Question about Panasonic Lands Phones
Hi, I have a Panasonic Kx-tg5971al model phone. the problem is that no button works on the base unit anymore. the hansset work fins, but not the base. CAnnot listen to messages, cannot dial, nothing works, it is completely death other than the leds do blink (eg if a new message is received).... so it is pluged to the electricity socket!. Not sure if it is a setting or something else, but it used to work, don't know what's happened to it. Many thanks, Beatrice
Have a Panasonic KX-TG1061C with 3 handsets. Handsets work perfectly. None of corded base unit buttons work.
to turn off night mode
do not think night mode would cause your problem.
check dialing mode #120
When you unplugged the base unit did you pull out the ac adapter for about 30 seconds to reset the base unit ?
Jan 04, 2015 | Panasonic Lands Phones
One handset works, the other displays
Pull the battery out of the afoul unit. Let sit for 5 min. Put battery back in unit and set it in the base unit.
Feb 28, 2009 | Panasonic KX-TG1033S Cordless Phone
I have the panasonic kxtc1175bxb cordless phone pair the handset
sorry, it seems that they have no manual for this model online yet. however, the procedure to reset handsets might work if you go to page 35 of the manual ("") good luck!
Feb 04, 2009 | Panasonic KX-TG1033S Cordless Phone
Need hnew handset for Panasonic KX-TG2357 - 240k
Available from these sellers
Jan 10, 2009 | Panasonic KX-TG2357 Cordless Phone
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
3 Handset:
Press {OK}, then wait until a beep
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Problem not solved yet, continuing to search for the disc, as the ring tone is driving me mad!
Jun 29, 2008 | Panasonic Lands Phones
No link to base Panasonic KX-TG2357
Astoundingly, the KXTG2357 works only with the original handsets it came with! You cannot replace a handset by buying another one (same model, of course) and register it with the base. How ridiculous is that? It's like buying a lamp that works only with the bulb that came with it. Replacement bulbs won't work. Well, Panasonic is one company I won't be dealing with anymore!
So, the solution is to get along with one less handset, or buy a new phone unit!
Jan 05, 2008 | Panasonic KX-TG2357 Cordless Phone
DeRegistering a Damaged Cordless Phone???!!!!
I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
Nov 05, 2007 | Panasonic KX-TGA600B Cordless Expansion...
Lands Phones Logo
51 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
