Question about Samsung YP-Z5 MP3 Player
Samsung YP-Z5F MP3 player malfunction
Cannot charge the YP-Z5F player. When connected to PC via USB seems to start however mesage, "Low Battery USB Disabled", displays.
Whilst connected can view contents, play songs etc, however even after 8 hours of connection same message appears.
Computer does not recognise that player is connected.
  • 1 more comment
  • Anonymous Jan 24, 2009
    i have the same problem too.
  • nedned1212 Jan 24, 2009
    decharged very soon ,and charged so late , and battry sign didnt get green after being charged ,
  • psychobabe Jan 26, 2009
    Won't connect to the computer or recharge when I plug it into the computer. Although it will recharge with my USB mains adaptor just not with the computer.
  • 79 Answers
I have that kind of Mp3 Player too... that happened to me, but the PC was able to read mine. However, the reason why the message: "Low Battery USB Disabled" appears, is that you still have remaining battery life, but will only last for less than an hour (indicated by low light and red empty battery sign) you have to make sure the Mp3 is completely discharged. (you'll be notified when you turn on the device while it says: "Low Battery") once that it is completely discharged, you can now plug in the USB cable with the device to the PC... if problem persists, check your PC.. can it read the device? Check if a notification balloon appears at the bottom right corner of the monitor screen. It should say, "Found New Hardware... Samsung YP-Z5F..." if it did not appear, try to INSTALL using the Installation CD given when you bought the product. Just insert the disk into the PC and continue on, then when it is already installed and ready for use, plug in the device! This may be a little hard, but this is the only way I know. Feel free to ask me! I am no technician but I know a lot on devices and fine mechanics. Good luck!
Posted on Jun 20, 2009
I have a samsung yp-z5f but i can't get in menu and it keeps freezeing.i reseted it but sill nothing.can you help?
A firmware upgrade may solve the issue. To upgrade firmware follow these steps:
  1. Download the firmware file from the Samsung Download Center by clicking here.
  2. Remember to save the file to your desktop or documents.
  3. Uncompress the downloaded file in a folder (use winrar or winzip). DATA file will be displayed.
  4. Connect the player to your PC with the USB cable.
  5. Right click on the Start button, and then left click Explore to open Windows Explorer on your PC. [Samsung YP-Z5] is displayed in Windows Explorer.
  6. Select the uncompressed files and drag-and-drop it into the Samsung YP-Z5 Data folder.
  7. Disconnect the YP-Z5 from your PC. After disconnecting the USB Cable, the upgrade screen appears.
  8. Select [Upgrade] to upgrade firmware.
Try it and see.
Nov 29, 2009 | Samsung YPZ5FZB 1 GB, BLACK, MP3 Player,...
My computer does not recognise my samsung YP-Z5F player at all,i am running windows vista,what should i do?
Manual for YP-Z5F:
http://downloadcenter.samsung.com/content/UM/200605/20060511090848406_YPZ5F-COMMON-ENGLISH0.0.pdf
1. Try a system reset: page 60
1.1 Turn the power on
1.2 Press the Reset hole on the bottom of the player.
86a5bae.jpg 2. When power won't turn on: page 61
2.1 Let the player charge
2.2 Turn the power on
2.3 Press the Reset hole on the bottom of the player.
3. Windows update might be required: page 63
3.1 Press <Start> on the toolbar of your PC to run Windows Update.
Select Key Updates and Service Packs, then update all.
Reboot your PC and reconnect.
When you're connecting to a pc that has another Operating System:
1. Install the software matching for your OS on the computer.
2. Update your player withe the latest firmware if available.
Note: when reinstalling firmware all files (music, pics, videos) will be erased from the player.
Downloads support page:
http://www.samsung.com/uk/support/main/supportSupportMain.do
Entering your exact model will lead to the correct downloads.
Sep 20, 2009 | Samsung YP-Z5FZ (1 GB) MP3 Player
How do I charge Samsung MP3 player Yp-U3 Samsung YP-U3 MP3 USB port not connected to the computer
The player needs to be charged via the USB connnection on your PC. If it doesnt fit, try the USB ports on the back. If its not working/not charging, please test the MP3 player on another PC.
Jan 21, 2009 | Samsung YP-U3 MP3 Player
Samsung YP-Z5F
I've had various issues similar to those described, and can offer the following trouble-shooting and/or work-around tricks that I've had success with:
Sometimes, when I come to use it I find that it won't turn on at all, but it's most likely because it's been a while (several weeks) since the last time that I used it.  The battery does seem to lose its charge over this time.  All I do is to charge it up for several hours, (or even overnight).  It usually charges best by leaving the unit OFF when plugging in the USB cable to the PC, just like a cell phone does.
As for the problem with the PC recognizing it, sometimes it just takes a few minutes. I have winXP.
First, open MyComputer.  If the mp3 player doesn't show up as another drive after about 60 seconds, press the F5 key to 'refresh'.  Sometimes closing MyComputer, then re-opening it makes a difference, too.  You might also want to try a different USB connection, like using one in the back of the PC instead of the front (or vice-versa).
Sometimes, though, it doesn't hurt to just press the RESET button at the bottom side (6 o'clock position when holding it upright and facing you).  With it turned ON, I insert a paper clip that's been partially straightened out, holding it in for about 3 seconds.
Jul 30, 2008 | Samsung YP-Z5FA MP3 Player
SAMAUNG-YP-Z5,LOW-BATTERY
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
Feb 10, 2008 | Samsung YP-Z5 MP3 Player
Yp-z5f MP3 PLAYER
i can't change my samsung mp3 YP-Z5F 2 GB and i don't have installation CD.So,how can i change and where can i download installation CD,If you don't mind , you can give me that CD,My account is nonamewai@gmail.com,
thanks you!~
Oct 19, 2007 | Samsung YP-Z5A MP3 Player
YP-Z5F MP3 player
you could try to connect it to another computer if it detects convert it to FAT32.
Apr 15, 2007 | Samsung YP-Z5A MP3 Player
Samsung MP3 Player YP-Z5F
is there a reset button [pinhole] on the player??
should fix it
Apr 01, 2007 | Samsung YP-MT6X MP3 Player
Samsung YP - Z5F
Samsung YP-Z5F
Will not always switch on and when it does switch on will not respond to control panel
Jan 19, 2007 | Samsung YP-MT6X MP3 Player
Samsung YP-Z5 MP3 Player Logo
782 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
