Question about Husqvarna Designer I
External Floppy Drive
Since buying a new computer, (the other one bit the dust) the external floppy drive is not recognized by my 4D program. I have tried XP and Vista and it makes no difference. I do not want to spen $500 to convert to USB although I feel that may be my only hope.
  • DonnaJW Oct 22, 2008
    Thank you, thank you, thank you!!!
  • 201 Answers
You don't have to convert your Des1 to USB. Make sure you have the correct machine and transfer method selected in 4D Configure. I used to have trouble writing to the floppy sometimes in my old Customizing software. What worked for me was: Don't put the floppy in the drive yet; hit the "Write" button; you will get a "Disk not Found" or something like that message; put the floppy in then; and click OK or the best option you will be offered. That seemed to make the program kick-start the "look for floppy" process. I belong to another Designer 1 support group and recall this subject has been discussed some time back. If I find out more information for you, I will pass it on.
Pamsquilt
Posted on Oct 19, 2008
How to download embroidery from floppies to a stick
the floppy disc format will be different to what the external hard drive uses or a stick uses. check with your local it nerd shop and find out how it can be done.
Apr 01, 2015 | Sewing Machines
EXTERNAL FLOPPY DRIVE FOR DESIGNER 1 ?? HOW TO
Sorry, an external floppy drive will not work for a Designer 1. You would have no where to plug the cable in to. The internal floppy drive is quite expensive. You might want to look around for a used Designer 1. You can probably find one for $400-$500. Replacing the floppy drive on yours would cost you almost $400 depending on the local dealer pricing.
Jun 27, 2014 | Husqvarna Designer I
I have floppy disk for all software can I get it on cd?
best solution would be to go on ebay and buy a usb floppy drive, that way you can still use and open the floppies. either that or buy the floppy drive and fit it into the computer.
most laptops and desktops support usb floppy drives
they quite cheap too. good luck
Jun 16, 2012 | Husqvarna Rose
My XP computer and my Windows 7 do not have ports for a disk so that I can transfer designs for the Designer I. What do I need to do to be able to transfer these designs? Is that what a reader/writer...
If your computor doesn't have a floppy drive, you can buy an external floppy drive that will just plug into one of your USB ports on your computor. You can probably pick one up for about $30.
Apr 28, 2011 | Husqvarna Designer I
I just bought a used Designer 1 with Customizing Software. The customizing program recognizes the a:Floppy external drive to receive designs. When I try opening the Disk Manager so I can download them,...
Don't insert the floppy disk in the drive until you are ready to actually do the writing to disk. If it still won't recognize that there is a design disk there, try re-formatting using disk manager - you will lose whatever designs are already on the disk, so make sure to save them to your hard drive using Windows Explorer first.
You might just need updated drivers for your floppy drive. Try an internet search by searching for Husqvarna Customizing drivers, or something like that.
Nov 08, 2010 | Husqvarna Designer I
I just bought a used Designer 1 with customizing software. Customizing recognizes my external a: Floppy Drive. When I go to Disk Manager to download to a fresh floppy, Disk Manager doesn't see the...
What worked for me was to not put the disk in the drive until I was ready to write to it. Sometimes this would be enough to make Disk Manager find the disk. If it didn't, I would re-format the disk. Re-formatting seemed to force the software to go look for the disk. This worked for me because I did not store all my designs on floppies. I only used the floppy to load what I was going to be embroidering out at that time. All my designs are stored on the hard drive which is backed up regularly, and are readily accessible for writing to the media I use for my D.1.
My D1 still runs designs from a floppy. I have the 4D software. What computer extension do I need to save my designs to, in order for the sewing machine to be able to stitch them. So far I'm having no luck...
Your Designer 1 will read none of the file formats you listed. It uses .shv which is a special file type created just for the Designer 1. Some embroidery sellers offer this format, but most do not. You don't need the .shv if you have the 4D software. When you purchase designs, you can buy almost any format you want and your software will deal with it. Most Husqvarna Designer owners purchase designs in .vp3 or .pes format. Avoid .art designs.
You need to set up your software using the Configure module. You can access this either by locating your 4D software folder on your hard drive - in that folder there should be an .exe called Configure - or use a link in your normal 4D screen once you open the program. Look for the icon along the top that looks like a screwdriver and pliers (or something like that). In Configure use the Send 1 tab to tell your software that you have a floppy disk Designer 1.
When you want to load designs for your sewing machine, open 4D Disk Manager (it will be in the drop-down Accessories box using the arrow beside the Configure button). You need to have the correctly formatted floppy disk in your computer's floppy disk drive. If you don't have one, you can format a blank one from within the Disk Manager module. Most importantly if you are using a floppy that already has been used in your Designer 1, you need to use the Read Disk icon along the top. The designs already on your floppy are read into the program. You can then add whatever designs you want by using the Open (icon showing an open manilla folder) or View (looks like a blue camera) buttons. Then you choose the Write Disk button to put not only your newly added designs on the floppy disk, but to also put back the ones that were already on it. Click "Yes" when asked if you want to erase designs already on the disk. It is quite safe provided you read the disk into Disk Manager first, as described above.
Jun 10, 2010 | Husqvarna Designer I
I have (pfaff 7570) pc designer software on floppy disk, no floppy drive, where can I get a download for the software
You will need to purchase an external floppy drive. There is no download available for software.
Sep 20, 2009 | PfaFF Creative 7570
Internal flopppy problem with Designer 1 embroidery machine
Dear bjdouce,
Push the floppy drive lid inwards and do the following:
First of all, check for any visible thread or dust inside the floppy drive.
Secondly clean the drive by blowing it with compressed air.
If this does not help, it is time to upgrade your machine to USB. Great to work with. Cost: plus minus $500.00.
Good Luck
Nov 15, 2008 | Husqvarna Designer I
Sewing Machines Logo
271 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
