Question about Whirlpool MH1150XM Convection/Microwave Oven
Whrilpool microwave mh1150xm does nothing...dead
My wife was cleaning our microwave and it suddenly blew the breaker. I reset the breaker and now the microwave is dead. I assume it is an internal fuse...but where is it located?
  • Whirlpool Master
  • 9,098 Answers
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find it, contact me and I can e-mail it to you.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Is it possible that some spray cleaner accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
Always spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
Always use the vent fan when cooking on the stove top to keep steam and grease out of the controls.
If it does not dry out over time, it may need to be manually dried or blown out.
If you think the controller or keypad may have trouble, we repair these on a regular basis for $39.95 in most cases in about a week or so door to door.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 20, 2008
My maytag microwave blew the ciruit breaker a several times last night. I reset the circuit breaker each time. Then the last time, I reset the circuit breaker and the microwave did not get power back....
If there's no other appliance on that circuit, then please stop trying to use the microwave. You could be dealing with a dead short, and those sometimes leave people,,,DEAD!
I would be really cautious about trying to use it anymore without checking it first for a direct short.
You need to allow the circuit breaker more time to reset, flip to off and give it 2 minutes, then turn it back on. You should feel the distinctive click, as well as hear it if it's working properly.
Circuit breakers can go bad after repeated failures within a circuit.
The outlet could also be damaged now, but normally it's the circuit breaker getting too hot with repeated failures.
If there are a number of other items on the same circuit, then try the microwave in a plug that you know has no other items being used at the same time, preferably while wearing heavy duty leather insulating gloves to protect yourself from any possible shock. If the circuit breaker blows, you've got a possible electrical short within the microwave.
Mar 27, 2012 | Microwave Ovens
Thanks for taking my question. Model Info: Whirlpool Accubake system electric range Super Capacity 465...... my wife moved the range to clean behind and it sparked at the plug and blew the breaker. ...
try fitting a new plug. if you do cut back the cord back at least 3 inches try it again. before you do check socket with another appliance.let me know if that fixed it or not
Jul 26, 2011 | Microwave Ovens
It wasnt working at no display nothing, i took down and cleaned real good now im getting a F6 code
Funny that a cleaning would revive a totally dead microwave! Never would have guessed. On microwaves manufactured by whirlpool, F6 apparently means "Microwave relay failure. Check wiring to relay 4903 for short circuits."
Talk to your local service shop and see if they will replace a microwave relay... they should be able to give you a parts and labour estimate before they begin so you will know what you are in for.
Oct 21, 2010 | Whirlpool MH1150XM Convection/Microwave...
My MH1150XMS-4 just stopped working suddenly.
The main fuse or the thermal cutout is probably blown. If the main fuse is blown, most likely the high voltage capacitor is shorted and must be replaced. If this is the case, it's a good idea to also replace the high voltage diode because it took a large over-current hit before the fuse blew. Be sure the oven is unplugged before measuring the resistance of the fuse or capacitor (the diode should read open in both directions because the forward voltage is more than a typical ohmmeter can put out). (Note: replacing the fuse without identifying and fixing the short or overload will simply waste the new fuse. It's not like the old farmhouse with one fuse for a dozen outlets going out because one item too many was plugged in.) The capacitor is available on Amazon for less than $17 (be sure the voltage and uF values match the one in your oven), the diode is about half of that, and the fuse should be under $3.
If the thermal cutout is blown, check the magnetron cooling provisions - make sure the fan turns freely, the blades are clean, and all vents are clean. After replacing the thermal cutout, verify that magnetron cooling fan runs at speed when the oven is running. Keep your hands and tools out of the oven if you are testing it with the cover off. The high voltage side can be energized by as much as 1800 Volts. An arc from this can cause serious damage or personal injury.
Amazon com 0CZZW1H004S Kenmore Microwave Capacitor Drawing Hi Home...
Oct 18, 2017 | Whirlpool MH1150XM Convection/Microwave...
Breaker blew and when flipped back on, microwave didn't work
yes there is a 15 amp fuse that needs to be changed in behind the front control panel
Aug 21, 2009 | Whirlpool MH7140XF Microwave Oven
My daewoo microwave/toaster blew my breaker upon resetting it and plugging in the microwave it blew again then it tripped my GFI what could be the problem?
Probably a short inside the microwave circuitry.  I had a Daewoo and had nothing but trouble with it.  Main board went out in a year, then again in another year.  Finally went to Home Depot where I bought it and was told that they had nothing but trouble with them and quit selling them.  Now I have a GE Spacemaker.
Apr 22, 2009 | Microwave Ovens
Was heating up food and all of a sudden nothing works on the microwave, nothing, clock, light, buttons, nothing..
sounds like your circuit breaker kicked or your fuse blew. go to your electrical panel and see.
Apr 21, 2009 | Whirlpool MH7140XF Microwave Oven
Whirlpool MH1150XM
Full details of our service are at http://www.microwavedisplay.com but if you still have questions, please reply back.
Apr 09, 2008 | Whirlpool MH1150XM Convection/Microwave...
Gold Star convection microwave model ER-930C
If you have a sentimental attachment to this microwave (lots of the older ones feel so much more "quality" than the flimsy throw away versions offered today), then you might want to pick up a service manual to diagnose your issue. Here is one being offered and it has a troubleshooting guide. http://www.analogalley.com/osccart/index.php?manufacturers_id=61
Jan 12, 2008 | Goldstar Microwave Ovens
Whirlpool MH1150XM Convection/Microwave Oven Logo
161 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
