Question about Refrigerators
Water despenser water does not flow....ice works fine...new filter installed...still no flow
  • cpandbc Jan 22, 2009
    we have the same problem, new filter in, the ice works, not water to the door. we have taken off the bottom portion of the front of the fridge, and taken apart the hose 'connector' and can see that the water gets to that point (e.g. we press the water button on the door and it comes out), but when we connect the tubes back together, it rarely works (e.g. once every couple of months).
    our model is GSH22JSRE SS
    Sergeant:
  • 409 Answers
check to see if you have a leak in the water line. the line runs from the wall to the icemaker. do you have any leaks on the inside of the door? any frost build up? im assuming that you have a side by side fridge with an icemaker.
Posted on Oct 11, 2008
My water dispenser is INOP.when lever is pressed only a hum can be heard but no water. Removed water filter and water shoots out inlet. Attempted to blow on inlet portion on water filter and no air flowed...
The water line may be plugged or frozen.
Remove all the food and put in another freezer and shut the freezer off for 24 hrs and see if it works then. Is there ice cubes stuck in the despenser ? If so clear them out. May be the jammed ice cube my not let any water through.
Jan 30, 2015 | Refrigerators
Ge mod GSS22GRC SS the ice maker works fine but all of a sudden the water despenser does not flow....I since changed the filter that did not help
Start by checking the water supply going to the fridge:
  • Turn off the water at the saddle tap valve.
  • Disconnect the water line in the back of the fridge. Place the disconnected end in a bucket and open the saddle tap valve.
  • Observe the flow rate–water should shoot out vigorously. If not, then the saddle tap valve is probably gunked up with sediment and you’ll need to replace it.
Oct 11, 2008 | GE Refrigerators
I am having problems with the ice maker. The water freezes but it will not roll over. I have to pull the ice off of the tray the ice is made.
check to see if water despenser is despensing water slow that normal. replace water filter . it will work ok
hope it can help u
Jan 12, 2011 | Electrolux E23CS75DSS Stainless Steel
No water flow to ice maker or water despenser...water lines are clear the filter is clear..could problem be water inlet valve ( dual valve controls water flow to ice maker and water despenser.
Its odd that both parts of the valve went bad at the same time. Personally sounds as if your water filter is clogged up and needs to be changed. I would do that first, before trying to change the water valve itself.
Dec 08, 2010 | Whirlpool Refrigerators
The ice from the ice maker tastes terrible, the water from the despenser is fine just the ice is a problem
remove icemaker and check that you have no eroding of teflon coating. you may install a quaity charcoal filter.
Jul 25, 2009 | Amana Refrigerators
No Ice is being made. Water is being despensed at the door but it seems that no water is going to the ice maker. Have good water flow to the pump.
Is the ice maker turned on?  The on/off switch is located on the top right side of the freezer compartment.  The manual says that there is a sensor beam that passes from one freezer wall to the other to shut off ice making when the bin is full.  Check to make sure nothing Is blocking that signal beam and that the bin is correctly installed.
May 30, 2009 | Kenmore 57029 Side by Side Refrigerator
Water despenser
The water dispensing valve may not be functioning, if the valve buzzes or hums when the water dispenser is pressed the valve may be mechanically deficient, if there is no sound whatsoever the switch for the dispenser,the dispensing valve coil or its electrical connections may have failed.
May 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
May 07, 2009 | Maytag MFI2568AE Side by Side French Door...
My fridge is a side by side whirlpool, and it has a water despenser. The water despenser and ice maker isn't flowing, there is no water, no ice. Im not sure the model #.
check your water supply is ok and replace your water filter if it has one this should solve you problem if not then its poss you have bad water solenoids but not likely. peyton
Jan 19, 2009 | Whirlpool ED2FHSS Side by Side...
No water
two things may have happened, first the o-ring washer on the pipe tap may have shrunk and restricting the flow of water, second the filter for the machine may be plugged up and need changing. good luck and if yoiu still need assistance feell free to ask againd
Refrigerators Logo
146 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
