb. and run with the 1 GB.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 11, 2008
New memory nx6110
Did you remove and replace 1 or 2 RAM modules? There are 2 modules installed. One is internal and one is external. Both MUST BE OF THE SAME DENSITY OR THE LAPTOP WILL NOT WORK. You will need a second 1GB RAM Module, then use the link below to download the service manual for your laptop. Accessing the internal RAM module is fairly easy...follow the directions and you will have not problems. You CAN remove the internal one and operate the device on the single 1GB module, but I would recommend if you do that, you put the 1GB module in the internal slot. Then later, if you wish, you can add more RAM without additional disassembly. By doing this you will at least double your RAM from the 512MB you had to !GB. You can double it again with the second RAM Module to 2GB later.
.GO Here. Find Remove/Replace procedure for Internal Memory Module.
Nov 10, 2013 | HP Compaq nx6110 PC Laptop
Repeatedly long beeps
If you upreage the RAM to 2Gb by inserting a 2nd 1Gb memory module then the 2nd RAM maybe faulty or incompatible.
If you insert a 2gb memory module to replace the 1Gb memory module then it maybe faulty or incompatible.
Try using the same make and RAM speed as the original RAM module.
Dec 29, 2012 | Biostar G31-M7 TE Motherboard
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
Ram issues with biostar n68sb-m2s motherboard
To determine if a 1Gb RAM module is faulty insert one RAM module in the motherboard at a time. If the both 1Gb RAM modules work then the RAM modules from different manufacturers are incompatible with each other. Try using RAM modules of the same make and speed.
Jul 09, 2012 | Biostar Computers & Internet
RK549AA-ABA SR2170NX problem: i think my second slot for ram is no good. i'm supposed to be able to install 2 gb max . I bought 1gb ram to install in slot # 2 but it doesn't work. can i install...
Is the 1Gb RAM you purchase the same make and speed as the original? If not, they may not be compatible with each other or the new RAM module may be faulty.
Try removing the RAM from slot 1 and insert the new 1Gb RAM module in slot and boot up your laptop to test the new 1GB RAM module.
Installing a single 2Gb RAM module should work.
Dec 29, 2010 | Computers & Internet
Upgrade ram
In order to upgrade the ram of your desktop. First you have to check the ram specifications. If wrong specifications the desktop will not work. To check you have to remove the ram from your desktop by removing the screws behind your desktop. Open the lid and you will see the contents of your desktop. Besides of your processor, there is ram installed. Unclip it. Then bring that ram to the computer shops. Purchase a ram higher than the ram installed in your desktop. Afterwards, install the new ram to your desktop. Good luck.
Sep 13, 2010 | Acer Aspire T690 (AST690UP820A) PC...
Adding an additional memory module to laptop...wont start!!!
The problem is that your laptop only supports 2 GB of RAM. If there is not a newer bios allowing more then 2 GB is the max you can go. Since you put the 2 GB in one slot then the other slot will be useless. It wouldn't matter how much you put in the 2nd slot because the bios already says you have 2 GB on board and will not accept anymore. Sorry.
Apr 08, 2009 | HP Compaq Presario C500t Notebook
Memory support for your d845gvsr board is as follows:
Memory speed - 333MHZ, 266MHZ and 200MHz.
Memory type - DDR SDRAM
Max Memory - Capacity of up to 2 GB
Memory Slots - 2
Memory module size is 1GB (1024MB) for slot.
Thank you,
Let me know if you need anything else.
Mar 02, 2009 | Intel Motherboard
RAM has to be
Four 184-pin DDR DIMM sockets
Supports PC3200 (400 MHz) /PC2700 (333 MHz) / PC2100 (266 MHz) DDR DIMM type
Maximum HP/Compaq approved memory module is 1 GB
Maximum HP/Compaq approved memory is 4 GB
It has to be the same.
• If you are replacing a memory module, put the
new memory module in the same memory slot
from which the old memory was removed.
• If you are adding a memory module, install the
new module into the socket nearest the
preinstalled module, and install additional
modules in the next available sockets
Jan 14, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
