Mitsubishi VS60805 I replaced the 2 ICs and it did not fix the 3d and color convergence problem. The TV was recently moved by trailer for 50 miles. I wonder if the tubes were knocked out of alignment? Could it also be the power supply fuses? Thanks Bob
  • 2 more comments
  • bobpro Oct 11, 2008
    How do I check tube alignment?
  • bobpro Oct 13, 2008
    Mitsubishi VS60805
    I replaced the 2 ICs and it did not fix the 3d and color convergence problem. The TV was recently moved by trailer for 50 miles. I wonder if the tubes were knocked out of alignment? If so, how can I fix the alignment?
    Thanks
    Bob
  • bobpro Oct 14, 2008
    Mitsubishi VS60805
    I replaced the 2 ICs and it did not fix the 3d and color convergence problem. The TV was recently moved by trailer for 50 miles. I wonder if the tubes were knocked out of alignment? If so, what's the fix?
    Thanks
    Bob
    Thanks for the advice.
    The problems are: 3D effect, color shadowing, and the entire screen image appears to bend.
    How do I check for cold solder joints and for bad resistors?
    Sergeant:
    Champion:
  • 334 Answers
An article of manufacture comprising a cathode ray tube is disclosed for use in a projection television system. The tube has a funnel and a face panel with a window for receiving a rectangular imaging screen. The projection television system includes tube receptacle means having conjugate means for accepting the tube in proper rotational alignment. The tube according to the invention is characterized by having two pairs of substantially radially oriented embossments on the funnel. The embossments are centered on, and azimuthally spaced one hundred and eighty degrees apart, on a diametrical line about forty-five degrees in counterclockwise rotation with respect to the minor axis of the rectangular imaging screen. The pairs of embossments according to the invention provide for engagement with the conjugate means of the tube receptacle means for proper rotational alignment of the tube in the system.
Posted on Oct 14, 2008
  • 4 more comments
  • nick helpap
    nick helpap Oct 14, 2008
    1. For use in a projection television system, an article of manufacture comprising a cathode ray tube having a funnel with a tube reference line and a face panel with a window for receiving a rectangular imaging screen, said system including receptacle means having conjugate means for accepting said tube in proper rotational alignment, said tube being characterized by having two pairs of substantially radially oriented embossments in said funnel centered on, and azimuthally spaced one hundred and eighty degrees apart, on a diametrical line about forty-five degrees in counter-clockwise rotation with respect to the minor axis of said rectangular imaging screen as viewed from the funnel end of said tube, said embossments of each pair being located about 1.150 inch from said tube reference line, and each of said embossments being about 0.390 inch in length and about 0.120 inch in heighth and width, and spaced from its counterpart about 0.120 inch and with the ends beveled at an angle of about forty-five degrees into said funnel, said pairs of embossments providing for engagement with said conjugate means in said tube receptacle means for proper rotational alignment of said tube in said system.
    2. For use in a projection television system, an article of manufacture comprising a glass cathode ray tube having a funnel with a tube reference line and a circular face panel with a window for receiving a rectangular imaging screen, said system including receptacle means having conjugate means for accepting said tube in proper rotational alignment, said tube being characterized by having two identical pairs of substantially radially oriented identical embossments in said funnel centered on, and azimuthally spaced one hundred and eighty degrees apart, on a diametrical line about forth-five degrees in counter-clockwise rotation with respect to the minor axis of said rectangular imaging screen as viewed from the funnel end of said tube, said embossments of each pair being located about 1.150 inch from said tube reference line, and each of said embossments being about 0.390 inch in length and about 0.120 inch in heighth and width, and spaced from its counterpart about 0.120 inch and with the ends forming a bevel at an angle of about forth-five degrees into said funnel, said pairs of embossments providing for engagement with said conjugate means in said tube receptacle means for proper rotational alignment of said tube in said system.
    3. For use in the manufacturing assembly of a glass cathode ray picture tube for use in a projection television system, said tube including a funnel with a reference line and a circular face panel with a window for receiving a rectangular imaging screen, a method of forming said tube for alignment in said system, comprising:
    molding identical pairs of two substantially radially oriented embossments on said funnel;
    centering said pairs on, and azimuthally spacing said pairs one hundred and eighty degrees apart on a diametrical line oriented about forty-five degrees in counter-clockwise rotation with respect to the minor axis of said screen, as viewed from the funnel end of said tube;
    locating said embossments about 1.146 inch from said reference line;
    forming each of said embossments to be about 0.390 inch in length, and about 0.118 inch in heighth and width;
    spacing each embossment from its counterpart about 0.116 inch;
    beveling the ends of said embossments at an angle of about forth-five degrees into said funnel;
    such that said pairs of embossments provide for proper rotational alignment of said tube in said system.
  • nick helpap
    The present invention relates to cathode ray tubes for projection television systems. More particularly, the invention relates to means and method for conveniently and precisely aligning cathode ray tubes in projection television systems during manufacture and maintenance.
    Precision aligning of projection tubes is essential in projection television systems. The television image that is electron-formed on the cathodoluminescent screen is projected a considerable distance onto a viewing screen and enlarged several times in the process. As a result, any appreciable error in alignment of a projection tube is similarly enlarged and amplified in the translation. Also, three discrete projection tubes are commonly used in a color system, and the images projected must appear in precise coincidence on the screen. Any appreciable error in the relative alignment of one or more of the tubes is amplified in projection, resulting in a degraded image on the screen.
  • nick helpap
  • nick helpap
    A focus coil (20) is adjustably retained around the neck (12c) of a cathode
    ray tube (12) inside a shield (14). An alignment apparatus (62) includes a
    ring (64) which is movable with five degrees of freedom and clamps onto
    the coil (20) through holes (14j) formed through the shield (14). The tube
    (12) and shield (14) are held stationary, while the ring (64) and thereby
    the coil (20) are moved to align the coil (20) relative to the tube (12)
    in accordance with electrical alignment test signals applied to the tube
    (12). A **** shell (66) which is generally coaxially disposed between the
    shield (14) and ring (64) includes a plurality of arcuate segments (66a)
    which are hinged together at their ends, and have pins (66b) extending
    radially inwardly therefrom for clamping engagement with the coil (20). A
    screw (70) extends inwardly from the ring (64) to clamp the **** shell
    (66) between its inner end and a radially opposed portion (72) of the
    inner surface of the ring (64). A sleeve (40) removably fixes the coil
    (20) to the neck (12c) of the tube (12), and includes a plurality of
    resilient fingers (56) which are movable into and out of locking
    engagement with the neck (12c). The sleeve (40) is clamped to the neck
    (12c) and, after alignment of the coil (20) to the tube (12), the coil
    (20) is fixed to the sleeve (40) using an adhesive.
  • nick helpap
    If you mean fuzzy as in out of focus, then just adjust the focus. Top one of the two controls on the flyback transformer
  • nick helpap
    look for hair line cracks on solder
    Scholar:
  • 92 Answers
I'm assuming you're referring to the two convergence ICs? If the set powers up you don't likely have a power supply problem. If it's just a convergence problem you're in the right area replacing the ICs.
Moving the set may be a key here but the picture tubes would not likely get out of whack that far unless it was handled very roughly. If it is a convergence problem (red, green and blue not lining up properly) and you've run through the convergence setup in the customer menu to no avail, and the problem just started after the set was moved I'd say more than likely you're dealing with a bad solder connection somewhere in the convergence circuit. Double check all resistors around the convergence ICs, they run hot in normal operation making them prone to becoming loose. There's also the DCU, the digital box (silver covered box near convergence ics that control the convergence signals to the ics) which can have loose connections where it's soldered to the main board or have loose connections internally.
If the problem is something other that what I'm guessing, please advise.
You have not mentioned what the symptoms are, this would be helpful.
Posted on Oct 13, 2008
    Sergeant:
  • 208 Answers
You need to measure continuity across the fuse or circuit protector like it was a short. Full meter deflection or on a digital meter, zero or close to it. If it goes to OL or a very high resistance, the fuse is bad or considered open.
And the convergence ICs that you have changed may not be suitable for your model....
For reference i am giving the compatible convergence ICs for your model.....
IC8D01 267P120010 HIC - STK392-040
IC8D02 267P120010 HIC - STK392-040
Post your comments back.....
  • Swaminathan R
    Swaminathan R Oct 13, 2008
    The power supply fuse can also be a problem........
    Genius:
  • 1,913 Answers
Http://tv.manualsonline.com/manuals/mfg/mitsubishi/vs60609serial_116016.html
check your display resolution.
rreset it to factory defaults settings.
aslo check power sup;ply adapter and earthing probelm.
Posted on Oct 11, 2008
  • 6,487 Answers
This can ba a misalign tube, so I suggest you to check the laignment of the tube then after that check if you still have the same problem...
Hope that helps..........
It has color at the bottom of the screen almost halfway up. I need to know how much to fix.
Tv have colors lines R,G,B mis alignments,have colors shadows or 3D pictures?Yes?Mean ur tv have a dead convergence board to causes this problems known as a tv convergence picture problems.The tv convergence board must have to be fixed like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 06, 2011 | Pioneer SD-P50A5-K 50" Rear Projection...
Screen resembles 3D look with predoment red and green to images - did the blue blub burn out and need to be replaced?
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.By replacing all these parts on the tv convergence board to fixed it to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 05, 2011 | Mitsubishi VS-60803 60" Rear Projection...
Color distortion, hazy snowy screen with thin red lines, suddenly happened had perfect pic 24 hours ago
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 01, 2011 | Mitsubishi VS-50705 50" Rear Projection...
Color is seprating
Tv have a problems known as a convergence problems,it dead.Tv have colors R,G,B lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts must be replaced on the tv convergence board to fixed it to solved tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Hitachi 50EX01B 50" Rear Projection...
Focus error 50h81 toshiba red line problem
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or have 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to fix it.To solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 01, 2011 | Toshiba 50H81 50" Rear Projection...
How can that blue shadow be fixed in the picture.
This tv have a convergence problems,it dead.Tv have colors lines R,G,B mis alingment anywhere in the picture,having colors shadow pictures or 3D pictures look alike?The tv convergence board is dead,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 15, 2010 | Hitachi 50GX30B 50". Rear Projection...
We turned the TV on and there was a rainbow curvy lines acroos half the screen
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 02, 2010 | Mitsubishi WS-65809 65" Rear Projection...
The red field on the screen, bends within the image, creating a 3D like effect.
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alingnment,have colors shadows pictures or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board,require replacing to fix the tv picture convergence problems.The shop,will cost $300-350 for parts and labors.
Oct 19, 2010 | Mitsubishi WS-65712 65" Rear Projection...
My 50" Toshiba has a color problem!!!
Ur convergence is dead.Must replaced the 2 Convergence ICS and all it resistors.By replacing these 2 convergence ICS well solved these problems colors misalign, 3D double pictures,blurry pictures.The shop will cost U $300 for parts and labors.
Jan 23, 2010 | Toshiba 50H81 50" Rear Projection...
Open Questions:
I have horizontal white lines across the display of my LCD Tv, I've included more info in the details section below I have an Insignia model# NS-46L780A12 LCD TV MFG date July, 2011 , recently the display has been acting very strangely because the issue comes and goes consistently dependent to whether or not there's caption writing on the screen - examples being programming information , channel , time etc.....these info blocks are each in their own particular areas on the display , where this gets odd is when your watching live TV ,these info blocks are always filled in with whichever program that's on, the best description of this issue is from these individual blocks of written captions on the screen example - from the top , there will be a continuous vertical row of horizontal lines starting directly underneath said caption all the way to the bottom , this will happen consistently wherever there happens to be writing on the screens display, so you get multiple rows of these horizontal lines from top to bottom of the display and they'll stay there for the entire time you watch your show , some shows have more ,some less ,depending on the writing for that show , this is all on cable TV / live TV I guess you can call it , and when I use my Fire TV stick with certain apps , I'll get no vertical rows horizontal white lines on the display with the exception that I push the mute button or change the level of the volume and the lines start to want to show up and do partially just for a little while ,but almost as soon as the info on the screen disappears as far as mute/ no mute or the volume level , the vertical rows of horizontal lines go away , I should also say that in either case Fire TV stick or cable , these vertical rows of horizontal lines take a little time to develope all the way from where the caption lettering begin and same process for when they go away , it's not instant in either case , it can take up a couple of minutes for either process to happen , one other oddity I guess you could say , in watching a cable tv program where you may get let's say 5 vertical rows of horizontal lines top to bottom at the beginning of the process , if you happen to try to watch that show ,those individual vertical rows of horizontal lines of varying widths will eventually connect with each other horizontally across the display
Feb 18, 2018 | Insignia Televison & Video
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
