Question about Whirlpool Washing Machines
My machine keeps washing but the clothes come out with lint all over them still I have tried to clean it but not sure if I have cleaned all the sections. The only codes I can find are 6aLBR6245JQ2 Whirlpool
    Sergeant:
  • 409 Answers
you may have lint caught between the inside and outside drums but i would also check the incoming water, as it doesn't seem like you have enough coming in. check the water valves on the wall and then also the water level in your washer. im assuming you have a top loading machine.
Posted on Oct 11, 2008
I have alot of particles in the bottom of my washer at the end of the cycle.. if i run another cycle with no clothes they stay in the bottom of the washer..appears to be dirt, leaves..etc
Hello, Suzanne -
So someone, whose clothes are washed in your machine, picks up "crud" on his or her clothes. (My dad used to collect "crud" in his pants cuffs and pants pockets, so my mom would make sure she emptied the pockets and cuffs over a wastebasket before putting his clothes in the washing machine.)
First, make sure pockets, cuffs, and whatever else clothing parts might collect "crud" are emptied over a wastebasket prior to placing in the washing machine.
"Crud" like pet hair or disintegrated facial tissue left in a pocket may still be left over in a washing machine tub after clothes are removed. I use a wet sponge to wipe out the washing machine tub when ever I see left over "crud."
Newer washing machines have lint traps, which are not as easy to access as those on clothes dryers. The washing machine lint trap may need cleaning out.
See tips provided here:
https://www.bobvila.com/articles/how-to-clean-a-washing-machine/
and here:
https://www.mrappliance.com/blog/2017/march/the-washers-lint-trap-needs-cleaning-too/
and here:
https://www.dependablelaundry.com.au/clean-washing-machine-remove-mildew-debris/
This web page covers "in-depth" cleaning of a washing machine:
https://learn.livingdirect.com/washing-machine-tips/
Best wishes.
Feb 18, 2018 | Washing Machines
I am getting a lot of lint on clothing is there a cleaning process with my smart drive pride 5.5 fisher & paykel washing machine
clean the lint filter in the machine
put any clothes that are likely to shed lint or are susceptible to collecting lint in a wash bag before putting in the machine
Oct 17, 2017 | Fisher Washing Machines
Lint on clothes after washing
its a possibility that one of the main drum bearings is leaking grease through the bearing seals so you will need an engineer to give you a quote for the repairs, it might be cheaper to purchase a new guaranteed machine eric
Jan 06, 2018 | Whirlpool Washing Machines
Kenmore 400 washer, leaves tons of lint on clothes, no lint basket to clean, cleaning the inside of the washer doesn't help. Black clothes have to be brushed completely with a lint brush to be wearable....
most common cause is that a tiisue or something of that nature went into your wash it breaks uprt and is scattered inside the machines outer bowls,either remove inner bowl to clean it or put it several empty washes to try and get rid of it
Oct 24, 2017 | Kenmore 2942 400 3.2 cu. ft. Top Load...
Dark clothes have lint left on them. what could help this problem?
Are you sure it is lint and not soap? My washer does this, and it looks like lint, but it is soap.
If it is lint, always keep the lint collector inside the agitator clean.
If it is soap, and this might work for lint:
1. Turn clothes, particularly black clothes, inside out.
2. Use a concentrated soap with little or no filler.
3. Use less soap than normal.
4. Fully dissolve soap before adding clothes.
5. Run rinse cycle again after completing full wash cycle.
Jun 22, 2011 | Admiral AW22 Top Load Washer
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
Washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Mar 14, 2010 | Kenmore 22622 Top Load Washer
Clothing are left with lint after washing cycles
Seperate fluffy linty clothes and wash those separately; never mix that stuff up. Also keep the dark and lights separate.I do a number of smaller loads that are in a lot of water; you get cleaner clothes and less wear. Overloads are hard on the washer and the clothes. Rots of Ruck.
Feb 04, 2009 | Maytag PAV2300 Top Load Washer
Lint in washer somewhere
It probably isn't the agitator. Are you sure that it is lint and not the clothes getting torn up? One thing you might want to try is this. First take and pull the basket to one side and clean the gasket on top of the basket. There may be gunk built up on it that is transferring to your clothes. After you do that, just like a coffee maker, put about a cup of white vinegar into the washer and run a wash on hot water. After the load wash again without the vinegar just to make sure it all gets out. This is a good way to keep the washer clean all the time too, do this maybe every 3 months or so. I will clean any hard water deposits built up on the hoses and such and you will notice you clothes coming out cleaner. You can do this with your dishwasher too. Let me know if you have any other questions and if this was helpful to you at all. Good luck and I am glad that I could help you out.
Jan 16, 2009 | Kenmore 24032\24036 Top Load Washer
To much lint on my clothes after washing
try an emptyhot wash with some limescale remover in approx quater of a litre, let it run all the way through the wash then put on another rinse to clear out system. check the next water fill for any debris/lint left.
Jun 16, 2007 | Kenmore 22442 Top Load Washer
Washing Machines Logo
77 people viewed this question
Dan Webster
Dan Webster
Sal De
