Question about Nokia 5200 Cellular Phone
Nokia 5200 when i try to open my nokia 5200 and try to press menu it freezes and when you try to open left scroll shortcut for messages it displays message storage not yet ready, i cant make calls and text messages plus many features of it pls help!!!!!!!!!!
  • 1 more comment
  • padz51 Oct 12, 2008
    i have pretty much the same problem with nokia 5200, its not wokring most of the time once in a while though i am able to use my keypad otherwise all i can do is answer the fone by sliding the fone open.shall i just take it to a shop to get fixed or would a person like me who has no clue about fixing fones be able to solve this with your help
  • harmandeep Oct 15, 2008
    My 5200 started misbehaving by restarting on its own. Later it started to go off at will and i'd have to keep checking to see if it's still on otherwise i'd have to switch it on again.Aftera while, it just refused to work for longer than a couple of minutes to hours, depending for how long i leave it to rest. Now, it doen't stay on at all...it comes on, all right; might even show the nokia start-up, but it goes off immediately.It might get to my wallpaper before going off but usually doesn't, except if i've left the phone off for a day or more...then it may even work for about 10 minutes.
    I have paid monehy to have it flashed many times, but it still gives the fault. And i finally know that it isnt a virus bcos 5200 comes with a firmware. However,i sent someone some files via bluetooth and his own nokia phone started behaving like mine immediately. Can my phone be infectious? Were the flash files not correct? How can i get the right ones?
    PLS HELP ME.
  • Anonymous Feb 07, 2009
    Menu, up, down, left, right bottons doesnt function thus when pressed digit 5 appears on screen. Already cleaned, resoldered flex cable connector. Kindly provide possible solutions
    Thanks,
    Nilo
    email: nilodg@yahoo.com
  • Nokia Master
  • 1,800 Answers
Dear
When this kind of problems occurs ur CP''s Flex Cable* is the faulty part in this case.
Solution is : replace the Flex Cable of ur 5200 (its a piece of cake)
Folllow me
1/ purchase the part click here.
2/ take the phone apart using the screwdriver Number 6 for nokia Cp's.
3/locate the flex cable connectors on both mother boards LCD and Keypad.
4/replace the old one with the fresh one .
PS: a flex cable of Nokia 5200/5300 lives about 100 000 slides
so slide the phone just when u gonna need it!!!
5/close the phone after making sure all connectios are ok..
6/enjoy it
7/ plz do ratet this post as good as u can!
Posted on Oct 11, 2008
Any text message i send goes to the out box and is either resending (to no avail) or listed as failed. I got the phone 3 days ago. It is a work phone with telstra. Nokia C%
The problem might be with "Message Center Number" which is different for different service providers.
You should call you service provider "Telstra" and ask them that number. You can then enter it in your mobile as mentioned below.
(Please rate the solution if helpful, Thank you)
Press "Menu"
Scroll to Messaging, press "Open"
Press "Options", scroll to Settings, press "Select"
Scroll to Text message, press "Open"
Scroll to Message centres, press "Open"
Scroll to SIM message centre, press "Open"
Scroll to Message centre name, press "Change"
Enter (your provider's name), press "OK"
Scroll to Message centre number, press "Change"
Enter (number provided), press "OK"
Press "Back" twice
Scroll to Message centre in use, press "Change"
Scroll to (provider's name you entered), press "OK".
Jun 17, 2011 | Nokia C5 Cell Phone
Tip
Nokia 5800 Tips
5800 Tips and Tricks
1. To bring out the Shortcuts on your Screen/Desktop-> Settings/Personal/Home Screen/Home Screen Theme and select Shortcut bar, you can then select which shortcut to display if goto "Shortcuts". This will also bring out the "Track" playing being displayed when you open the Music Player.
2. Tap the Clock to bring out the Clock menu and make your alarm, alarm repeat is now built-in.
3. Tap the "General" or Date (the set Profile besides the clock) and the Profile selection menu pops out, almost similar to pressing the "Power" button in all S60, but here the Remove memory is not shown, but "Calendar" shortcut is included and the other profiles as well.
4. If you are on the Numeric Keypad, pressing the [#] key alternately will toggle the General and Silent Profiles, same as before, which means long press on zero [0] will bring out bookmarks for the Web.
5. Tapping on the displayed To do or Calendar entry will bring you immediately to that particular item.
6. Tapping the Active Icon on the Top Left (near the battery indicator) will give you shortcuts for any of the active icons.
7. Long press on the Green Call Button will still activate the Voice Command Prompt
8. Long press on the center button is similar to the Long press on the "Menu" key (the yin-yang key on most S60) which will bring out the menu for all the active applications.
9. Go to Applications/File Manager and setup "Backup" for automated backup schedule of your phone data.
10. How to update your Nokia 5800 firmware using your phone.
Presss *#0000# to display phone factory information and firmware
Now press options and select check for updates
The newest update is sent to your phone from nokia
Download and install updates.
This is done using GPRS or WIFI Connectivity.
General Tips
1. Use Dialer and press # for about 2 seconds will switch the profile between Silent and General; press and hold 0 will open the web browser; press and hold 1 will open the voice mailbox
2. There is a shortcut key for Music, Gallery, Share, Video, Web shortcut at the top right corner just below the front camera
3. Press and hold the Green caller button when standby mode will activate the voice command. You could call the name from the contact or application name.
4. Organize your sms by grouping them like outlook by Messaging -> Option -> Setting -> Text message -> Other -> Show messages in groups -> Yes
5. Notification light will blink if there is unread sms/missed call. It could be turned off at Settings -> Notification light -> Off
6. If the touch input is not accurate, you could calibrate your screen at Touch Input-> Touch Screen Calibration -> ( Tap around the 4 dots at the corner)
7. Turning control functions:
a. Rotate your screen horizontal or vertical
b. Silence your phone for incoming call by rotate your phone with screen facing down.
c. Snooze the alarm by rotating phone screen facing down
8. Theme effect will give 3D and transition effect if on but will slow down your tube considerably. Settings -> Personal -> Themes -> General -> Themes effects -> On/Off
9. Shortcut to exit application : Press and hold the middle white button then press and hold the program that you wish to quit, an open/exit option will pop out (useful for those haven’t install handy taskman yet)
10. When using handwriting input, slide from left to right is Spacebar, right to left is Backspace
11. Organize your menu by Menu -> option -> organize. You could drag and drop the location of the application you wish to relocate.
on May 12, 2010 | Cell Phones
Tip
Sony ericsson secret tips
Sony Ericsson Secret Menu:
> means press joystick or arrow keys to right
< means press joystick or arrow keys to left
1. push joy stick to RIGHT once
2. press *
3. push joy stick to LEFT twice
4. press *
5. push joy stick to LEFT once
6. press *
The Service Menu will appears containing following information !
1. Service Info
a. Software Version
b. SIMlock
c. Configuration
2. Service Setting
a. Contrast
3. Service Test
a. Display
b. LED/Illumination - *This test is very cool
c. Keyboard
d. Buzzer
e. ********
f. Earphone
g. Microphone
h. Real Time Clock
i. Joystick Counter*
Lockstatus: < * * <
Shortcut to last dialed numbers: 0#
Shortcut to sim numbers: On main menu type a number and press #
If you change the language from default to any other language, then it may be difficult to switch to default language.
The shortcut is very simple. Just press < 0000 >
< stands for left arrow button or joystick and > stands for right arrow button or joystick.
Secret Games: Snake on the T68
Go to Erix and then on the main screen press 123 and you will be taken to the game.
Secret Message:
On Tetris on the main screen when the blocks are falling press 397 and a message will appear.
on Mar 08, 2010 | Cell Phones
I have nokia 5200 Mobile, my mobile key pad working with Shortcut Example: press 7+end call=Menu press 5=go to inbox How can solve it problem
go to settings and short cut option then see the shortcuts option and remove the shortcuts if still problem do a reset of your phone by clicking settings ->restore factory settings. before restoring take a backup of your contacts .thanks
Jun 13, 2011 | Nokia 5200 Cellular Phone
My friend sent me mms on my N70 I tried to removed the message but I can't do it. Maybe you could help me erase the messages. Thanks
Hello - I use a Nokia 70 so hopefully I can help.
Scroll the centre button down to messages - press once to open. Move down one more setting to UNREAD messages and press again.
This will open ALL messages in you inbox - TXT/SMS + email + MMS.
Find your MMS by scrolling up/down then click the C (cancel) button bottom left on your phone. This should then ask - Do You Want to Erase this message - click YES.
The second option after you have found the MMS in the inbox is to open it, then press option which is the 'select' key on the left part of the screen. Press this once and you will have a menu of choices like -- move to / save picture / forward message to / save message on phone card // AND DELETE.
One of these should work if the phone is in good working order on all the other features. - Ray
Jan 15, 2011 | Nokia N70 Cellular Phone
Tip
Nokia 5800 XpressMusic Smartphone Tips and Tricks 1. To bring out the...
Press*#0000# to display phone factory information and firmware
General Tips
Battery saving Tips
1. Always turn off wireless scanning, Blue-tooth when not in use
2. For those not using 3G, choose your network mode to “GSM” instead of “Dual mode” which will consume more battery. Settings -> Connectivity -> Network mode -> GSM
3. Less Display Light
a. Setting -> Phone -> Display -> light sensor (move the slider to the left)
b. Setting -> Phone -> Display -> Light Time-Out (lesser time to save battery but annoying if too short while you are playing games)
4. Always terminate the application properly that is not using by using Option ->Exit. It might be running background and consuming battery which you don’t know.
Memory Saving Tips
1. Restart your phone if the memory less than 30MB, you could either soft reset (User a dialer and dial 5 * * then call) or hard reset by pressing the power button
2. Use Handy Taskman to close all application regularly or kill application that is not in use.
Camera & Picture tips
1. Some noise could be reduced if set the ISO sensitivity to low instead of auto.
2. When viewing pictures, you could use your stylus to view for previous (slide left) or next (slide right) picture like iphone feature.
Video
For converting video that is high quality to play at 5800, should use the mp4 format as below (All is 16:9 widescreen):
a) Xvid @ 678kbps resolution 480×272
b) Xvid @794kpbs resolution 640×352
c) H.264 @ 512kbps resolution 400×224
d) H.264 @ 550kbps resolution 400×224 (Recommended)
Music tips
1. If you can’t find your songs after transferring from your pc to memory card, go to music player -> Option -> Refresh library
Application Tips
1. Always install your phone theme on the memory cards. This is because if some theme does not work (Christmas tree) then you need to flash your phone.
2. Uninstall your application in proper way. Use Menu -> Setting -> Application mgr. -> Installed apps -> Choose application then option n uninstall
5800 Hard Reset(credit goes to ArunGupta)
WANNA HARD RESET YOUR NOKIA 5800 XM?
JUST PUT *#7370# AND THEN PUT LOCK CODE(I.E 12345) BACK UP YOUR PHONE MEMORY BEFORE DOING THIS
NEW LOCK CODE METHOD FOR NOKIA 5800XM
PRESS GREEN KEY + RED KEY + CAMERA KEY WHILE BOOTING YOUR 5800 JUST PRESS IT UNTIL YOUR DEVICE RESTARTS
This method is for nokia 5800 XM
on Mar 05, 2010 | Cell Phones
Tip
NOKIA E71 Tips and Tricks
The E71 was one of the very best handsets to come out of Nokia factories in 2008 and the best ever in my book. So it is only right that we utilise its functionality to the absolute hilt and try and make the E71 even more efficient.
Here is a long list of must know tips and tricks for the E71. You might already know a few but if you are new to S60 and the E71 in particular, I’m sure this will make for a happy start to the E71 new year!
  • STICKY FUNCTION KEY – A quick double press on the bottom left ‘function’ key locks it. This is helpful in situations when you need to press a combination of keys or in applications like Gmail which can be controlled via the keypad.
  • 1-800-WHATEVER – To dial 1-800-WHATEVER: type 1800, hit Fn, then Shift twice, type WHATEVER, and press the Call/Green key to dial. (The idea is to type in the alphabet mode in CAPITAL letters ONLY). The alphabets will automatically be converted to numbers.
  • ONE TOUCH MUTE – You can simply mute a call by press the button between the volume keys present on the right hand side of the phone. Press it again to cancel the mute.
  • REMAP THE KEYS – There are times when you feel certain keys on the E71 are being wasted when they could have come in very handy. For example, the volume keys would work wonderfully with the web browser to scroll pages or in your music player and the mute key could work as select. Make that happen.
  • TIME & DATE – When the phone is in the locked state and the screen is blank, hit the Navi Button to display the time and date in a large font.
  • TEXT MESSAGES – When in the standby mode, hold down left soft key to read out new text messages.
  • ASSIGN SHORTCUTS - If you have a lot of applications installed on your E71, you might want to assign additional shortcuts to different applications by definying a set of keypresses with an application called Cute Keys.
As a follow up to the above tips, here are a few shortcuts that you should enjoy. I have highlighted some of the lesser known ones.
GENERAL
  • To get to a symbol or number hold down its key.
  • Shift + Backspace deletes letters after the cursor, thus immitating the behavior of the ‘Delete’ key on the computer.
  • In the Main Menu:
A B C D
E F G H
I J K L
To open A press 1, 2 for B, 3 for C, * for D, 4 for E, 5 for F and so on.
* Fn + Ctrl + C to copy.
* Fn + Ctrl + V to paste.
* Shift + Left ( or Right ) to select text.
* Ctrl + Up for page up.
* Ctrl + Down for page down.
* Ctrl + Vowels ( or n ) for accented characters like á or ñ.
CAMERA
  • T to focus.
GALLERY
* Green Call to send the image.
* Fn + * for full screen.
* Fn + 7 to zoom in. Press twice for the full screen size.
* Fn + 4 to scroll left while in the zoomed image.
* Fn + 5 to zoom in.
* Fn + 3 to rotate right.
* Fn + 2 to scroll up while in the zoomed image.
* Fn + 1 to rotate left.
* Fn + 0 to zoom out.
STANDBY
* Hold * to activate/deactivate Bluetooth.
* Hold 0 to go to the web browser.
* Left Soft Key then Fn ( or * ) locks the keypad.
* Hold End/Red to disconnect all data connections.
* Hold Left Soft Key to read out new text messages.
MAIL
* Shift + Return to mark/unmark a single message.
* Shift + Down to mark multiple items.
* Fn + Spacebar in new message body to access input (predictive text, etc.) options.
MAPS
* Shift to zoom in.
* Backspace to zoom out.
* Space to go to the current position.
REAL PLAYER
* Fn + 2 for full screen.
* Hold Up for fast forward.
* Hold Down for rewind.
WEB
* 1 for bookmarks.
* 2 to find something on a page.
* 3 to return to the previous page.
* 5 to tab open windows.
* * to zoom in.
* # to zoom out.
* 8 for page overview.
* 9 to go to a different web page.
* 0 to got to the homepage.
* Hit the Backspace key to close the current window.
on Dec 15, 2009 | Nokia E71 Smartphone
Need email setting for nokia n81 incoming and outgoing
Hello :
Here are the instructions :
Setting up email:
1:From the standby screen, press the Messaging softkey . Altenatively, press the Menu button, and highlight Messaging .Press Open.
2:Scroll down to highlight New mailbox .Press Open.
3:A message appears: No mailbox defined. Define now? .Press Yes.
4:Instructions appear for the email wizard .To start the email set-up wizard, press Start.
5:In the email address box, type in your full email address .Press OK.
6:You can now type in the name you want to call your email mailbox, or leave it as the default name of your email service .Press OK.
7:You are asked to define the user name and password for your account . Press Yes to continue.
8:In the User name panel, edit the email address until you have your user name - this is usually the bit of your email address before the '@' sign, (though if you're unsure, check with on your email service provider's website).
9:When completed, scroll down using the navigation pad to highlight the Password panel. Type in your email account password . Press OK.
10:After a few moments a message appears onscreen informing you that the email mailbox has been defined .Press OK.
11:The first time you set up, you will be taken into your mailbox and asked: Connect to mailbox? . Press Yes.
12:After a few seconds while the phone connects, you will get a list of email message subject headers onscreen . Scroll through the list to highlight ones you want to view.
13:Press Open to download and view the full email. Scroll down to read the message .
14:If the message has an attachment, scroll to highlight it and press Attachments . Highlight the attachment and press Open . You'll be able to see the attachment in full . Press Close and Back to return to the original email.
To get back to your mailbox, press Back. Alternatively, if you want to reply, forward or see other options, press Options. A list appears onscreen .
 Replying to emails:
1:To reply, highlight Reply. Press Select. Highlight To sender .Press Select.
2:Type in the text of your message. You can also edit or delete the original message if you want to, add new recipients or alter the subject header .
3:When you're ready to send, press Options, highlight Send and press Select .
4:Alternatively, before you send the message you can add an image or other files by selecting Insert from the Options list and pressing Select .
5:A row of icons appears at the bottom of the display, representing different elements you can insert - images, others, video clips, sound clips or text . Highlight and select one of these, and you can search through files to add a suitable attachment. Press Select to add it to your email.
6:When ready to send, as before press Options, highlight Send and press Select .
Checking for new emails :
1:To check for new emails go to the Messaging menu as before .
2:Scroll down to the name you gave your email mailbox . Press Open.
3:If you're not currently connected, you will be asked if you want to connect to your mailbox . Press Yes. New messages will now be retrieved.
4:If you are already in your mailbox and want to check for new messages, press Options, scroll down to Retrieve email .Press Select.
5:Highlight New . Press Select. New messages subjects will be delivered to your mailbox.
Sending new emails:
You can send messages as emails as quickly and easily as text or MMS messages.
1:In the Messaging menu, highlight New message .Press Select.
2:Scroll down to highlight E-mail . Press OK.
3:Add the email address, subject and message .
4:If you want to, add any attachments in the way outlined above.
5:As before, when your email is ready to send, press Options, highlight Send and press Select .
good luck .
rate please !
Mar 18, 2010 | Nokia N81
Unlocking nokia 5200
Follow the instructions give below & unlock your mobile using unlock code by making use of this site http://www.theunlockarena.com/unlock-your-phone/rs13wp2/
Warning : Do not enter any wrong unlock codes on your Nokia 5200 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5200 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 5200 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5200.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5200 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5200 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5200
Jul 03, 2008 | Nokia 5200 Cellular Phone
No text message
try master reset or master clear
Sep 21, 2007 | Motorola Mobility RAZR V3
Nokia 5200 Cellular Phone Logo
199 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
