Question about E-Machines (308714) Motherboard
Reboot with new hd
Have a emachine w4685 installed new hard drive used original restore dvd which loaded normal. rebooted computer windows xp home begins, ask's what country, language, time zone ect. gets to what name to call the computer you put a name in,click on the next button and that is as far as it gets. I can't get pass this page. I've reloaded the dvd same problem same page all comes to a halt.
  • 1 more comment
  • wimstock Oct 11, 2008
    Yes acdr this I have done I click on the next button which is lit up hour glass pops up hard drive runs then stops the [next] button is no longer lit and I cant get to the next setup page
    yes the bios recognizes the hd. What happens is as a new install of windows xp windows will launch welcome to windows screen comes up at the bottom right of the screen is an arrow showing [next] so you click on that to go to the next setup page. I can go to three more set up pages all asking different questions. On the forth page the screen asked what to name the computer. You give it a name and press next gust like the previous three set up pages. However at these point it will not go to the next page. I have reloaded this restore dvd three times indicting it was successful. Possible the dvd is damaged and its not the computer
  • wimstock Nov 01, 2008
    Gust an update, I gave up trying to install the original restore cd and went to kubuntu one of the lenix programs, Its a bit of a learning curve but it works. Thanks for all the help.
Try Checking if your motherboards bios will recognize the hard drive. If not, Then the hard drive is probably damaged.
To access The bios, Most Motherboards open the bios when you press the delete key
If you have two or more hard drives then the settings of the jumpers eg. Slave,Master,Cable Select.
Because they might be conflicting with each other.
I had the same problem, But I tried installing XP Home edition on my secondary hard drive and it works.
But i need to insert my xp home install disc to get it the bios to recognize that windows is installed otherwise it goes " insert system disk and press enter"
Posted on Oct 11, 2008
    Genius:
  • 1,913 Answers
Give country usa and computer name as any u like .u can set also your name .
Rebooting a used emachines laptop I just bought
If you can boot into Windows 8
  1. Power on your computer.
  2. Press the Windows and C key to begin a search.
  3. Type recovery and click eMachines Recovery Management.
  4. Click on Restore Factory Settings, at the Restore tab from the left menu.
  5. Click Next.
  6. Click Fully clean the drive option.
  7. Click Reset.
More items...
eMachines Recovery Disk - Guide for Windows XP, Vista, 7, 8
Rebooting used emachines laptop Google Search
Oct 14, 2017 | eMachines Computers & Internet
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
Hello there, I can't reinstall Windows XP. When loading the reboot DVD, my both computers mention they can't find the device. Which device they can't find is not clear. Both computers are set up to...
Even though you have set the computer to boot from the DVD first, there is usually a special function key you can press to ensure you boot from it.
Just when you get the error will determine what the problem may be. When you first start, you should get the prompt "press any key to boot from the CD (DVD). If you don't get that prompt, then your DVD may be going bad on you.
You say you are loading a reboot DVD. I have no idea what that is, but XP was distributed on a CD for the most part. Be sure you are trying to boot from the original Windows XP CD or a system restore CD.
If you are allowing the computer to boot to Linux first, then you're in for trouble. That won't work.
Oct 11, 2010 | Packard Bell Computers & Internet
My 13 year old son laptop need be reset like new
There are a couple possible solutions to your problem. If the computer will still turn on and load windows, and I assume you are using Windows XP, you can try doing a system restore. To do this, go to Start, Programs, Accessories, System Tools, and select System Restore. If system restore is enabled, you should be able to choose a date in the past when the laptop was working properly and restore the computer to that date. If you want to completely reload windows, you will need a Windows XP installation disc. Load the disc in the CD or DVD player and reboot the computer. You should see a screen asking you to press any key to boot from CD, go ahead and press Enter. You will now enter setup where you can reformat the hard drive and reload windows XP. Follow the on-screen instructions to delete any old partitions, and then create a new partition and format it using NTFS. The windows XP installation will continue after the hard drive is formatted. If, when you reboot the computer with the installation disc in the drive, you are not prompted to boot from CD, you may need to reboot and press F2 or F12 to change the boot selection to the CD or DVD drive so it will load the CD first before it tries to load your original Windows installation.
Jul 18, 2010 | Dell Inspiron 1525 Laptop Midnight Blue
Can't install OEM Windows XP on fresh hard disk
please check the consistancy of hard drive or try to run a zero format first and then reinstall the win
Apr 15, 2009 | Computers & Internet
I need to preform a system reboot/ restore for aSONY VAIOPCGGR250
Holding zero is the method for restoring Toshiba computers. Sony Vaio should use F10. From there you can do a full system restore to factory defaults.
Hope that helps :)
Apr 14, 2009 | Sony VAIO VGN-FJ270/B Notebook
Was told I need a new HD on my T3504 so I put one in
you should make use of the original Microsoft windows xp service pack 2
Jan 13, 2009 | E-Machines T3504 PC Desktop
REBOOT LOOP -EMACHINE T5026
You have provided some good information, but more detail is needed.
Is the system still under warranty? How long ago did this start? Have you added any new hardware or software?
Your reboot issue might not be hard drive or MBR related. Disconnect everything not needed for booting. Even disconnect keyboard and mouse to see if it will get to the Windows Desktop.
If that works, start adding until you get the reboot problem again.
If none of that helps and you need to recover data from the computer, buy or borrow a hard drive you can boot to for the computer and when you are able to boot to Windows, you can back up your important data, then wipe the drive and reload Windows or leave it blank as extra storage capacity depending upon your desire or circumstances.
Let me know if you have questions.
Honest1abe
Dec 29, 2008 | E-Machines eMachines Desktop PC
Internal laptop CD/DVD combo drive problem
1. uninstall dvd/cd using device manager reboot and winxp will reinstall driver 2. go to my computer / dvd drive / right click / properties / hardware - roll back or update & properties - enable digital cd audio / recording - enable cd recording 3. do system restore start / all programs / accessories / system tools / system restore 4. do full system recovery - us windows xp OS
Nov 23, 2006 | Acer (91.AB264.016) Internal 24x CD-ROM...
E-Machines (308714) Motherboard Logo
394 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
