Which button i want to see ho is online at yahoo messenger 9.0,which buttons shouli press?
  • 661 Answers
It doesn't work like that.......
although I think that yahoo has some usergroups and forums, you could explore, however you cannot just get a list of who's on...
you can get (by permission) to see if one of your Friends is online, but they can still choose not to appear online if they wish.
Posted on Oct 11, 2008
My yahoo messenger is locked 81003003
HI.......................
it has errors
Messenger "9" 1st version was in Beta (testing) form. The newest version is not, But it's not working well either. Stick to 8.1 until they work out the Bugs. Including people using 8.1 trying to message ones with 9 or reverse they are having compatibility problems; like text not showing,pictures not showing. It shuts down on Vista users , not allowing people to log in.Web cams do not always work. Many things do not work or are missing that YM 8.1 has. It Seems for Vista users it is so buggy Yahoo is giving up on it and are no longer trying to fix it. http://www.ymessengerblog.com/blog/2008/...
You need to remove version 9 completely 1st to Get version 8 to work.
Use this method: Start,My PC, C drive, open Program files.Next open Yahoo file then Messenger file.Click on UNWISE to Un install messenger 9 completely. Do not just delete yahoo file as this can cause problems with other Yahoo programs.
Download the newest 8.1 here http://download.yahoo.com/dl/msgr8/us/ym...
Your contacts list and messages are stored online and will be there when you return to 8.1 messenger.
Another big problem is with the latest update for Flash Player
Flash player 10 Does have conflicts and is causing things to not load or just crash upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel, then download the older version.
http://www.download.com/Adobe-Flash-Play...
Some people are losing signal,things fade out, freezing up or getting disconnected . This can be caused my running low on virtual memory! You can increase your memory by going to start button, settings, control panel, system, advance tab, performance, advance tab, virtual memory, change it, make it 1500 kb or higher, In both boxes, click apply then ok . This applys for all instant messengers,MSN, Yahoo,skype ect.
More help can be found here; http://www.freecreed.com/userid.html.
GOOD LUCK........................
Sep 22, 2011 | Yahoo Messenger
Ho to open yahoo acount
Try this.
1. Click on Yahoo Messenger app. 2. Once it opens, Click on " Get a new Yahoo ID" button. 3. Fill the registration form and get the new account.
Sincerely, Thiyaga
Aug 18, 2011 | Yahoo Messenger
Yahoo messenger error 81003016
HI welcome to fixya free solutions. you are getting this error because of connection error! try to go to messenger then connection preference, its on the top left of your yahoo messenger..choose connect directly to the internet then apply. mess 9 noted for this error.
Messenger "9" 1st version was in Beta (testing) form. The newest version is not, But it's not working well either.Try using 8.1 "the newest before 9", until they work out the Bugs. Including people using 8.1 or older versions trying to message ones with 9 or reverse they are having compatibility problems; like text not showing,pictures not showing.Chat rooms not found or opening. It shuts down on Vista users , not allowing people to log in.Web cams do not always work. Many things do not work or are missing that YM 8.1 has. It Seems for Vista users it is so buggy Yahoo is giving up on it and are no longer trying to fix it. http://www.ymessengerblog.com/blog/2008/…
You need to remove version 9 completely 1st to Get version 8 to work best.Left over files and fragments from using control panel to remove messenger can cause problems/conflicts with the new download.
Download the newest 8.1 here http://download.yahoo.com/dl/msgr8/us/ym…
And it works well with Vista.
Flash player 10 Does have conflicts and is causing things to not load or just crash upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here.
http://www.download.com/Adobe-Flash-Play…
Some people are losing signal,things fade out, freezing up or getting disconnected . This can be caused my running low on virtual memory! You can increase your memory by going to start button, settings, control panel, system, advance tab, performance, advance tab, virtual memory, change it, make it 1500 kb or higher, In both boxes, click apply then ok . This applys for all instant messengers,MSN, Yahoo,skype ect. And yahoo games.
If none of these work for you then kindly do comment back to me.
Aug 05, 2009 | Yahoo Messenger
Cannot see the message i typed in yahoo messenger 9 and other versions?
If uninstalling and installing the yahoo messenger also not work then follow the below two steps STEP -1
go to Start Button - Run - type regsvr32 jscript.dll - then press OK
STEP-2
go to Start Button - Run - type regsvr32 vbscript.dll - then press OK
now your yahoo messenger will work normally
Mar 13, 2009 | Yahoo Messenger
Whi sing in get the message ecountered a conection problem . network connection and the click try again {81003004} X(((((((((
Messenger 9 for Vista users and XP users with 9, With windows newupdate to their FireWall, Has so many glitches. Yahoo has given up andno longer trying to fix it. http://www.ymessengerblog.com/blog/2008/...The updated Firewall will not let Messenger download correctly.And iscausing 8.1 users to have major problems now. The only option they areleaving users with is reverting back to 8.0 or 7.5 these and allversions can be found here;http://www.filehippo.com/download_yahoo_... They are releasing a new version 10 (untested) as usual!
You need to remove version 9 1st to get another version to work. Toremove Messenger version Use Unwise located middle of page of MessengerFolder.. Your contacts are stored online But if you want to save yourold messages archives,they are saved on your PC in the messenger fileyou are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
error 81003004 is a connection problem,
Connection Problems;
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if thisis checked, uncheck it.check connect directly to internet then click ok
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
This person asked same Q.
Asker's Rating: Asker's Comment: Thanks..but I already uninstalled thenew version and went back to 8.1 and it seems to be working just fine. It was always logging on and off and bogging mycomputer down.
Mar 12, 2009 | Yahoo Messenger
My yahoo Im stops working
Use info below to delete present version completely then if you want to try 9 again and are using Vista go here for help.
http://www.ymessengerblog.com/blog/2008/10/27/installing-90-on-windows-vista/
Messenger 9 for Vista users and XP users with 9, Mess 9 has many unsolved problems and missing features that messenger 8.1 or 8.0 has. Plus now the updated Windows Firewall will not let Messenger download correctly.And is causing 9 users to have problems now.. The only option that might help is going to the control panel and turning off the firewall to download and install then turning it back on.Then click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save.
.If the fire wall still causes problems,then revert back to 8.1 or 8.0 these and all versions of messenger can be found here; http://www.freecreed.com/ymsgr-archive.html
You need to remove version 9,or present version, 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.Make sure Automatic is checked! then continue to uninstall..Or use control panel ,Vista-program features or XP-add/remove this is the 2nd best way. If you just delete the Yahoo file to remove messenger,you will also lose the shared file that contains things needed on other Yahoo sites. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
The latest update for Flash Player to #10 Is causing things to not load,Can not log in,or Messenger just crashes upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here. http://www.adobe.com/support/flashplayer/downloads.html
Here is the best help/fix it sites I have found so far for Messenger,chat,and Yahoo in general. http://www.helpbytes.co.uk/ This one for Vista http://www.vista4beginners.com/tips-and-tricks
many problems solved using this link http://www.freecreed.com/
Dec 11, 2008 | Yahoo Messenger
I need to get my contacts back
Your contacts list is stored online, you can change versions and contacts transfer.Not sure what you mean by disconnected ( from what? yahoo,messenger,) Do this,
Dec 10, 2008 | Yahoo Messenger
My yahoo messenger application is not responding
http://help.yahoo.com/l/us/yahoo/messeng...
Dec 09, 2008 | Yahoo Messenger
Yahoo Messenger
make a new user account in your window some time you can't open your messenger becouse of virus .dear make new user account of u r window login there and run there 100% it will work .plz improve my rank with reply
Dec 03, 2008 | Yahoo Messenger
Computers & Internet Logo
David Payne
David Payne
